ich habe ein Problem mit der Live-Ansicht meiner Axis-Cam M1034-W mit dem PlugIn "homebridge-camera-ffmpeg".
Ich bekomme zwar den Snapshot in Home angezeigt, aber beim Live-Stream dreht sich nur das Rad.
Das Debug-Protokoll hat folgenden Inhalt:
[7/31/2021, 5:18:35 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:18:36 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.536 seconds.
[7/31/2021, 5:18:36 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:18:36 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:18:46 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:18:46 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:18:46 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.421 seconds.
[7/31/2021, 5:18:46 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:18:46 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:18:56 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:18:56 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.471 seconds.
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Video stream requested: 1280 x 720, 30 fps, 299 kbps
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Starting video stream: 1280 x 720, 30 fps, 299 kbps (AAC-eld)
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] Stream command: ffmpeg -rtsp_transport tcp -i rtsp://User:[email protected]/axis-media/media.amp -an -sn -dn -codec:v h264 -pix_fmt yuv420p -color_range mpeg -r 30 -f rawvideo -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease,scale=trunc(iw/2)*2:trunc(ih/2)*2 -b:v 299k -payload_type 99 -ssrc 10387969 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params lIfhHL+YWL0Qw2rRqqH5SfK7dbuu3rF/GL4ygo7y srtp://192.168.2.61:54709?rtcpport=54709&pkt_size=1316 -vn -sn -dn -codec:a libfdk_aac -profile:a aac_eld -flags +global_header -f null -ar 16k -b:a 24k -ac 1 -payload_type 110 -ssrc 16136835 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params sn+DP9ynoX3l/A4ttGkrTEFRHxyUclCz+mYhdbcd srtp://192.168.2.61:54996?rtcpport=54996&pkt_size=188 -loglevel level+verbose -progress pipe:1
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] built with gcc 9.3.0 (Alpine 9.3.0)
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] configuration: --pkgconfigdir=/build/workspace/lib/pkgconfig --prefix=/build/workspace --pkg-config-flags=--static --extra-cflags=-I/build/workspace/include --extra-ldflags=-L/build/workspace/lib --extra-libs='-lpthread -lm' --enable-static --disable-debug --disable-shared --disable-ffplay --disable-doc --enable-openssl --enable-gpl --enable-version3 --enable-nonfree --enable-pthreads --enable-libvpx --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libx264 --enable-runtime-cpudetect --enable-libfdk-aac --enable-avfilter --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-filters --enable-decoder=h264 --enable-network --enable-protocol=tcp --enable-libspeex --enable-demuxer=rtsp --enable-indev=alsa --enable-outdev=alsa
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libavutil 56. 51.100 / 56. 51.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libavcodec 58. 91.100 / 58. 91.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libavformat 58. 45.100 / 58. 45.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libavdevice 58. 10.100 / 58. 10.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libavfilter 7. 85.100 / 7. 85.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libswscale 5. 7.100 / 5. 7.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libswresample 3. 7.100 / 3. 7.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] libpostproc 55. 7.100 / 55. 7.100
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [tcp @ 0x7f8fb7484b80] [verbose] Starting connection attempt to 192.168.2.86 port 554
[7/31/2021, 5:18:57 PM] [Camera FFmpeg] [Cam-Gartenhaus] [tcp @ 0x7f8fb7484b80] [verbose] Successfully connected to 192.168.2.86 port 554
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] [rtsp @ 0x7f8fb7484280] [verbose] SDP:
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] v=0
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] o=- 1627744738003785 1627744738003785 IN IP4 192.168.2.86
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] s=Media Presentation
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] e=NONE
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] b=AS:50064
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] t=0 0
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=control:*
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=range:npt=0.000000-
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] m=video 0 RTP/AVP 96
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] c=IN IP4 0.0.0.0
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] b=AS:50000
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=framerate:30.0
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=transform:-1.000000,0.000000,0.000000;0.000000,0.863839,0.000000;0.000000,0.000000,1.000000
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=control:trackID=1
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=rtpmap:96 H264/90000
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=fmtp:96 packetization-mode=1; profile-level-id=4D4029; sprop-parameter-sets=Z01AKZpmAoAt2AtQEBAQXpw=,aO48gA==
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] m=audio 0 RTP/AVP 0
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] b=AS:64
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] a=control:trackID=2
[7/31/2021, 5:18:58 PM] [Camera FFmpeg] [Cam-Gartenhaus] [rtsp @ 0x7f8fb7484280] [verbose] setting jitter buffer size to 0
[7/31/2021, 5:19:00 PM] [Camera FFmpeg] [Cam-Gartenhaus] [h264 @ 0x56220d355800] [verbose] Reinit context to 1280x720, pix_fmt: yuv420p
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [warning] Guessed Channel Layout for Input Stream #0.1 : mono
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Input #0, rtsp, from 'rtsp://User:[email protected]/axis-media/media.amp':
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Metadata:
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] title : Media Presentation
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Duration: N/A, start: 0.033211, bitrate: N/A
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #0:0: Video: h264 (Main), 1 reference frame, yuv420p(tv, bt709, progressive, left), 1280x720 [SAR 1:1 DAR 16:9], 240 tbr, 90k tbn, 180k tbc
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #0:1: Audio: pcm_mulaw, 8000 Hz, mono, s16, 64 kb/s
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] Matched encoder 'libx264' for codec 'h264'.
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream mapping:
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #0:1 -> #1:0 (pcm_mulaw (native) -> aac (libfdk_aac))
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Press [q] to stop, [?] for help
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [h264 @ 0x56220d37a940] [verbose] Reinit context to 1280x720, pix_fmt: yuv420p
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [graph_1_in_0_1 @ 0x56220d5e6580] [verbose] tb:1/8000 samplefmt:s16 samplerate:8000 chlayout:0x4
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [format_out_1_0 @ 0x56220d5e6cc0] [verbose] auto-inserting filter 'auto_resampler_0' between the filter 'Parsed_anull_0' and the filter 'format_out_1_0'
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [auto_resampler_0 @ 0x56220d5e7a40] [verbose] ch:1 chl:mono fmt:s16 r:8000Hz -> ch:1 chl:mono fmt:s16 r:16000Hz
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Output #1, rtp, to 'srtp://192.168.2.61:54996?rtcpport=54996&pkt_size=188':
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] encoder : Lavf58.45.100
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #1:0: Audio: aac (libfdk_aac) (ELD), 16000 Hz, mono, s16, delay 288, 24 kb/s
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] encoder : Lavc58.91.100 libfdk_aac
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [Parsed_scale_0 @ 0x56220d869380] [verbose] w:min(1280,iw) h:min(720,ih) flags:'bicubic' interl:0
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [Parsed_scale_1 @ 0x56220d3eac40] [verbose] w:trunc(iw/2)*2 h:trunc(ih/2)*2 flags:'bicubic' interl:0
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [graph 0 input from stream 0:0 @ 0x56220d868f80] [verbose] w:1280 h:720 pixfmt:yuv420p tb:1/90000 fr:240/1 sar:1/1
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [Parsed_scale_0 @ 0x56220d869380] [verbose] w:1280 h:720 fmt:yuv420p sar:1/1 -> w:1280 h:720 fmt:yuv420p sar:1/1 flags:0x4
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [Parsed_scale_1 @ 0x56220d3eac40] [verbose] w:1280 h:720 fmt:yuv420p sar:1/1 -> w:1280 h:720 fmt:yuv420p sar:1/1 flags:0x4
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [libx264 @ 0x56220d4be500] [info] using SAR=1/1
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [libx264 @ 0x56220d4be500] [info] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [libx264 @ 0x56220d4be500] [info] profile High, level 3.1, 4:2:0, 8-bit
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Output #0, rtp, to 'srtp://192.168.2.61:54709?rtcpport=54709&pkt_size=1316':
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Stream #0:0: Video: h264 (libx264), 1 reference frame, yuv420p(tv, left), 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 299 kb/s, 30 fps, 90k tbn, 30 tbc
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] encoder : Lavc58.91.100 libx264
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] Side data:
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] cpb: bitrate max/min/avg: 0/0/299000 buffer size: 0 vbv_delay: N/A
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** dropping frame 5 from stream 0 at ts 4
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 24 dup!
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 10 dup!
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 64 fps=0.0 q=47.0 size= 14kB time=00:00:02.21 bitrate= 50.4kbits/s dup=34 drop=1 speed=4.28x
[7/31/2021, 5:19:01 PM] [Camera FFmpeg] [Cam-Gartenhaus] Getting the first frames took 3.72 seconds.
[7/31/2021, 5:19:02 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 78 fps= 75 q=40.0 size= 20kB time=00:00:02.85 bitrate= 56.4kbits/s dup=34 drop=1 speed=2.75x
[7/31/2021, 5:19:02 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 91 fps= 59 q=39.0 size= 35kB time=00:00:03.29 bitrate= 87.9kbits/s dup=34 drop=1 speed=2.14x
[7/31/2021, 5:19:03 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 107 fps= 52 q=39.0 size= 50kB time=00:00:03.87 bitrate= 105.0kbits/s dup=34 drop=1 speed=1.88x
[7/31/2021, 5:19:03 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 121 fps= 47 q=38.0 size= 68kB time=00:00:04.38 bitrate= 126.4kbits/s dup=34 drop=1 speed= 1.7x
[7/31/2021, 5:19:03 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 5 dup!
[7/31/2021, 5:19:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 138 fps= 45 q=37.0 size= 87kB time=00:00:04.89 bitrate= 145.1kbits/s dup=39 drop=1 speed=1.58x
[7/31/2021, 5:19:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 1 dup!
[7/31/2021, 5:19:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 159 fps= 44 q=38.0 size= 115kB time=00:00:05.34 bitrate= 176.1kbits/s dup=40 drop=1 speed=1.48x
[7/31/2021, 5:19:05 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 175 fps= 42 q=38.0 size= 138kB time=00:00:05.85 bitrate= 192.2kbits/s dup=40 drop=1 speed=1.42x
[7/31/2021, 5:19:05 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 186 fps= 40 q=38.0 size= 148kB time=00:00:06.37 bitrate= 190.3kbits/s dup=40 drop=1 speed=1.38x
[7/31/2021, 5:19:06 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 203 fps= 40 q=37.0 size= 167kB time=00:00:06.88 bitrate= 198.6kbits/s dup=40 drop=1 speed=1.34x
[7/31/2021, 5:19:06 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 216 fps= 38 q=37.0 size= 185kB time=00:00:07.45 bitrate= 202.7kbits/s dup=40 drop=1 speed=1.31x
[7/31/2021, 5:19:06 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 4 dup!
[7/31/2021, 5:19:07 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 238 fps= 39 q=37.0 size= 209kB time=00:00:07.97 bitrate= 214.7kbits/s dup=44 drop=1 speed=1.29x
[7/31/2021, 5:19:07 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 250 fps= 37 q=37.0 size= 227kB time=00:00:08.41 bitrate= 220.6kbits/s dup=44 drop=1 speed=1.26x
[7/31/2021, 5:19:08 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 267 fps= 37 q=37.0 size= 246kB time=00:00:08.93 bitrate= 225.8kbits/s dup=44 drop=1 speed=1.24x
[7/31/2021, 5:19:08 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 280 fps= 36 q=37.0 size= 262kB time=00:00:09.57 bitrate= 224.7kbits/s dup=44 drop=1 speed=1.24x
[7/31/2021, 5:19:09 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 1 dup!
[7/31/2021, 5:19:09 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 295 fps= 36 q=37.0 size= 280kB time=00:00:10.01 bitrate= 228.7kbits/s dup=45 drop=1 speed=1.22x
[7/31/2021, 5:19:09 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 310 fps= 35 q=39.0 size= 324kB time=00:00:10.53 bitrate= 252.0kbits/s dup=45 drop=1 speed= 1.2x
[7/31/2021, 5:19:10 PM] [Camera FFmpeg] [Cam-Gartenhaus] [verbose] *** 3 dup!
[7/31/2021, 5:19:10 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 329 fps= 35 q=38.0 size= 341kB time=00:00:11.10 bitrate= 251.6kbits/s dup=48 drop=1 speed=1.19x
[7/31/2021, 5:19:10 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:19:10 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:19:10 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 341 fps= 35 q=38.0 size= 356kB time=00:00:11.42 bitrate= 254.9kbits/s dup=48 drop=1 speed=1.16x
[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] [info] frame= 348 fps= 34 q=38.0 size= 363kB time=00:00:11.93 bitrate= 248.9kbits/s dup=48 drop=1 speed=1.16x
[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 1.005 seconds.
[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] Stopped video stream.
[37m[7/31/2021, 5:19:11 PM] [Camera FFmpeg] [Cam-Gartenhaus] FFmpeg exited with code: null and signal: SIGKILL (Expected)
[7/31/2021, 5:19:21 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:19:21 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:19:22 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.51 seconds.
[7/31/2021, 5:19:22 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:19:22 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:19:32 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:19:32 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:19:32 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.546 seconds.
[7/31/2021, 5:19:32 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:19:32 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:19:42 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:19:42 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:19:43 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.467 seconds.
[7/31/2021, 5:19:43 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:19:43 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:19:53 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:19:53 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:19:54 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.531 seconds.
[7/31/2021, 5:19:54 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:19:54 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:20:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:20:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:20:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.529 seconds.
[7/31/2021, 5:20:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:20:04 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:20:14 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:20:14 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:20:15 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.421 seconds.
[7/31/2021, 5:20:15 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:20:15 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:20:25 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:20:25 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
[7/31/2021, 5:20:25 PM] [Camera FFmpeg] [Cam-Gartenhaus] Fetching snapshot took 0.436 seconds.
[7/31/2021, 5:20:25 PM] [Camera FFmpeg] [Cam-Gartenhaus] Sending snapshot: 1280 x 720
[7/31/2021, 5:20:25 PM] [Camera FFmpeg] [Cam-Gartenhaus] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease -f image2 -
[7/31/2021, 5:20:35 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot requested: 1280 x 720
[7/31/2021, 5:20:35 PM] [Camera FFmpeg] [Cam-Gartenhaus] Snapshot command: ffmpeg -i http://User:[email protected]/jpg/image.jpg?size=3 -frames:v 1 -f image2 - -hide_banner -loglevel error
Die Auflösung habe ich mehrfach verändert brachte aber kein Erfolg.
Für Hilfe bin ich Dankbar.
