Abend alle zusammen,
bei mir gab es heute einen Stromausfall und seitdem startet die Homebridge wegen dem Plugin Homebridge rm-tv nicht mehr.
pi@raspberrypi:~ $ sudo systemctl restart homebridge; sudo journalctl -fau homebridge
-- Logs begin at Sat 2020-04-25 15:17:01 CEST. --
Apr 25 20:49:41 raspberrypi homebridge[20372]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
Apr 25 20:49:41 raspberrypi homebridge[20372]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
Apr 25 20:49:41 raspberrypi homebridge[20372]: at Module.load (internal/modules/cjs/loader.js:1000:32)
Apr 25 20:49:41 raspberrypi homebridge[20372]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
Apr 25 20:49:41 raspberrypi homebridge[20372]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
Apr 25 20:49:41 raspberrypi homebridge[20372]: [4/25/2020, 20:49:41] Got SIGTERM, shutting down Homebridge...
Apr 25 20:49:46 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Apr 25 20:49:46 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 25 20:49:56 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Apr 25 20:49:56 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 25 20:49:59 raspberrypi homebridge[20414]: [4/25/2020, 20:49:59] Loaded config.json with 1 accessories and 3 platforms.
Apr 25 20:49:59 raspberrypi homebridge[20414]: [4/25/2020, 20:49:59] ---
Apr 25 20:50:01 raspberrypi homebridge[20414]: [4/25/2020, 20:50:01] Loaded plugin: homebridge-broadlink-rm-tv
Apr 25 20:50:01 raspberrypi homebridge[20414]: [4/25/2020, 20:50:01] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
Apr 25 20:50:01 raspberrypi homebridge[20414]: [4/25/2020, 20:50:01] ---
Apr 25 20:50:01 raspberrypi homebridge[20414]: [4/25/2020, 20:50:01] Loaded plugin: homebridge-config-ui-x
Apr 25 20:50:01 raspberrypi homebridge[20414]: [4/25/2020, 20:50:01] Registering platform 'homebridge-config-ui-x.config'
Apr 25 20:50:06 raspberrypi homebridge[20414]: [4/25/2020, 20:50:06] Loaded plugin: homebridge-hue
Apr 25 20:50:06 raspberrypi homebridge[20414]: [4/25/2020, 20:50:06] Registering platform 'homebridge-hue.Hue'
Apr 25 20:50:06 raspberrypi homebridge[20414]: [4/25/2020, 20:50:06] ---
Apr 25 20:50:06 raspberrypi homebridge[20414]: [4/25/2020, 20:50:06] Loaded plugin: homebridge-mi-flora-filtered
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] Registering accessory 'homebridge-mi-flora-filtered.mi-flower-care'
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] ---
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] Loading 3 platforms...
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] [Config] Initializing config platform...
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] [Config] Spawning homebridge-config-ui-x with PID 20444
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] [Broadlink] Initializing BroadlinkRM platform...
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] Error: [PARSE-ERROR] /var/homebridge/plugin-persist/homebridge-broadlink-rm/fdb3f22f83878465c40a21859b26113b does not look like a valid storage file!
Apr 25 20:50:10 raspberrypi homebridge[20414]: at LocalStorage.parseFileSync (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/node-persist/src/local-storage.js:666:19)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/node-persist/src/local-storage.js:615:26)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/node-persist/src/local-storage.js:142:14)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/node-persist/src/node-persist.js:37:32)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Object.init (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/homebridge-platform-helper/helpers/persistentState.js:9:15)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at new HomebridgePlatform (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/node_modules/homebridge-platform-helper/platform.js:15:21)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at new BroadlinkRMPlatform (/usr/local/lib/node_modules/homebridge-broadlink-rm-tv/platform.js:33:5)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:337:32)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Module.load (internal/modules/cjs/loader.js:1000:32)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
Apr 25 20:50:10 raspberrypi homebridge[20414]: at internal/main/run_main_module.js:18:47
Apr 25 20:50:10 raspberrypi homebridge[20414]: [4/25/2020, 20:50:10] Got SIGTERM, shutting down Homebridge...
Apr 25 20:50:15 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Apr 25 20:50:15 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
^C
pi@raspberrypi:~ $
Auf Github hab vom Entwickler schon ein Issue gefunden da hab ich den Befehl wie beschrieben eingegeben hat aber leider nichts gebracht.
Kann mir da einer weiterhelfen?
