danke für den Tip, das werde ich mal versuchen ... die Deinstallation hat gut geklappt, aber nun läuft die HB ger nicht mehr ![]()
pi@Raspi3HB:~ $ sudo service homebridge start
pi@Raspi3HB:~ $ homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[2017-11-10 10:57:33] Loaded plugin: homebridge-rcswitch-gpiomem
[2017-11-10 10:57:33] Registering accessory 'homebridge-rcswitch-gpiomem.RCSwitch'
[2017-11-10 10:57:33] ---
[2017-11-10 10:57:33] Loaded config.json with 9 accessories and 1 platforms.
[2017-11-10 10:57:33] Loading 1 platforms...
/usr/local/lib/node_modules/homebridge/lib/api.js:122
throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Error: The requested platform 'HarmonyHub' was not registered by any plugin.
at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13)
at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:293:45)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:85:36)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
at Module._compile (module.js:641:30)
at Object.Module._extensions..js (module.js:652:10)
at Module.load (module.js:560:32)
at tryModuleLoad (module.js:503:12)
at Function.Module._load (module.js:495:3)
pi@Raspi3HB:~ $
Ader die Installation vom Plugin ging nur über:
installieren ...
pi@Raspi3HB:~ $ sudo chown -R $USER /usr/local/ && npm install homebridge-harmonyhub -g
npm WARN deprecated [email protected]: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
npm WARN deprecated [email protected]: use @xmpp/jid package <https://www.npmjs.com/package/@xmpp/jid>
+ [email protected]
added 146 packages in 21.199s
pi@Raspi3HB:~ $
Nach der Installation sieht es dann wieder so aus ...
[2017-11-10 11:00:38] ---
[2017-11-10 11:00:38] Loaded config.json with 9 accessories and 1 platforms.
[2017-11-10 11:00:38] Loading 1 platforms...
[2017-11-10 11:00:38] [Harmony Hub] Initializing HarmonyHub platform...
[2017-11-10 11:00:38] Loading 9 accessories...
[2017-11-10 11:00:38] [Stehlampe] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Cinewall] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Subwoofer] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Gartenhaus] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Spots] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Schranklampe] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Schalter A] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Schalter B] Initializing RCSwitch accessory...
[2017-11-10 11:00:38] [Schalter C] Initializing RCSwitch accessory...
^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^$
^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[40m ^[[0m^[[47m ^[[0m^[[47m ^[[0m^[[47m ^$
[2017-11-10 11:00:38] Homebridge is running on port 51826.
[2017-11-10 11:00:41] [Harmony Hub] Fetching Logitech Harmony activities...
[2017-11-10 11:00:42] [Harmony Hub] Found activities:
Fernsehen
PS3
Küche Lautsprecher
PowerOff
Wohnzimmer Lautsprecher
Surround
Ob das mit dem Broadlink RM Pro einfach/besser klappt ? Muss ich da nur das PlugIn installieren oder muss da auch wie bei Pilight oder RCSwitch vorher
noch ein "Programm" installiert werden ?
CU und Danke Kai
