Moin,
wollte it folgender Anleitung mittels Airtunes und ffmpeg Sprachausgaben via Airplay von meinem Raspberry zum tätigen: https://forum.fhem.de/index.php?topic=102295.0
Mir meldet allerding der Befehl: node play_ffmpeg.js --host 192.168.3.49 --port 7000 --ffmpeg /usr/bin/ffmpeg
ZitatAlles anzeigeninternal/modules/cjs/loader.js:979
throw err;
Error: Cannot find module '../build/Release/airtunes'
Require stack:
- /home/pi/node_airtunes/lib/device_coreaudio.js
- /home/pi/node_airtunes/lib/devices.js
- /home/pi/node_airtunes/lib/index.js
- /home/pi/node_airtunes/examples/play_ffmpeg.js
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:976:15)
at Function.Module._load (internal/modules/cjs/loader.js:859:27)
at Module.require (internal/modules/cjs/loader.js:1036:19)
at require (internal/modules/cjs/helpers.js:72:18)
at Object.<anonymous> (/home/pi/node_airtunes/lib/device_coreaudio.js:4:16)
at Module._compile (internal/modules/cjs/loader.js:1147:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
at Module.load (internal/modules/cjs/loader.js:996:32)
at Function.Module._load (internal/modules/cjs/loader.js:896:14)
at Module.require (internal/modules/cjs/loader.js:1036:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/home/pi/node_airtunes/lib/device_coreaudio.js',
'/home/pi/node_airtunes/lib/devices.js',
'/home/pi/node_airtunes/lib/index.js',
'/home/pi/node_airtunes/examples/play_ffmpeg.js'
Installiert habe ich wie in dem verlinkten Thread. Also dachte ich mir ich installiere mal wie auf Github beschrieben mittels: npm install airtunes
ZitatAlles anzeigennpm ERR! code ENOSELF
npm ERR! Refusing to install package with name "airtunes" under a package
npm ERR! also called "airtunes". Did you name your project the same
npm ERR! as the dependency you're installing?
npm ERR!
npm ERR! For more information, see:
npm ERR! <https://docs.npmjs.com/cli/ins…of-npms-install-algorithm>
npm ERR! /home/pi/.npm/_logs/2020-11-02T11_06_29_399Z-debug.log
Das liegt ja vermutlich an dem bereits geklonten Github Repository? Wie bekomme ich das sauber entfernt? Das löschen des Verzeichnisses node_airtunes bringt nichts.
LG
boehser enkel
