ich habe vor einiger Zeit mal den homebridge-timer installiert gehabt und da ich diesen dann doch nicht benötigt hatte wieder deinstalliert. Nun hätte ich bedarf an diesen timer, jedoch kann ich ihn nicht installieren...
sudo npm install -g homebridge-timer
Password:
> [email protected] install /usr/local/lib/node_modules/homebridge-timer/node_modules/fibers
> node build.js || nodejs build.js
gyp WARN EACCES user "root" does not have permission to access the dev dir "/Users/Manuel/.node-gyp/10.16.2"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/homebridge-timer/node_modules/fibers/.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/homebridge-timer/node_modules/fibers/.node-gyp'
gyp ERR! System Darwin 17.7.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--release"
gyp ERR! cwd /usr/local/lib/node_modules/homebridge-timer/node_modules/fibers
gyp ERR! node -v v10.16.2
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-gyp exited with code: 1
Please make sure you are using a supported platform and node version. If you
would like to compile fibers on this machine please make sure you have setup your
build environment--
Windows + OS X instructions here: https://github.com/nodejs/node-gyp
Ubuntu users please run: `sudo apt-get install g++ build-essential`
Alpine users please run: `sudo apk add python make g++`
sh: nodejs: command not found
npm ERR! file sh
npm ERR! code ELIFECYCLE
npm ERR! errno ENOENT
npm ERR! syscall spawn
npm ERR! [email protected] install: `node build.js || nodejs build.js`
npm ERR! spawn ENOENT
npm ERR!
npm ERR! /Users/Manuel/.npm/_logs/2019-08-17T06_31_40_535Z-debug.log
Server:~ Manuel$
Wenn ich diesen Timer noch richtig im Kopf habe, so war bei dem es sehr angenehm, dass der Countdown der runtergezählt wurde sichtbar war. Das hätte ich so eigentlich gern wieder.
