37m[16.11.2021, 15:23:22] [39mGot SIGTERM, shutting down Homebridge...
[37m[16.11.2021, 15:23:22] [39m[36m[Wohnzimmer][39m INFO - shutdown
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m HTTP Server closed
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m User interface closed
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m HauseingangHSV: FFmpeg prebuffer process exited (expected)
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m HauseingangHSV: Prebufferring process closed
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m WEHSVNEW: FFmpeg prebuffer process exited (expected)
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m WEHSVNEW: Prebufferring process closed
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: FFmpeg prebuffer process exited (expected)
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Prebufferring process closed
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m HofHSV: FFmpeg prebuffer process exited (expected)
[37m[16.11.2021, 15:23:22] [39m[36m[CameraUI][39m HofHSV: Prebufferring process closed
[37m[16.11.2021, 15:23:27][0m [36m[HB Supervisor][0m Homebridge Process Ended. Code: 143, Signal: null
[37m[16.11.2021, 15:23:32][0m [36m[HB Supervisor][0m Restarting Homebridge...
[37m[16.11.2021, 15:23:32][0m [36m[HB Supervisor][0m Starting Homebridge with extra flags: -D
[37m[16.11.2021, 15:23:32][0m [36m[HB Supervisor][0m Started Homebridge v1.3.5 with PID: 3858
Initializing HAP-NodeJS v0.9.6...
[37m[16.11.2021, 15:23:33] [39mLoaded config.json with 2 accessories and 6 platforms.
[37m[16.11.2021, 15:23:33] [39mLoaded 3 cached accessories from cachedAccessories.
[37m[16.11.2021, 15:23:33] [39m---
[37m[16.11.2021, 15:23:33] [39mLoaded plugin: [email protected]
[37m[16.11.2021, 15:23:33] [39mRegistering platform 'homebridge-config-ui-x.config'
[37m[16.11.2021, 15:23:33] [39mRegistering platform 'homebridge-harmony.HarmonyHubWebSocket'
[37m[16.11.2021, 15:23:33] [39mRegistering accessory 'homebridge-http-motion-sensor.http-motion-sensor'
[37m[16.11.2021, 15:23:33] [39m[33mDisabled plugin: [email protected][39m
[37m[16.11.2021, 15:23:33] [39mRegistering platform 'homebridge-samsung-tizen.SamsungTizen'
[37m[16.11.2021, 15:23:33] [39mRegistering accessory 'homebridge-twinkly.Twinkly'
[37m[16.11.2021, 15:23:33] [39mRegistering platform 'homebridge-twinkly.Twinkly'
[37m[16.11.2021, 15:23:33] [39mRegistering platform 'homebridge-camera-ui.CameraUI'
[37m[16.11.2021, 15:23:33] [39mLoading 6 platforms...
[37m[16.11.2021, 15:23:33] [39m[36m[Config][39m Initializing config platform...
[37m[16.11.2021, 15:23:33] [39m[36m[Config][39m Running in Service Mode
[37m[16.11.2021, 15:23:33] [39m[36m[SamsungTizen][39m Initializing SamsungTizen platform...
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m Initializing HarmonyHubWebSocket platform...
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m HarmonyPlatform Init
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO : following activites controls will be ignored if they are in the same state : NONE[39m
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - remoteOverrideCommandsList is : undefined[39m
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)(Wohnzimmer)INFO - playPause option set to false[39m
[37m[16.11.2021, 15:23:33] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - input visibility file does not exist[39m
[37m[16.11.2021, 15:23:33] [39m[36m[Twinkly][39m Initializing Twinkly platform...
[37m[16.11.2021, 15:23:33] [39m[36m[CameraUI][39m Initializing CameraUI platform...
[37m[16.11.2021, 15:23:33] [39m[33mIgnoring config for the platform "midea-air" in your config.json as the plugin "homebridge-midea-air" has been disabled.[39m
[37m[16.11.2021, 15:23:34] [39mLoading 2 accessories...
[37m[16.11.2021, 15:23:34] [39m[36m[Alarm][39m Initializing http-motion-sensor accessory...
[37m[16.11.2021, 15:23:34] [39m[36m[Waschmaschine][39m Initializing http-motion-sensor accessory...
[37m[16.11.2021, 15:23:34] [39m[36m[Wohnzimmer][39m [90mWohnzimmer-TV Got cached Accessory 7faa2501-af2d-4a67-8770-f696cdc12cc8 for Wohnzimmer[39m
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Initializing platform accessory: 36615A34-6C3B-4C87-806D-FE7462353CF0 (Küchenpfeiler 2)
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Last known address: 192.168.2.31
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Initializing platform accessory: 7482347A-68A7-459B-8CE5-7B910787951B (Küchenpfeiler)
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Last known address: 192.168.2.30
[37m[16.11.2021, 15:23:34] [39m[36m[Wohnzimmer][39m DidFinishLaunching
[37m[16.11.2021, 15:23:34] [39m[36m[Wohnzimmer][39m (Wohnzimmer)INFO - Loading activities...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m Initializing camera.ui with PID: 3858
Preparing Advertiser for 'Homebridge CD38 001D' using ciao backend!
Setup Payload:
X-HM://0024WP8D9O4II
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
[30m[47m [49m[39m
[30m[47m ┌────────────┐ [49m[39m
[30m[47m │ 869-51-581 │ [49m[39m
[30m[47m └────────────┘ [49m[39m
[30m[47m [49m[39m
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Broadcasting to find devices...
Starting to advertise 'Homebridge CD38 001D' using ciao backend!
[37m[16.11.2021, 15:23:34] [39mHomebridge v1.3.5 (Homebridge CD38) is running on port 51878.
[37m[16.11.2021, 15:23:34] [39m[36m[Alarm][39m The device 'Alarm' can now be reached under http://0.0.0.0:18084
[37m[16.11.2021, 15:23:34] [39m[36m[Waschmaschine][39m The device 'Waschmaschine' can now be reached under http://0.0.0.0:9000
Preparing Advertiser for 'Schlafzimmerfernseher E0BA' using ciao backend!
Preparing Advertiser for 'Kueche BC11' using ciao backend!
Preparing Advertiser for 'Gästezimmer TV E9C9' using ciao backend!
Starting to advertise 'Schlafzimmerfernseher E0BA' using ciao backend!
[37m[16.11.2021, 15:23:34] [39mSchlafzimmerfernseher E0BA is running on port 33693.
[37m[16.11.2021, 15:23:34] [39mPlease add [Schlafzimmerfernseher E0BA] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'Kueche BC11' using ciao backend!
[37m[16.11.2021, 15:23:34] [39mKueche BC11 is running on port 43185.
[37m[16.11.2021, 15:23:34] [39mPlease add [Kueche BC11] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'Gästezimmer TV E9C9' using ciao backend!
[37m[16.11.2021, 15:23:34] [39mGästezimmer TV E9C9 is running on port 43193.
[37m[16.11.2021, 15:23:34] [39mPlease add [Gästezimmer TV E9C9] manually in Home app. Setup Code: 869-51-581
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/gestalt
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/gestalt
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Found known device: 7482347A-68A7-459B-8CE5-7B910787951B @ 192.168.2.30
[37m[16.11.2021, 15:23:34] [39m[36m[Twinkly][39m Found known device: 36615A34-6C3B-4C87-806D-FE7462353CF0 @ 192.168.2.31
[37m[16.11.2021, 15:23:34] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - socket opened[39m
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m Clear timer for notification (ff4621634d) reached
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m Clear timer for notification (bd7b4762f6) reached
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m Clear timer for notification (50d31a76c7) reached
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m HauseingangHSV: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m HauseingangHSV: Probe stream: -i rtsp://installer:[email protected]/Streaming/Channels/1
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m HofHSV: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m HofHSV: Probe stream: -i rtsp://admin:[email protected]:554/h264Preview_01_main
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m PrusaN: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m PrusaN: Probe stream: -i http://192.168.2.92/webcam/?action=stream&1616352533258
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m TiefgarageHSV: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m TiefgarageHSV: Probe stream: -i rtsp://admin:[email protected]:554/h264Preview_01_sub
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m SchlafzimmerHSV: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m SchlafzimmerHSV: Probe stream: -i rtsp://admin:[email protected]:554/h264Preview_01_sub
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Probe stream: -i rtsp://admin1:[email protected]:554/stream1
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m WEHSVNEW: Setting up camera, please be patient...
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m WEHSVNEW: Probe stream: -i rtsp://admin:[email protected]/live0
[37m[16.11.2021, 15:23:34] [39m[36m[CameraUI][39m PrusaN: {"probe":true,"timedout":false,"audio":[],"video":["mjpeg (Baseline)","yuvj422p(pc","bt470bg/unknown/unknown)","1280x720","25 tbr","25 tbn","25 tbc"]}
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m Authentication…
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m POST http://192.168.2.31/xled/v1/login
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m POST http://192.168.2.30/xled/v1/login
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m POST http://192.168.2.30/xled/v1/verify
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m POST http://192.168.2.31/xled/v1/verify
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m Authentication successful
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/mode
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m (Wohnzimmer)INFO - configuring Main TV Service
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - accessories : main activity name : undefined[39m
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - accessories : activity to configure : Fernsehen[39m
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - accessories : activity to configure : Sky[39m
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - accessories : activity to configure : Apple TV sehen[39m
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m (Wohnzimmer)WARNING - No main Activity that match config file found, default to first one
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m (Wohnzimmer)INFO - Configuring Main Activity Fernsehen
[37m[16.11.2021, 15:23:35] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - Accessories confirmed after retrieving hub infos : [39m
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/mode
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/out/brightness
[37m[16.11.2021, 15:23:35] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/out/brightness
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WEHSVNEW: {"probe":true,"timedout":false,"audio":["aac (LC)","16000 Hz","mono","fltp"],"video":["h264 (High)","yuv420p(tv","bt709","progressive)","1920x1080","15 fps","14.99 tbr","90k tbn","30 tbc"]}
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WEHSVNEW: Start prebuffering...
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WEHSVNEW: Prebuffering command: ffmpeg -hide_banner -loglevel error -analyzeduration 600 -probesize 640 -rtsp_transport tcp -i rtsp://admin:[email protected]/live0 -f mp4 -vcodec copy -an -movflags frag_keyframe+empty_moov+default_base_moof tcp://127.0.0.1:25905
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: {"probe":true,"timedout":false,"audio":["pcm_alaw","8000 Hz","mono","s16","64 kb/s"],"video":["h264 (High)","yuvj420p(pc","bt709","progressive)","1920x1080","15 fps","29.75 tbr","90k tbn","30 tbc"]}
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Start prebuffering...
[37m[16.11.2021, 15:23:36] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Prebuffering command: ffmpeg -hide_banner -loglevel error -reorder_queue_size 1025 -max_delay 0 -rtsp_transport tcp -i rtsp://admin1:[email protected]:554/stream1 -f mp4 -vcodec copy -an -movflags frag_keyframe+empty_moov+default_base_moof tcp://127.0.0.1:23857
[37m[16.11.2021, 15:23:38] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCurrentActivity : Refresh needed since last update is too old or current Activity is not set : -1[39m
[37m[16.11.2021, 15:23:38] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)keysMap is :{}[39m
[37m[16.11.2021, 15:23:38] [39m[36m[CameraUI][39m HauseingangHSV: {"probe":true,"timedout":false,"audio":[],"video":["h264 (Main)","yuv420p(progressive)","1280x720","10 fps","10 tbr","90k tbn","20 tbc"]}
[37m[16.11.2021, 15:23:38] [39m[36m[CameraUI][39m HauseingangHSV: Start prebuffering...
[37m[16.11.2021, 15:23:38] [39m[36m[CameraUI][39m HauseingangHSV: Prebuffering command: ffmpeg -hide_banner -loglevel error -rtsp_transport tcp -reorder_queue_size 1025 -max_delay 0 -i rtsp://installer:[email protected]/Streaming/Channels/1 -f mp4 -vcodec copy -an -movflags frag_keyframe+empty_moov+default_base_moof tcp://127.0.0.1:27144
[37m[16.11.2021, 15:23:39] [39m[36m[CameraUI][39m TiefgarageHSV: {"probe":true,"timedout":false,"audio":["aac (LC)","16000 Hz","mono","fltp"],"video":["h264 (High)","yuv420p(progressive)","640x480","12 tbr","90k tbn","180k tbc"]}
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.Active [39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCurrentActivity : Refresh needed since last update is too old or current Activity is not set : -1[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.ActiveIdentifier[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCurrentActivity : Cancelling refresh since a refresh is allready in progress -1[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCharacteristic : updating Characteristic.ActiveIdentifier to 0[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.CurrentVisibilityState : DEFAULT - 0[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.TargetVisibilityState : DEFAULT - 0[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.Mute[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.Volume[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/mode
[37m[16.11.2021, 15:23:41] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/mode
[37m[16.11.2021, 15:23:41] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/out/brightness
[37m[16.11.2021, 15:23:41] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/out/brightness
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)keysMap is :{}[39m
[37m[16.11.2021, 15:23:41] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCharacteristic : updating Characteristic.Active to false[39m
[37m[16.11.2021, 15:23:41] [39m[36m[CameraUI][39m HofHSV: {"probe":true,"timedout":false,"audio":["aac (LC)","16000 Hz","mono","fltp"],"video":["h264 (High)","yuv420p(progressive)","1920x1072","4 tbr","90k tbn","180k tbc"]}
[37m[16.11.2021, 15:23:41] [39m[36m[CameraUI][39m HofHSV: Start prebuffering...
[37m[16.11.2021, 15:23:41] [39m[36m[CameraUI][39m HofHSV: Prebuffering command: ffmpeg -hide_banner -loglevel error -rtsp_transport udp -i rtsp://admin:[email protected]:554/h264Preview_01_main -f mp4 -vcodec copy -an -movflags frag_keyframe+empty_moov+default_base_moof tcp://127.0.0.1:23730
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m Can not determine stream codecs, probe timed out
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m SchlafzimmerHSV: {"probe":true,"timedout":true,"audio":["aac (LC)","16000 Hz","mono","fltp"],"video":["h264 (High)","yuv420p(progressive)","640x480","12.50 tbr","90k tbn","180k tbc"]}
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m Setting up HTTP server for motion detection...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HauseingangHSV: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HauseingangHSV: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HauseingangHSV: Initializing HomeKit Secure Video
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HauseingangHSV: Adding doorbell service
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HofHSV: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HofHSV: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HofHSV: Initializing HomeKit Secure Video
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m PrusaN: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m PrusaN: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m TiefgarageHSV: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m TiefgarageHSV: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m TiefgarageHSV: Adding motion sensor service
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m SchlafzimmerHSV: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m SchlafzimmerHSV: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Initializing HomeKit Secure Video
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Adding doorbell service
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WEHSVNEW: Configuring unbridged accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WEHSVNEW: Setting up accessory...
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WEHSVNEW: Initializing HomeKit Secure Video
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m WEHSVNEW: Adding doorbell service
Preparing Advertiser for 'HauseingangHSV 53A2' using ciao backend!
Preparing Advertiser for 'HofHSV 2DAB' using ciao backend!
Preparing Advertiser for 'PrusaN 23C8' using ciao backend!
Preparing Advertiser for 'TiefgarageHSV DD9B' using ciao backend!
Preparing Advertiser for 'SchlafzimmerHSV 6B24' using ciao backend!
Preparing Advertiser for 'WohnungseingangHSVNeu 3B56' using ciao backend!
Preparing Advertiser for 'WEHSVNEW F61C' using ciao backend!
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m HTTP server for motion detection is listening on port 2525
[37m[16.11.2021, 15:23:42] [39m[36m[CameraUI][39m camera.ui v5.0.0-alpha.89 is listening on port 2526 (http)
(node:3858) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 shutdown listeners added to [HomebridgeAPI]. Use emitter.setMaxListeners() to increase limit
(Use `node --trace-warnings ...` to show where the warning was created)
Starting to advertise 'HauseingangHSV 53A2' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mHauseingangHSV 53A2 is running on port 34097.
[37m[16.11.2021, 15:23:42] [39mPlease add [HauseingangHSV 53A2] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'HofHSV 2DAB' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mHofHSV 2DAB is running on port 46469.
[37m[16.11.2021, 15:23:42] [39mPlease add [HofHSV 2DAB] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'PrusaN 23C8' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mPrusaN 23C8 is running on port 38193.
[37m[16.11.2021, 15:23:42] [39mPlease add [PrusaN 23C8] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'TiefgarageHSV DD9B' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mTiefgarageHSV DD9B is running on port 39225.
[37m[16.11.2021, 15:23:42] [39mPlease add [TiefgarageHSV DD9B] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'SchlafzimmerHSV 6B24' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mSchlafzimmerHSV 6B24 is running on port 44553.
[37m[16.11.2021, 15:23:42] [39mPlease add [SchlafzimmerHSV 6B24] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'WohnungseingangHSVNeu 3B56' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mWohnungseingangHSVNeu 3B56 is running on port 37407.
[37m[16.11.2021, 15:23:42] [39mPlease add [WohnungseingangHSVNeu 3B56] manually in Home app. Setup Code: 869-51-581
Starting to advertise 'WEHSVNEW F61C' using ciao backend!
[37m[16.11.2021, 15:23:42] [39mWEHSVNEW F61C is running on port 33543.
[37m[16.11.2021, 15:23:42] [39mPlease add [WEHSVNEW F61C] manually in Home app. Setup Code: 869-51-581
[37m[16.11.2021, 15:24:09] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/out/brightness
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.ActiveIdentifier[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCurrentActivity : Refresh needed since last update is too old or current Activity is not set : -1[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.Active [39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCurrentActivity : Cancelling refresh since a refresh is allready in progress -1[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCharacteristic : updating Characteristic.Active to false[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - GET Characteristic.CurrentVisibilityState : DEFAULT - 0[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/out/brightness
[37m[16.11.2021, 15:24:09] [39m[36m[Twinkly][39m GET http://192.168.2.31/xled/v1/led/mode
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)keysMap is :{}[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Wohnzimmer][39m [90m(Wohnzimmer)INFO - refreshCharacteristic : updating Characteristic.ActiveIdentifier to 0[39m
[37m[16.11.2021, 15:24:09] [39m[36m[Twinkly][39m GET http://192.168.2.30/xled/v1/led/mode
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m SchlafzimmerHSV: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m SchlafzimmerHSV: Snapshot command: ffmpeg -i http://192.168.2.56/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=XXX -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: Snapshot command: ffmpeg -i http://192.168.2.92/webcam/?action=snapshot -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m HofHSV: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m HofHSV: Snapshot command: ffmpeg -i http://192.168.0.212/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=XXX -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Snapshot command: ffmpeg -rtsp_transport tcp -re -i rtsp://admin1:[email protected]:554/stream2 -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m TiefgarageHSV: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m TiefgarageHSV: Snapshot command: ffmpeg -i http://192.168.0.215/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=XXX -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m HauseingangHSV: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m HauseingangHSV: Snapshot command: ffmpeg -i http://installer:[email protected]/Streaming/channels/1/picture/ -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m WEHSVNEW: Snapshot requested: 1280 x 720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m WEHSVNEW: Snapshot command: ffmpeg -rtsp_transport tcp -i rtsp://admin:[email protected]/live0 -frames:v 1 -f image2 - -hide_banner -loglevel error
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: [mjpeg @ 0x55e33b188900] unable to decode APP fields: Invalid data found when processing input
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: [mjpeg @ 0x55e33b189f80] unable to decode APP fields: Invalid data found when processing input
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: Fetching snapshot took 0.288 seconds.
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: Sending snapshot: 1280x720
[37m[16.11.2021, 15:24:10] [39m[36m[CameraUI][39m PrusaN: Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m TiefgarageHSV: Fetching snapshot took 0.793 seconds.
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m TiefgarageHSV: Sending snapshot: 1280x720
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m TiefgarageHSV: Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HofHSV: Fetching snapshot took 0.928 seconds.
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HofHSV: Sending snapshot: 1280x720
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HofHSV: Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HauseingangHSV: Fetching snapshot took 0.909 seconds.
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HauseingangHSV: Sending snapshot: 1280x720
[37m[16.11.2021, 15:24:11] [39m[36m[CameraUI][39m HauseingangHSV: Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[37m[16.11.2021, 15:24:12] [39m[36m[CameraUI][39m WEHSVNEW: Fetching snapshot took 2.331 seconds.
[37m[16.11.2021, 15:24:12] [39m[36m[CameraUI][39m WEHSVNEW: Sending snapshot: 1280x720
[37m[16.11.2021, 15:24:12] [39m[36m[CameraUI][39m WEHSVNEW: Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[37m[16.11.2021, 15:24:13] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Fetching snapshot took 2.548 seconds.
[37m[16.11.2021, 15:24:13] [39m[36m[CameraUI][39m WohnungseingangHSVNeu: Sending snapshot: 1280x720
