deCONZ --dbg-info=1 --dbg-aps=1 --dbg-zcl=1 --dbg-zdp=1 --htt p-port=80 --platform minimal
libpng warning: iCCP: known incorrect sRGB profile
This plugin does not support propagateSizeHints()
This plugin does not support raise()
15:54:50:404 HTTP Server listen on address 0.0.0.0, port: 8090, root: /usr/share /deCONZ/webapp/
15:54:50:729 dev /dev/ttyS0 (/dev/ttyS0)
15:54:50:730 ZCLDB init file /home/pi/.local/share/dresden-elektronik/deCONZ/zcl db.txt
15:54:51:089 parent process -bash
15:54:51:090 gw run mode: normal
15:54:51:090 GW sd-card image version file does not exist: /home/pi/.local/share /dresden-elektronik/deCONZ/gw-version
15:54:51:090 sd-card cid: 035344534333324780ffffffff013a2d
15:54:51:092 DB sqlite version 3.27.2
15:54:51:094 DB PRAGMA page_count: 44
15:54:51:094 DB PRAGMA page_size: 4096
15:54:51:094 DB PRAGMA freelist_count: 3
15:54:51:094 DB file size 180224 bytes, free pages 3
15:54:51:094 DB PRAGMA user_version: 7
15:54:51:094 DB cleanup
15:54:51:095 DB create temporary views
13:54:51:146 started websocket server at port 8088
13:54:51:151 [INFO] - Found file containing button maps. Parsing data...
13:54:51:178 [INFO] - Button maps loaded.
13:54:51:182 dlg action: Read binding table
13:54:51:182 found node plugin: libde_rest_plugin.so - REST API Plugin
13:54:51:187 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
13:54:51:227 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
13:54:51:636 LightNode 1: Configuration tool 1 added
13:54:51:671 LightNode 18: Licht Garten added
13:54:51:678 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:f2:53:d0%' COLLATE NOCASE: LIDL Silvercrest
13:54:51:681 LightNode 7: Offen 1 added
13:54:51:711 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:f2:53:d0%' COLLATE NOCASE: LIDL Silvercrest
13:54:51:713 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:f2:53:d0%' COLLATE NOCASE: LIDL Silvercrest
13:54:51:717 LightNode 4: Kooduu added
13:54:51:724 LightNode 24: Arbeitszimmer added
13:54:51:730 LightNode 14: Wohnzimmer rechts added
13:54:51:734 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:71:27:ff:f e:d0:b7:5e%' COLLATE NOCASE: _TZE200_htnnfasr
13:54:51:748 LightNode 22: Sprenger Hinten added
13:54:51:768 LightNode 9: Kaffeemaschine added
13:54:51:770 SensorNode 6 set node 0x00158d000411bf09
13:54:51:775 LightNode 5: On/Off light 5 added
13:54:51:778 LightNode 21: Nähzimmer added
13:54:51:782 SensorNode 11 set node 0x00158d00045cf8e7
13:54:51:791 LightNode 3: Ventilator added
13:54:51:797 LightNode 25: Dusche 1 added
13:54:51:800 LightNode 26: Dusche 2 added
13:54:51:804 SensorNode 2 set node 0x00158d000450e5b0
13:54:51:810 LightNode 2: Subwoofer added
13:54:51:812 SensorNode 3 set node 0x00158d000412111c
13:54:51:816 SensorNode 5 set node 0x00158d000411bf17
13:54:51:819 SensorNode 10 set node 0x00158d0004523526
13:54:51:828 LightNode 6: Licht Einfahrt added
13:54:51:833 LightNode 16: Arcade added
13:54:51:838 LightNode 13: Wohnzimmer hinten added
13:54:51:845 LightNode 15: Wohnzimmer links added
13:54:51:849 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:0f:5f:cc%' COLLATE NOCASE: Heiman
13:54:51:851 LightNode 17: Licht Piet added
13:54:51:873 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:0f:5f:cc%' COLLATE NOCASE: Heiman
13:54:51:874 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:f e:0f:5f:cc%' COLLATE NOCASE: Heiman
13:54:51:875 SensorNode 4 set node 0x00158d000411b5f7
13:54:51:879 LightNode 12: Betonkeller added
13:54:51:884 LightNode 20: Poolpumpe added
13:54:51:887 SensorNode 14 set node 0xec1bbdfffea570e5
13:54:51:896 LightNode 23: Chaoskeller added
13:54:51:902 LightNode 11: Licht Bodo added
13:54:51:907 LightNode 19: Einfahrt 1 added
13:54:51:912 LightNode 27: Spielehaus added
13:54:51:918 LightNode 10: TV Sicherung added
13:54:51:920 SensorNode 7 set node 0x00158d0004116757
13:54:51:926 LightNode 8: Deckenlicht Küche added
13:54:51:928 SensorNode 9 set node 0x00158d000450a3b7
13:54:52:129 Skip idle timer callback, too early: elapsed 949 msec
13:54:52:999 dev /dev/ttyS0 (/dev/ttyS0)
13:54:55:094 device state timeout ignored in state 2
13:54:55:254 device state timeout ignored in state 2
13:54:55:414 device state timeout ignored in state 2
13:54:55:574 device state timeout ignored in state 2
13:54:55:734 device state timeout ignored in state 2
13:54:55:895 device state timeout ignored in state 2
13:54:56:054 device state timeout ignored in state 2
13:54:56:230 device state timeout ignored in state 2
13:54:56:296 Announced to internet https://phoscon.de/discover
13:54:56:297 discovery server date: Thu, 15 Jul 2021 13:54:56 GMT
13:54:56:298 local time seems to be ok
13:54:56:390 device state timeout ignored in state 2
13:54:56:550 device state timeout ignored in state 2
13:54:56:711 device state timeout ignored in state 2
13:54:56:870 device state timeout (handled)
13:54:56:876 device disconnected reason: 1, index: 0
13:54:56:950 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:54:56:951 device state timeout ignored in state 1
13:54:57:106 wait reconnect 15 seconds
13:54:58:106 wait reconnect 14 seconds
13:54:59:106 wait reconnect 13 seconds
13:55:00:106 wait reconnect 12 seconds
13:55:01:106 wait reconnect 11 seconds
13:55:02:106 wait reconnect 10 seconds
13:55:03:106 wait reconnect 9 seconds
13:55:04:107 wait reconnect 8 seconds
13:55:05:106 wait reconnect 7 seconds
13:55:06:106 wait reconnect 6 seconds
13:55:06:173 dev /dev/ttyS0 (/dev/ttyS0)
13:55:07:106 wait reconnect 5 seconds
13:55:08:106 wait reconnect 4 seconds
13:55:09:106 wait reconnect 3 seconds
13:55:10:106 wait reconnect 2 seconds
13:55:11:106 wait reconnect 1 seconds
13:55:11:175 dev /dev/ttyS0 (/dev/ttyS0)
13:55:11:182 device disconnected reason: 4, index: 1
13:55:12:106 wait reconnect 15 seconds
13:55:12:185 dev /dev/ttyS0 (/dev/ttyS0)
13:55:12:190 start reconnect to network
13:55:13:107 wait reconnect 14 seconds
13:55:13:108 Skip idle timer callback, too early: elapsed 918 msec
13:55:14:106 wait reconnect 13 seconds
13:55:15:106 wait reconnect 12 seconds
13:55:16:106 wait reconnect 11 seconds
13:55:16:163 dev /dev/ttyS0 (/dev/ttyS0)
13:55:17:106 failed to reconnect to network try=1
13:55:17:107 wait reconnect 10 seconds
13:55:18:106 wait reconnect 9 seconds
13:55:19:107 wait reconnect 8 seconds
13:55:20:106 wait reconnect 7 seconds
13:55:21:106 wait reconnect 6 seconds
13:55:22:106 failed to reconnect to network try=2
13:55:22:107 wait reconnect 5 seconds
13:55:23:106 wait reconnect 4 seconds
13:55:24:106 wait reconnect 3 seconds
13:55:25:106 wait reconnect 2 seconds
13:55:26:106 wait reconnect 1 seconds
13:55:26:163 dev /dev/ttyS0 (/dev/ttyS0)
13:55:26:228 dev /dev/ttyS0 (/dev/ttyS0)
13:55:27:106 failed to reconnect to network try=3
13:55:27:107 Skip idle timer callback, too early: elapsed 942 msec
13:55:28:250 device state timeout ignored in state 2
13:55:28:410 device state timeout ignored in state 2
13:55:28:575 device state timeout ignored in state 2
13:55:28:734 device state timeout ignored in state 2
13:55:28:895 device state timeout ignored in state 2
13:55:29:054 device state timeout ignored in state 2
13:55:29:215 device state timeout ignored in state 2
13:55:29:374 device state timeout ignored in state 2
13:55:29:534 device state timeout ignored in state 2
13:55:29:694 device state timeout ignored in state 2
13:55:29:854 device state timeout ignored in state 2
13:55:30:014 device state timeout (handled)
13:55:30:018 device disconnected reason: 4, index: 0
13:55:30:094 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:55:30:095 device state timeout ignored in state 1
13:55:30:106 wait reconnect 15 seconds
13:55:31:106 wait reconnect 14 seconds
13:55:32:107 failed to reconnect to network try=4
13:55:32:108 wait reconnect 13 seconds
13:55:33:106 wait reconnect 12 seconds
13:55:34:106 wait reconnect 11 seconds
13:55:35:106 wait reconnect 10 seconds
13:55:36:107 wait reconnect 9 seconds
13:55:36:174 dev /dev/ttyS0 (/dev/ttyS0)
13:55:37:106 failed to reconnect to network try=5
13:55:37:107 wait reconnect 8 seconds
13:55:38:106 wait reconnect 7 seconds
13:55:39:106 wait reconnect 6 seconds
13:55:40:106 wait reconnect 5 seconds
13:55:41:106 wait reconnect 4 seconds
13:55:42:106 failed to reconnect to network try=6
13:55:42:107 wait reconnect 3 seconds
13:55:43:106 wait reconnect 2 seconds
13:55:44:106 wait reconnect 1 seconds
13:55:44:174 dev /dev/ttyS0 (/dev/ttyS0)
13:55:44:180 device disconnected reason: 4, index: 1
13:55:45:106 wait reconnect 15 seconds
13:55:45:163 dev /dev/ttyS0 (/dev/ttyS0)
13:55:46:106 wait reconnect 14 seconds
13:55:46:107 Skip idle timer callback, too early: elapsed 942 msec
13:55:46:167 dev /dev/ttyS0 (/dev/ttyS0)
13:55:47:106 failed to reconnect to network try=7
13:55:47:107 wait reconnect 13 seconds
13:55:48:106 wait reconnect 12 seconds
13:55:49:106 wait reconnect 11 seconds
13:55:50:106 wait reconnect 10 seconds
13:55:51:106 wait reconnect 9 seconds
13:55:52:106 failed to reconnect to network try=8
13:55:52:107 wait reconnect 8 seconds
13:55:53:107 wait reconnect 7 seconds
13:55:54:105 wait reconnect 6 seconds
13:55:55:106 wait reconnect 5 seconds
13:55:56:106 wait reconnect 4 seconds
13:55:56:164 dev /dev/ttyS0 (/dev/ttyS0)
13:55:57:106 failed to reconnect to network try=9
13:55:57:107 wait reconnect 3 seconds
13:55:58:106 wait reconnect 2 seconds
13:55:59:106 wait reconnect 1 seconds
13:55:59:170 dev /dev/ttyS0 (/dev/ttyS0)
13:56:00:106 Skip idle timer callback, too early: elapsed 934 msec
13:56:01:262 device state timeout ignored in state 2
13:56:01:422 device state timeout ignored in state 2
13:56:01:582 device state timeout ignored in state 2
13:56:01:742 device state timeout ignored in state 2
13:56:01:901 device state timeout ignored in state 2
13:56:02:062 device state timeout ignored in state 2
13:56:02:106 try to reconnect to network try=10
13:56:02:350 device state timeout ignored in state 2
13:56:02:510 device state timeout ignored in state 2
13:56:02:670 device state timeout ignored in state 2
13:56:02:830 device state timeout ignored in state 2
13:56:02:990 device state timeout ignored in state 2
13:56:03:150 device state timeout (handled)
13:56:03:154 device disconnected reason: 4, index: 0
13:56:03:230 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:56:03:231 device state timeout ignored in state 1
13:56:04:106 wait reconnect 15 seconds
13:56:05:106 wait reconnect 14 seconds
13:56:06:106 wait reconnect 13 seconds
13:56:06:163 dev /dev/ttyS0 (/dev/ttyS0)
13:56:07:106 reconnect network failed, try later
13:56:07:107 wait reconnect 12 seconds
13:56:07:107 start reconnect to network
13:56:08:106 wait reconnect 11 seconds
13:56:09:106 wait reconnect 10 seconds
13:56:10:106 wait reconnect 9 seconds
13:56:11:107 wait reconnect 8 seconds
13:56:12:106 failed to reconnect to network try=1
13:56:12:107 wait reconnect 7 seconds
13:56:13:107 wait reconnect 6 seconds
13:56:14:106 wait reconnect 5 seconds
13:56:15:106 wait reconnect 4 seconds
13:56:16:106 wait reconnect 3 seconds
13:56:16:177 dev /dev/ttyS0 (/dev/ttyS0)
13:56:17:106 failed to reconnect to network try=2
13:56:17:107 wait reconnect 2 seconds
13:56:18:106 wait reconnect 1 seconds
13:56:18:181 dev /dev/ttyS0 (/dev/ttyS0)
13:56:18:192 device disconnected reason: 4, index: 1
13:56:19:106 wait reconnect 15 seconds
13:56:19:184 dev /dev/ttyS0 (/dev/ttyS0)
13:56:20:106 wait reconnect 14 seconds
13:56:20:107 Skip idle timer callback, too early: elapsed 921 msec
13:56:21:106 wait reconnect 13 seconds
13:56:22:106 failed to reconnect to network try=3
13:56:22:107 wait reconnect 12 seconds
13:56:23:106 wait reconnect 11 seconds
13:56:24:106 wait reconnect 10 seconds
13:56:25:106 wait reconnect 9 seconds
13:56:26:106 wait reconnect 8 seconds
13:56:26:182 dev /dev/ttyS0 (/dev/ttyS0)
13:56:27:108 failed to reconnect to network try=4
13:56:27:108 wait reconnect 7 seconds
13:56:28:106 wait reconnect 6 seconds
13:56:29:106 wait reconnect 5 seconds
13:56:30:106 wait reconnect 4 seconds
13:56:31:107 wait reconnect 3 seconds
13:56:32:106 failed to reconnect to network try=5
13:56:32:107 wait reconnect 2 seconds
13:56:33:106 wait reconnect 1 seconds
13:56:33:183 dev /dev/ttyS0 (/dev/ttyS0)
13:56:34:106 Skip idle timer callback, too early: elapsed 921 msec
13:56:35:278 device state timeout ignored in state 2
13:56:35:438 device state timeout ignored in state 2
13:56:35:598 device state timeout ignored in state 2
13:56:35:758 device state timeout ignored in state 2
13:56:35:918 device state timeout ignored in state 2
13:56:36:078 device state timeout ignored in state 2
13:56:36:238 device state timeout ignored in state 2
13:56:36:398 device state timeout ignored in state 2
13:56:36:558 device state timeout ignored in state 2
13:56:36:718 device state timeout ignored in state 2
13:56:36:878 device state timeout ignored in state 2
13:56:37:038 device state timeout (handled)
13:56:37:041 device disconnected reason: 4, index: 0
13:56:37:106 failed to reconnect to network try=6
13:56:37:107 wait reconnect 15 seconds
13:56:37:117 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:56:37:118 device state timeout ignored in state 1
13:56:38:106 wait reconnect 14 seconds
13:56:39:106 wait reconnect 13 seconds
13:56:40:106 wait reconnect 12 seconds
13:56:41:106 wait reconnect 11 seconds
13:56:42:106 failed to reconnect to network try=7
13:56:42:107 wait reconnect 10 seconds
13:56:43:106 wait reconnect 9 seconds
13:56:44:106 wait reconnect 8 seconds
13:56:45:106 wait reconnect 7 seconds
13:56:46:106 wait reconnect 6 seconds
13:56:46:179 dev /dev/ttyS0 (/dev/ttyS0)
13:56:47:106 failed to reconnect to network try=8
13:56:47:106 wait reconnect 5 seconds
13:56:48:106 wait reconnect 4 seconds
13:56:49:106 wait reconnect 3 seconds
13:56:50:106 wait reconnect 2 seconds
13:56:51:106 wait reconnect 1 seconds
13:56:51:170 dev /dev/ttyS0 (/dev/ttyS0)
13:56:51:178 device disconnected reason: 4, index: 1
13:56:52:106 failed to reconnect to network try=9
13:56:52:107 wait reconnect 15 seconds
13:56:52:189 dev /dev/ttyS0 (/dev/ttyS0)
13:56:53:107 wait reconnect 14 seconds
13:56:53:108 Skip idle timer callback, too early: elapsed 917 msec
13:56:54:106 wait reconnect 13 seconds
13:56:55:106 wait reconnect 12 seconds
13:56:56:106 wait reconnect 11 seconds
13:56:56:172 dev /dev/ttyS0 (/dev/ttyS0)
13:56:57:106 failed to reconnect to network try=10
13:56:57:107 wait reconnect 10 seconds
13:56:58:107 wait reconnect 9 seconds
13:56:59:106 wait reconnect 8 seconds
13:57:00:106 wait reconnect 7 seconds
13:57:01:107 wait reconnect 6 seconds
13:57:02:106 reconnect network failed, try later
13:57:02:106 wait reconnect 5 seconds
13:57:02:107 start reconnect to network
13:57:03:106 wait reconnect 4 seconds
13:57:04:106 wait reconnect 3 seconds
13:57:05:106 wait reconnect 2 seconds
13:57:06:106 wait reconnect 1 seconds
13:57:06:190 dev /dev/ttyS0 (/dev/ttyS0)
13:57:06:260 dev /dev/ttyS0 (/dev/ttyS0)
13:57:07:106 failed to reconnect to network try=1
13:57:07:107 Skip idle timer callback, too early: elapsed 914 msec
13:57:08:286 device state timeout ignored in state 2
13:57:08:446 device state timeout ignored in state 2
13:57:08:607 device state timeout ignored in state 2
13:57:08:766 device state timeout ignored in state 2
13:57:08:926 device state timeout ignored in state 2
13:57:09:086 device state timeout ignored in state 2
13:57:09:246 device state timeout ignored in state 2
13:57:09:407 device state timeout ignored in state 2
13:57:09:566 device state timeout ignored in state 2
13:57:09:726 device state timeout ignored in state 2
13:57:09:886 device state timeout ignored in state 2
13:57:10:046 device state timeout (handled)
13:57:10:050 device disconnected reason: 4, index: 0
13:57:10:106 wait reconnect 15 seconds
13:57:10:126 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:57:10:126 device state timeout ignored in state 1
13:57:11:108 wait reconnect 14 seconds
13:57:12:106 failed to reconnect to network try=2
13:57:12:106 wait reconnect 13 seconds
13:57:13:107 wait reconnect 12 seconds
13:57:14:106 wait reconnect 11 seconds
13:57:15:107 wait reconnect 10 seconds
13:57:16:106 wait reconnect 9 seconds
13:57:16:162 dev /dev/ttyS0 (/dev/ttyS0)
13:57:17:107 failed to reconnect to network try=3
13:57:17:107 wait reconnect 8 seconds
13:57:18:106 wait reconnect 7 seconds
13:57:19:106 wait reconnect 6 seconds
13:57:20:106 wait reconnect 5 seconds
13:57:21:106 wait reconnect 4 seconds
13:57:22:106 failed to reconnect to network try=4
13:57:22:107 wait reconnect 3 seconds
13:57:23:107 wait reconnect 2 seconds
13:57:24:106 wait reconnect 1 seconds
13:57:24:179 dev /dev/ttyS0 (/dev/ttyS0)
13:57:24:185 device disconnected reason: 4, index: 1
13:57:25:106 wait reconnect 15 seconds
13:57:25:174 dev /dev/ttyS0 (/dev/ttyS0)
13:57:26:106 wait reconnect 14 seconds
13:57:26:107 Skip idle timer callback, too early: elapsed 931 msec
13:57:26:163 dev /dev/ttyS0 (/dev/ttyS0)
13:57:27:108 failed to reconnect to network try=5
13:57:27:109 wait reconnect 13 seconds
13:57:28:106 wait reconnect 12 seconds
13:57:29:107 wait reconnect 11 seconds
13:57:30:106 wait reconnect 10 seconds
13:57:31:106 wait reconnect 9 seconds
13:57:32:106 failed to reconnect to network try=6
13:57:32:108 wait reconnect 8 seconds
13:57:33:107 wait reconnect 7 seconds
13:57:34:106 wait reconnect 6 seconds
13:57:35:106 wait reconnect 5 seconds
13:57:36:106 wait reconnect 4 seconds
13:57:36:162 dev /dev/ttyS0 (/dev/ttyS0)
13:57:37:106 failed to reconnect to network try=7
13:57:37:107 wait reconnect 3 seconds
13:57:38:106 wait reconnect 2 seconds
13:57:39:107 wait reconnect 1 seconds
13:57:39:182 dev /dev/ttyS0 (/dev/ttyS0)
13:57:40:106 Skip idle timer callback, too early: elapsed 923 msec
13:57:41:286 device state timeout ignored in state 2
13:57:41:446 device state timeout ignored in state 2
13:57:41:606 device state timeout ignored in state 2
13:57:41:767 device state timeout ignored in state 2
13:57:41:926 device state timeout ignored in state 2
13:57:42:086 device state timeout ignored in state 2
13:57:42:106 try to reconnect to network try=8
13:57:42:350 device state timeout ignored in state 2
13:57:42:510 device state timeout ignored in state 2
13:57:42:670 device state timeout ignored in state 2
13:57:42:830 device state timeout ignored in state 2
13:57:42:990 device state timeout ignored in state 2
13:57:43:150 device state timeout (handled)
13:57:43:156 device disconnected reason: 4, index: 0
13:57:43:229 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
13:57:43:230 device state timeout ignored in state 1
13:57:44:106 wait reconnect 15 seconds
13:57:45:105 wait reconnect 14 seconds
13:57:46:106 wait reconnect 13 seconds
13:57:46:165 dev /dev/ttyS0 (/dev/ttyS0)
13:57:47:106 failed to reconnect to network try=9
13:57:47:107 wait reconnect 12 seconds
13:57:48:106 wait reconnect 11 seconds
13:57:49:106 wait reconnect 10 seconds
13:57:50:106 wait reconnect 9 seconds
13:57:51:106 wait reconnect 8 seconds
13:57:52:106 failed to reconnect to network try=10
13:57:52:106 wait reconnect 7 seconds
13:57:53:107 wait reconnect 6 seconds
13:57:54:106 wait reconnect 5 seconds
13:57:55:106 wait reconnect 4 seconds
13:57:56:106 wait reconnect 3 seconds
13:57:56:189 dev /dev/ttyS0 (/dev/ttyS0)
13:57:57:106 reconnect network failed, try later
13:57:57:107 wait reconnect 2 seconds
13:57:57:108 start reconnect to network
13:57:58:106 wait reconnect 1 seconds
13:57:58:180 dev /dev/ttyS0 (/dev/ttyS0)
13:57:58:191 device disconnected reason: 4, index: 1
13:57:59:106 wait reconnect 15 seconds
13:57:59:174 dev /dev/ttyS0 (/dev/ttyS0)
13:58:00:106 wait reconnect 14 seconds
13:58:00:107 Skip idle timer callback, too early: elapsed 931 msec
13:58:01:106 wait reconnect 13 seconds
13:58:02:106 failed to reconnect to network try=1
13:58:02:107 wait reconnect 12 seconds
13:58:03:106 wait reconnect 11 seconds
13:58:04:107 wait reconnect 10 seconds
13:58:05:106 wait reconnect 9 seconds
13:58:06:106 wait reconnect 8 seconds
13:58:06:163 dev /dev/ttyS0 (/dev/ttyS0)
13:58:07:106 failed to reconnect to network try=2
13:58:07:107 wait reconnect 7 seconds
13:58:08:106 wait reconnect 6 seconds
13:58:09:107 wait reconnect 5 seconds
13:58:10:106 wait reconnect 4 seconds
13:58:11:106 wait reconnect 3 seconds
13:58:12:106 failed to reconnect to network try=3
13:58:12:107 wait reconnect 2 seconds
13:58:13:107 wait reconnect 1 seconds
