Leider hat sich mein Homebridge verabschiedet, ich habe gestern über das UI die Module und die Homebridge upgedated und jetzt kann ich die Seite nicht mehr aufrufen. habt ihr ne Idee? habe echt schon viele Tipps hier im Forum durchgespielt, aber ich komme nicht mehr drauf.
Könnt ihr mal in den Logs schauen und mir helfen? danke
root@raspberrypi:~# sudo systemctl restart homebridge; sudo journalctl -fau homebridge
-- Logs begin at Thu 2016-11-03 18:16:44 CET. --
Jun 14 10:33:59 raspberrypi homebridge[2104]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Jun 14 10:33:59 raspberrypi homebridge[2104]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
Jun 14 10:33:59 raspberrypi homebridge[2104]: at startup (internal/bootstrap/node.js:283:19)
Jun 14 10:33:59 raspberrypi homebridge[2104]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
Jun 14 10:33:59 raspberrypi homebridge[2104]: [6/14/2020, 10:33:59 AM] Got SIGTERM, shutting down Homebridge...
Jun 14 10:34:04 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jun 14 10:34:04 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jun 14 10:34:04 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Jun 14 10:34:04 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jun 14 10:34:04 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jun 14 10:34:15 raspberrypi homebridge[2143]: [6/14/2020, 10:34:15 AM] Loaded config.json with 0 accessories and 3 platforms.
Jun 14 10:34:15 raspberrypi homebridge[2143]: [6/14/2020, 10:34:15 AM] ---
Jun 14 10:34:25 raspberrypi homebridge[2143]: [6/14/2020, 10:34:25 AM] Loaded plugin: [email protected]
Jun 14 10:34:25 raspberrypi homebridge[2143]: [6/14/2020, 10:34:25 AM] Registering platform 'homebridge-config-ui-x.config'
Jun 14 10:34:25 raspberrypi homebridge[2143]: [6/14/2020, 10:34:25 AM] ---
Jun 14 10:34:27 raspberrypi homebridge[2143]: ###
Jun 14 10:34:27 raspberrypi homebridge[2143]: ### The "request" library is not installed automatically anymore.
Jun 14 10:34:27 raspberrypi homebridge[2143]: ### But is a dependency of "request-promise".
Jun 14 10:34:27 raspberrypi homebridge[2143]: ### Please install it with:
Jun 14 10:34:27 raspberrypi homebridge[2143]: ### npm install request --save
Jun 14 10:34:27 raspberrypi homebridge[2143]: [6/14/2020, 10:34:27 AM] ====================
Jun 14 10:34:27 raspberrypi homebridge[2143]: [6/14/2020, 10:34:27 AM] ERROR LOADING PLUGIN homebridge-harmony:
Jun 14 10:34:27 raspberrypi homebridge[2143]: [6/14/2020, 10:34:27 AM] Error: Cannot find module 'aws4'
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Module.require (internal/modules/cjs/loader.js:692:17)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at require (internal/modules/cjs/helpers.js:25:18)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-harmony/node_modules/request/request.js:10:12)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Module._compile (internal/modules/cjs/loader.js:778:30)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Module.load (internal/modules/cjs/loader.js:653:32)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-harmony/node_modules/request/index.js:143:19)
Jun 14 10:34:27 raspberrypi homebridge[2143]: at /usr/local/lib/node_modules/homebridge-harmony/node_modules/request-promise/lib/rp.js:11:16
Jun 14 10:34:27 raspberrypi homebridge[2143]: at module.exports (/usr/local/lib/node_modules/homebridge-harmony/node_modules/stealthy-require/lib/index.js:62:23)
Jun 14 10:34:27 raspberrypi homebridge[2143]: [6/14/2020, 10:34:27 AM] The plugin "homebridge-hue" requires Node version of ^12.17.0 which does not satisfy the current Node version of v10.21.0. You may need to upgrade your installation of Node.
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] Loaded plugin: [email protected]
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] Registering platform 'homebridge-hue.Hue'
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] ---
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] Loading 3 platforms...
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] [Config] Initializing config platform...
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] [Config] Spawning homebridge-config-ui-x with PID 2175
Jun 14 10:34:40 raspberrypi homebridge[2143]: [6/14/2020, 10:34:40 AM] Error loading platform requested in your config.json at position 2
Jun 14 10:34:42 raspberrypi homebridge[2143]: [6/14/2020, 10:34:42 AM] Error: The requested platform 'HarmonyHubWebSocket' was not registered by any plugin.
Jun 14 10:34:42 raspberrypi homebridge[2143]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at config.platforms.forEach (/usr/local/lib/node_modules/homebridge/src/server.ts:386:37)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Array.forEach (<anonymous>)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:373:27)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:152:29)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Module._compile (internal/modules/cjs/loader.js:778:30)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Module.load (internal/modules/cjs/loader.js:653:32)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at startup (internal/bootstrap/node.js:283:19)
Jun 14 10:34:42 raspberrypi homebridge[2143]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
Jun 14 10:34:42 raspberrypi homebridge[2143]: [6/14/2020, 10:34:42 AM] Got SIGTERM, shutting down Homebridge...
