at bootstrap_node.js:666:3
at startup (bootstrap_node.js:194:16)
at Function.Module.runMain (module.js:690:10)
at Function.Module._load (module.js:493:3)
at tryModuleLoad (module.js:501:12)
at Module.load (module.js:561:32)
at Object.Module._extensions..js (module.js:660:10)
at Module._compile (module.js:649:30)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:45:10)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:86:36)
at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:316:45)
at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13)
Error: The requested platform 'Lightify API' was not registered by any plugin.
throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
[2019-1-22 23:28:15] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:26:46] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:18:59] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:12:30] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:11:40] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:11:21] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 23:04:47] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 22:59:35] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
[2019-1-22 22:58:32] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:67:26)
Error: getaddrinfo ENOTFOUND eu.lightify-api.org eu.lightify-api.org:443
_currentUrl: 'https://eu.lightify-api.org/lightify/services/session?' } }
[Symbol(outHeadersKey)]: [Object] },
[Symbol(isCorked)]: false,
_redirectable: [Circular],
maxHeadersCount: null,
parser: [HTTPParser],
upgradeOrConnect: false,
timeoutCb: null,
aborted: undefined,
res: null,
_ended: false,
path: '/lightify/services/session?',
method: 'POST',
timeout: undefined,
socketPath: undefined,
agent: [Agent],
_onPendingData: [Function: noopPendingOutput],
_header: 'POST /lightify/services/session? HTTP/1.1\r\nContent-Type: application/json\r\nContent-Length: 84\r\nHost: eu.lightify-api.org\r\nConnection: close\r\n\r\n',
connection: [TLSSocket],
socket: [TLSSocket],
_headerSent: true,
finished: true,
_trailer: '',
_hasBody: true,
_contentLength: null,
_removedTE: false,
_removedContLen: false,
_removedConnection: false,
sendDate: false,
useChunkedEncodingByDefault: true,
shouldKeepAlive: false,
chunkedEncoding: false,
upgrading: false,
_last: true,
writable: true,
outputSize: 0,
outputCallbacks: [],
outputEncodings: [],
output: [],
_maxListeners: undefined,
_eventsCount: 6,
_events: [Object],
ClientRequest {
_currentRequest:
_onNativeResponse: [Function],
_requestBodyBuffers: [ [Object] ],
_requestBodyLength: 84,
_redirects: [],
_redirectCount: 0,
_ending: true,
_ended: true,
search: '?' },
pathname: '/lightify/services/session',
hostname: 'eu.lightify-api.org',
nativeProtocols: [Object],
data: [Object],
headers: [Object],
method: 'POST',
href: 'https://eu.lightify-api.org/lightify/services/session?',
port: null,
protocol: 'https:',
maxBodyLength: 10485760,
{ maxRedirects: 21,
_options:
_eventsCount: 2,
_events: { response: [Function], error: [Function] },
writable: true,
corkedRequestsFree: [Object] },
bufferedRequestCount: 0,
errorEmitted: false,
prefinished: false,
pendingcb: 0,
lastBufferedRequest: null,
bufferedRequest: null,
writelen: 0,
writecb: null,
onwrite: [Function: bound onwrite],
bufferProcessing: false,
sync: true,
corked: 0,
writing: false,
length: 0,
defaultEncoding: 'utf8',
decodeStrings: true,
destroyed: false,
finished: false,
ended: false,
ending: false,
needDrain: false,
finalCalled: false,
highWaterMark: 16384,
objectMode: false,
WritableState {
_writableState:
Writable {
_httpRequest:
serialNumber: 'OSR017C2E12' } },
password: 'XXX',
{ username: 'XXX',
data:
headers: { 'Content-Type': 'application/json', 'Content-Length': 84 },
method: 'POST',
port: null,
{ host: 'eu.lightify-api.org',
options:
_eventsCount: 0,
_events: {},
Tue, 22 Jan 2019 21:56:44 GMT NRC 22:56:44 [NRC CLIENT] -> request error ClientRequest {
[2019-1-22 22:56:44] [homebridge-harmonyhub.HarmonyHub] Ignoring Harmony Platform setup because it is not configured
password: 'XXX',
Tue, 22 Jan 2019 21:56:44 GMT NRC 22:56:44 [NRC CLIENT] -> options data { username: 'XXX',
serialNumber: 'OSR017C2E12' } } }
password: 'XXX',
{ username: 'XXX',
data:
method: 'POST',
port: null,
options:
_eventsCount: 0,
_events: {},
Tue, 22 Jan 2019 21:56:44 GMT NRC 22:56:44 [NRC CLIENT] -> clientRequest ClientRequest {
request: [Function: request] } } }
get: [Function: get],
createServer: [Function: createServer],
Server: [Function],
globalAgent: [Agent],
{ Agent: [Function],
'https:':
request: [Function: request] },
ServerResponse: [Function],
Server: [Function],
OutgoingMessage: [Function],
IncomingMessage: [Function],
ClientRequest: [Function],
Agent: [Function],
STATUS_CODES: [Object],
METHODS: [Array],
{ _connectionListener: [Function: connectionListener],
{ 'http:':
nativeProtocols:
serialNumber: 'OSR017C2E12' },
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
protocol: 'https:',
2019-01-22T21:56:34.609Z follow-redirects options { maxRedirects: 21,
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT] -> options pre connect { host: 'eu.lightify-api.org',
addCustomHttpMethod: [Function] }
unregisterMethod: [Function],
patch: [Function],
delete: [Function],
put: [Function],
post: [Function],
get: [Function],
methods: {},
responseConfig: {},
requestConfig: {},
mimetypes: {},
connection: {},
proxy: undefined,
useProxyTunnel: false,
useProxy: false,
options: {},
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]connect -> FINAL SELF object ====> EventEmitter {
password: 'xxx',
{ username: 'xxx',
data:
href: 'https://eu.lightify-api.org/lightify/services/session?' },
_eventsCount: 0,
_events: {},
ClientRequest {
clientRequest:
method: 'POST',
responseConfig: {},
requestConfig: {},
protocol: 'https',
port: null,
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]connect -> options post connect { host: 'eu.lightify-api.org',
password: 'xxx',
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]connect -> args.data = { username: 'xxx',
headers: { 'Content-Type': 'application/json' } }
password: 'xxx',
{ username: 'xxx',
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]connect -> args = { data:
responseConfig: {} }
requestConfig: {},
protocol: 'https',
port: null,
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]connect -> options pre connect { host: 'eu.lightify-api.org',
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT]createConnectOptions -> connect URL = https://eu.lightify-api.org/lightify/services/session?
Tue, 22 Jan 2019 21:56:34 GMT LightifyPlugin https://eu.lightify-api.org/lightify/services/session?
_eventsCount: 1 }
_events: { error: [Function] },
normal: [Function],
proxy: [Function],
prepareData: [Function],
handleResponse: [Function],
handleEnd: [Function],
configureResponse: [Function],
configureRequest: [Function],
isValidData: [Function],
isJSON: [Function],
isXML: [Function],
jsonctype: [ 'application/json', 'application/json;charset=utf-8' ],
'text/xml;charset=utf-8' ],
'text/xml',
'application/xml;charset=utf-8',
[ 'application/xml',
xmlctype:
Tue, 22 Jan 2019 21:56:34 GMT NRC 22:56:34 [NRC CLIENT] -> ConnectManager ConnectManager {
[2019-1-22 22:56:26] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
timeoutCb: null,
aborted: undefined,
res: null,
_ended: false,
method: 'POST',
timeout: undefined,
agent: [Agent],
_headerSent: true,
finished: true,
_trailer: '',
_hasBody: true,
_removedTE: false,
sendDate: false,
upgrading: false,
_last: true,
writable: true,
outputSize: 0,
output: [],
_eventsCount: 6,
_events: [Object],
ClientRequest {
_currentRequest:
_redirects: [],
_redirectCount: 0,
_ending: true,
_ended: true,
search: '?' },
data: [Object],
headers: [Object],
method: 'POST',
port: null,
protocol: 'https:',
{ maxRedirects: 21,
_options:
_eventsCount: 2,
writable: true,
prefinished: false,
pendingcb: 0,
writelen: 0,
writecb: null,
sync: true,
corked: 0,
writing: false,
length: 0,
destroyed: false,
finished: false,
ended: false,
ending: false,
needDrain: false,
finalCalled: false,
objectMode: false,
WritableState {
_writableState:
Writable {
_httpRequest:
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
options:
_eventsCount: 0,
_events: {},
Tue, 22 Jan 2019 21:55:00 GMT NRC 22:55:0 [NRC CLIENT] -> request error ClientRequest {
[2019-1-22 22:55:00] [homebridge-harmonyhub.HarmonyHub] Ignoring Harmony Platform setup because it is not configured
password: 'xxx',
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT] -> options data { username: 'xxx',
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
options:
_eventsCount: 0,
_events: {},
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT] -> clientRequest ClientRequest {
Server: [Function],
'https:':
Server: [Function],
Agent: [Function],
METHODS: [Array],
{ 'http:':
nativeProtocols:
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
protocol: 'https:',
2019-01-22T21:54:59.732Z follow-redirects options { maxRedirects: 21,
password: 'xxx',
{ username: 'xxx',
data:
method: 'POST',
port: null,
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT] -> options pre connect { host: 'eu.lightify-api.org',
patch: [Function],
delete: [Function],
put: [Function],
post: [Function],
get: [Function],
methods: {},
responseConfig: {},
requestConfig: {},
mimetypes: {},
connection: {},
proxy: undefined,
useProxy: false,
options: {},
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]connect -> FINAL SELF object ====> EventEmitter {
password: 'xxx',
{ username: 'xxx',
data:
_eventsCount: 0,
_events: {},
ClientRequest {
clientRequest:
method: 'POST',
responseConfig: {},
requestConfig: {},
protocol: 'https',
port: null,
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]connect -> options post connect { host: 'eu.lightify-api.org',
password: 'xxx',
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]connect -> args.data = { username: 'xxx',
password: 'xxx',
{ username: 'xxx',
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]connect -> args = { data:
requestConfig: {},
protocol: 'https',
port: null,
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]connect -> options pre connect { host: 'eu.lightify-api.org',
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT]createConnectOptions -> connect URL = https://eu.lightify-api.org/lightify/services/session?
Tue, 22 Jan 2019 21:54:59 GMT LightifyPlugin https://eu.lightify-api.org/lightify/services/session?
_eventsCount: 1 }
normal: [Function],
proxy: [Function],
isJSON: [Function],
isXML: [Function],
'text/xml',
xmlctype:
Tue, 22 Jan 2019 21:54:59 GMT NRC 22:54:59 [NRC CLIENT] -> ConnectManager ConnectManager {
[2019-1-22 22:54:43] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v9.9.0. You may need to upgrade your installation of Node.
timeoutCb: null,
aborted: undefined,
res: null,
_ended: false,
method: 'POST',
timeout: undefined,
agent: [Agent],
_headerSent: true,
finished: true,
_trailer: '',
_hasBody: true,
_removedTE: false,
sendDate: false,
upgrading: false,
_last: true,
writable: true,
outputSize: 0,
output: [],
_eventsCount: 6,
_events: [Object],
ClientRequest {
