Hallo zusammen, meine Homebridge läuft nicht mehr und ich komme auch nicht mehr mit dem Browser auf die Oberfläche.
Ist das hier das richtige Journal? Mit dem Problem bin ich jetzt überfragt. Habe die Homebridge nach der Anleitung von dieser Seite installiert und sie lief auch rund. Hat es mit irgendeinen Update zu tun?
Sep 25 17:21:19 raspberrypi homebridge[6564]: [9/25/2019, 5:21:19 PM] Homebridge is running on port 51826.
Sep 25 17:21:19 raspberrypi homebridge[6564]: [9/25/2019, 5:21:19 PM] [WeatherPlus] Error retrieving weather report and forecast for DarkSky
Sep 25 17:21:19 raspberrypi homebridge[6564]: [9/25/2019, 5:21:19 PM] [WeatherPlus] Error Message: Forecast cannot be retrieved. Response: 403 Forbidden
Sep 25 17:21:23 raspberrypi homebridge[6564]: [9/25/2019, 5:21:23 PM] [Config] Homebridge Config UI X v4.6.1 is listening on :: port 8080
Sep 25 17:21:24 raspberrypi homebridge[6564]: [9/25/2019, 5:21:24 PM] [Config] Error: listen EADDRINUSE: address already in use :::8080
Sep 25 17:21:24 raspberrypi homebridge[6564]: [9/25/2019, 5:21:24 PM] [Config] Another process or service on this host is using port 8080.
Sep 25 17:21:24 raspberrypi homebridge[6564]: [9/25/2019, 5:21:24 PM] [Config] Please stop the other service or change the port you have assigned to homebridge-config-ui-x.
Sep 25 17:21:24 raspberrypi homebridge[6564]: [9/25/2019, 5:21:24 PM] [Config] Ending process now.
Sep 25 17:21:24 raspberrypi homebridge[6564]: [9/25/2019, 5:21:24 PM] Got SIGTERM, shutting down Homebridge...
Sep 25 17:21:29 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Sep 25 17:21:29 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Sep 25 17:21:29 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Sep 25 17:21:39 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Sep 25 17:21:39 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Sep 25 17:21:39 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Sep 25 17:21:41 raspberrypi homebridge[6613]: [9/25/2019, 5:21:41 PM] Loaded config.json with 0 accessories and 4 platforms.
Sep 25 17:21:41 raspberrypi homebridge[6613]: [9/25/2019, 5:21:41 PM] ---
Sep 25 17:21:41 raspberrypi homebridge[6613]: [9/25/2019, 5:21:41 PM] Loaded plugin: homebridge-config-ui-x
Sep 25 17:21:41 raspberrypi homebridge[6613]: [9/25/2019, 5:21:41 PM] Registering platform 'homebridge-config-ui-x.config'
Sep 25 17:21:41 raspberrypi homebridge[6613]: [9/25/2019, 5:21:41 PM] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.16.3 which does not satisfy the current Node version of v10.15.3. You may need to upgrade your installation of Node.
Sep 25 17:21:42 raspberrypi homebridge[6613]: [9/25/2019, 5:21:42 PM] Loaded plugin: homebridge-hue
Sep 25 17:21:42 raspberrypi homebridge[6613]: [9/25/2019, 5:21:42 PM] Registering platform 'homebridge-hue.Hue'
Sep 25 17:21:42 raspberrypi homebridge[6613]: [9/25/2019, 5:21:42 PM] ---
Sep 25 17:21:42 raspberrypi homebridge[6613]: [9/25/2019, 5:21:42 PM] Loaded plugin: homebridge-shelly
Sep 25 17:21:43 raspberrypi homebridge[6613]: [9/25/2019, 5:21:43 PM] Registering platform 'homebridge-shelly.Shelly'
Sep 25 17:21:43 raspberrypi homebridge[6613]: [9/25/2019, 5:21:43 PM] ---
Sep 25 17:21:44 raspberrypi homebridge[6613]: [9/25/2019, 5:21:44 PM] Loaded plugin: homebridge-weather-plus
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] Registering platform 'homebridge-weather-plus.WeatherPlus'
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] ---
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] Loading 4 platforms...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Config] Initializing config platform...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Config] Spawning homebridge-config-ui-x with PID 6633
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] Initializing Hue platform...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] config.json: warning: philipslights: ignoring unknown key
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] config.json: warning: ct: ignoring unknown key
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] config.json: warning: linkbutton: ignoring unknown key
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] homebridge-hue v0.11.40, node v10.15.3, homebridge v0.4.50
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Hue] warning: not using recommended node version v10.16.3 LTS
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [WeatherPlus] Initializing WeatherPlus platform...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [WeatherPlus] Initializing platform accessory 'Wetterdaten'...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Shelly] Initializing Shelly platform...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] Loading 0 accessories...
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Shelly] 6 accessories loaded from cache
Sep 25 17:21:46 raspberrypi homebridge[6613]: [9/25/2019, 5:21:46 PM] [Shelly] Admin server is running on port 8080
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Philips hue: Philips BSB002 bridge v1934129020, api v1.34.0
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Philips hue: warning: not using recommended Hue bridge api version 1.33.0
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [WeatherPlus] Error retrieving rain report
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [WeatherPlus] Error Message: Forecast cannot be retrieved. Response: 403 Forbidden
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Philips hue: 3 accessories
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Initializing platform accessory 'Philips hue'...
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Philips hue: 2 services
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Initializing platform accessory 'Stern'...
Sep 25 17:21:47 raspberrypi homebridge[6613]: [9/25/2019, 5:21:47 PM] [Hue] Initializing platform accessory 'Arbeitsplatte'...
Sep 25 17:21:47 raspberrypi homebridge[6613]: Setup Payload:
Sep 25 17:21:47 raspberrypi homebridge[6613]: X-HM://0023ISYWYLDPI
Sep 25 17:21:47 raspberrypi homebridge[6613]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
