pi@raspberrypi:~ $ sudo systemctl restart homebridge; sudo journalctl -fau homebridge
-- Logs begin at Mon 2020-01-13 19:17:01 CET. --
Jan 13 19:21:32 raspberrypi homebridge[1320]: [1/13/2020, 19:21:32] Registering platform 'homebridge-platform-blink-security.BlinkSecurityPlatform'
Jan 13 19:21:32 raspberrypi homebridge[1320]: [1/13/2020, 19:21:32] ---
Jan 13 19:21:32 raspberrypi homebridge[1320]: [1/13/2020, 19:21:32] Loaded plugin: homebridge-config-ui-x
Jan 13 19:21:32 raspberrypi homebridge[1320]: [1/13/2020, 19:21:32] Registering platform 'homebridge-config-ui-x.config'
Jan 13 19:21:32 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Jan 13 19:21:32 raspberrypi systemd[1]: homebridge.service: Main process exited, code=killed, status=15/TERM
Jan 13 19:21:32 raspberrypi systemd[1]: homebridge.service: Succeeded.
Jan 13 19:21:32 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 13 19:21:32 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 13 19:21:34 raspberrypi homebridge[1347]: [1/13/2020, 19:21:34] Loaded config.json with 2 accessories and 1 platforms.
Jan 13 19:21:34 raspberrypi homebridge[1347]: [1/13/2020, 19:21:34] ---
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Loaded plugin: homebridge-blinkcameras
Jan 13 19:21:35 raspberrypi homebridge[1347]: homebridge API version: 2.4
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Registering platform 'homebridge-platform-blink-security.BlinkSecurityPlatform'
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] ---
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Loaded plugin: homebridge-config-ui-x
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Registering platform 'homebridge-config-ui-x.config'
Jan 13 19:21:35 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:35] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] ---
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] Loading 1 platforms...
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] [Config] Initializing config platform...
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] [Config] Spawning homebridge-config-ui-x with PID 1376
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] Loading 2 accessories...
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] [Xiaomi Mi Robot Vaccum 1st Generation] Initializing XiaomiRoborockVacuum accessory...
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] Error: The requested accessory 'BlinkCameras' was not registered by any plugin.
Jan 13 19:21:36 raspberrypi homebridge[1347]: at API.accessory (/usr/local/lib/node_modules/homebridge/lib/api.js:64:13)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:297:42)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:91:38)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Module._compile (internal/modules/cjs/loader.js:955:30)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Module.load (internal/modules/cjs/loader.js:811:32)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
Jan 13 19:21:36 raspberrypi homebridge[1347]: at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
Jan 13 19:21:36 raspberrypi homebridge[1347]: [1/13/2020, 19:21:36] Got SIGTERM, shutting down Homebridge...
Jan 13 19:21:41 raspberrypi homebridge[1347]: [1/13/2020, 19:21:41] [Config] Homebridge Config UI X v4.7.0 is listening on :: port 8080
Jan 13 19:21:41 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 13 19:21:41 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 13 19:21:51 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jan 13 19:21:51 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 1.
Jan 13 19:21:51 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 13 19:21:51 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 13 19:21:53 raspberrypi homebridge[1416]: [1/13/2020, 19:21:53] Loaded config.json with 2 accessories and 1 platforms.
Jan 13 19:21:53 raspberrypi homebridge[1416]: [1/13/2020, 19:21:53] ---
Jan 13 19:21:53 raspberrypi homebridge[1416]: [1/13/2020, 19:21:53] Loaded plugin: homebridge-blinkcameras
Jan 13 19:21:53 raspberrypi homebridge[1416]: homebridge API version: 2.4
Jan 13 19:21:53 raspberrypi homebridge[1416]: [1/13/2020, 19:21:53] Registering platform 'homebridge-platform-blink-security.BlinkSecurityPlatform'
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Loaded plugin: homebridge-config-ui-x
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Registering platform 'homebridge-config-ui-x.config'
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] ---
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Loading 1 platforms...
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] [Config] Initializing config platform...
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] [Config] Spawning homebridge-config-ui-x with PID 1436
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Loading 2 accessories...
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] [Xiaomi Mi Robot Vaccum 1st Generation] Initializing XiaomiRoborockVacuum accessory...
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Error: The requested accessory 'BlinkCameras' was not registered by any plugin.
Jan 13 19:21:54 raspberrypi homebridge[1416]: at API.accessory (/usr/local/lib/node_modules/homebridge/lib/api.js:64:13)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:297:42)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:91:38)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Module._compile (internal/modules/cjs/loader.js:955:30)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Module.load (internal/modules/cjs/loader.js:811:32)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
Jan 13 19:21:54 raspberrypi homebridge[1416]: at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
Jan 13 19:21:54 raspberrypi homebridge[1416]: [1/13/2020, 19:21:54] Got SIGTERM, shutting down Homebridge...
Jan 13 19:21:59 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 13 19:21:59 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 13 19:21:59 raspberrypi homebridge[1416]: [1/13/2020, 19:21:59] [Config] Homebridge Config UI X v4.7.0 is listening on :: port 8080
Jan 13 19:22:09 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jan 13 19:22:09 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 2.
Jan 13 19:22:09 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 13 19:22:09 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 13 19:22:11 raspberrypi homebridge[1460]: [1/13/2020, 19:22:11] Loaded config.json with 2 accessories and 1 platforms.
Jan 13 19:22:11 raspberrypi homebridge[1460]: [1/13/2020, 19:22:11] ---
Jan 13 19:22:12 raspberrypi homebridge[1460]: [1/13/2020, 19:22:12] Loaded plugin: homebridge-blinkcameras
Jan 13 19:22:12 raspberrypi homebridge[1460]: homebridge API version: 2.4
Jan 13 19:22:12 raspberrypi homebridge[1460]: [1/13/2020, 19:22:12] Registering platform 'homebridge-platform-blink-security.BlinkSecurityPlatform'
Jan 13 19:22:12 raspberrypi homebridge[1460]: [1/13/2020, 19:22:12] ---
Jan 13 19:22:12 raspberrypi homebridge[1460]: [1/13/2020, 19:22:12] Loaded plugin: homebridge-config-ui-x
Jan 13 19:22:12 raspberrypi homebridge[1460]: [1/13/2020, 19:22:12] Registering platform 'homebridge-config-ui-x.config'
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] ---
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Loading 1 platforms...
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] [Config] Initializing config platform...
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] [Config] Spawning homebridge-config-ui-x with PID 1480
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Loading 2 accessories...
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] [Xiaomi Mi Robot Vaccum 1st Generation] Initializing XiaomiRoborockVacuum accessory...
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Error: The requested accessory 'BlinkCameras' was not registered by any plugin.
Jan 13 19:22:13 raspberrypi homebridge[1460]: at API.accessory (/usr/local/lib/node_modules/homebridge/lib/api.js:64:13)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:297:42)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:91:38)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Module._compile (internal/modules/cjs/loader.js:955:30)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Module.load (internal/modules/cjs/loader.js:811:32)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
Jan 13 19:22:13 raspberrypi homebridge[1460]: at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
Jan 13 19:22:13 raspberrypi homebridge[1460]: [1/13/2020, 19:22:13] Got SIGTERM, shutting down Homebridge...
Jan 13 19:22:18 raspberrypi homebridge[1460]: [1/13/2020, 19:22:18] [Config] Homebridge Config UI X v4.7.0 is listening on :: port 8080
Jan 13 19:22:18 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 13 19:22:18 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 13 19:22:28 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jan 13 19:22:28 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 3.
Jan 13 19:22:28 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 13 19:22:28 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 13 19:22:30 raspberrypi homebridge[1520]: [1/13/2020, 19:22:30] Loaded config.json with 2 accessories and 1 platforms.
Jan 13 19:22:30 raspberrypi homebridge[1520]: [1/13/2020, 19:22:30] ---
Jan 13 19:22:30 raspberrypi homebridge[1520]: [1/13/2020, 19:22:30] Loaded plugin: homebridge-blinkcameras
Jan 13 19:22:30 raspberrypi homebridge[1520]: homebridge API version: 2.4
Jan 13 19:22:30 raspberrypi homebridge[1520]: [1/13/2020, 19:22:30] Registering platform 'homebridge-platform-blink-security.BlinkSecurityPlatform'
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Loaded plugin: homebridge-config-ui-x
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Registering platform 'homebridge-config-ui-x.config'
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] ---
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Loading 1 platforms...
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] [Config] Initializing config platform...
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] [Config] Spawning homebridge-config-ui-x with PID 1540
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Loading 2 accessories...
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] [Xiaomi Mi Robot Vaccum 1st Generation] Initializing XiaomiRoborockVacuum accessory...
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Error: The requested accessory 'BlinkCameras' was not registered by any plugin.
Jan 13 19:22:31 raspberrypi homebridge[1520]: at API.accessory (/usr/local/lib/node_modules/homebridge/lib/api.js:64:13)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:297:42)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:91:38)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Module._compile (internal/modules/cjs/loader.js:955:30)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Module.load (internal/modules/cjs/loader.js:811:32)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
Jan 13 19:22:31 raspberrypi homebridge[1520]: at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
Jan 13 19:22:31 raspberrypi homebridge[1520]: [1/13/2020, 19:22:31] Got SIGTERM, shutting down Homebridge...
Jan 13 19:22:36 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 13 19:22:36 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
