Beiträge von pillemats
    hallo zusammen
    ich habe gerade im webvif ein paar plugins deinstalliert und nun startet Nichte mehr :(
    root@HPX312 ~ > sudo systemctl restart homebridge; sudo journalctl -fau homebridge
    -- Logs begin at Sat 2019-01-26 00:49:06 CET. --
    Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
    Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
    Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
    Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] Loading 1 accessories...
    Jan 26 00:55:20 HPX312 homebridge[8351]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
    Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
    Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
    Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Jan 26 00:55:21 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
    Jan 26 00:55:21 HPX312 systemd[1]: Started Node.js HomeKit Server.
    Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded config.json with 1 accessories and 2 platforms.
    Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] ---
    Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded plugin: homebridge-config-ui-x
    Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Registering platform 'homebridge-config-ui-x.config'
    Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded plugin: homebridge-harmonyhub
    Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] Registering platform 'homebridge-harmonyhub.HarmonyHub'
    Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] ---
    Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
    Jan 26 00:55:26 HPX312 homebridge[8523]: [2019-1-26 00:55:26] Loaded plugin: homebridge-hue
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Registering platform 'homebridge-hue.Hue'
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] ---
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Loading 2 platforms...
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Config] Initializing config platform...
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Config] Spawning homebridge-config-ui-x with PID 8592
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] Initializing Hue platform...
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
    Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Loading 1 accessories...
    Jan 26 00:55:27 HPX312 homebridge[8523]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
    Jan 26 00:55:27 HPX312 homebridge[8523]: throw new Error("The requested accessory '" + name + "' was not registered by any plugin.");
    Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
    Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
    Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Jan 26 00:55:37 HPX312 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
    Jan 26 00:55:37 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
    Jan 26 00:55:37 HPX312 systemd[1]: Started Node.js HomeKit Server.
    Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded config.json with 1 accessories and 2 platforms.
    Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] ---
    Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded plugin: homebridge-config-ui-x
    Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Registering platform 'homebridge-config-ui-x.config'
    Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded plugin: homebridge-harmonyhub
    Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] Registering platform 'homebridge-harmonyhub.HarmonyHub'
    Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] ---
    Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loaded plugin: homebridge-hue
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Registering platform 'homebridge-hue.Hue'
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] ---
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loading 2 platforms...
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Config] Initializing config platform...
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Config] Spawning homebridge-config-ui-x with PID 8866
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] Initializing Hue platform...
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
    Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loading 1 accessories...
    Jan 26 00:55:42 HPX312 homebridge[8742]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
    Jan 26 00:55:42 HPX312 homebridge[8742]: throw new Error("The requested accessory '" + name + "' was not registered by any plugin.");
    Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
    Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
    Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Jan 26 00:55:53 HPX312 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
    Jan 26 00:55:53 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
    Jan 26 00:55:53 HPX312 systemd[1]: Started Node.js HomeKit Server.
    Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded config.json with 1 accessories and 2 platforms.
    Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] ---
    Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded plugin: homebridge-config-ui-x
    Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Registering platform 'homebridge-config-ui-x.config'
    Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded plugin: homebridge-harmonyhub
    Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] Registering platform 'homebridge-harmonyhub.HarmonyHub'
    Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] ---
    Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Loaded plugin: homebridge-hue
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Registering platform 'homebridge-hue.Hue'
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] ---
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Loading 2 platforms...
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Config] Initializing config platform...
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Config] Spawning homebridge-config-ui-x with PID 9083
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] Initializing Hue platform...
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
    Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
    hier meine config
    "accessories": [{
    "name": "Test lamp",
    "accessory": "FakeBulb",
    "bulb_name": "Lamp1"
    "bridge": {
    "name": "Homebridge",
    "pin": "031-45-154",
    "port": 51826
    "platforms": [{
    "port": 8888,
    "sudo": true,
    "platform": "config",
    "theme": "red",
    "auth": "form",
    "log": {
    "service": "homebridge",
    "method": "systemd"
    "name": "Config"
    "sensors": true,
    "users": {
    "xx": "xx"
    "platform": "Hue",
    "name": "Phillips Hue",
    "lights": true
    normal müsste alles richtig sein aber es geht nicht
    hoffentlich kann mir jemand helfen
    Hallo zusammen
    ich habe mir heute auf meinem Sever (Debian 9) Homebridge eingerichtet. In erster Linie nur, weil ich meine Osram Plugs mit HomeKit und meiner Hue Bridge steuern möchte.
    das hat auch alles soweit gut geklappt. allerdings verlangt er jedes mal nach dem Neustart, das ich bei der hue bridge die taste drücke und das nervt wie sau :D
    hier mal der log
    Jan 25 23:48:26 HPX312 homebridge[6741]: [2019-1-25 23:48:26] [Phillips Hue] Philips hue: bridge request 18: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:48:26 HPX312 homebridge[6741]: [2019-1-25 23:48:26] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:48:26 HPX312 homebridge[6741]: [2019-1-25 23:48:26] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:48:41 HPX312 homebridge[6741]: [2019-1-25 23:48:41] [Phillips Hue] Philips hue: bridge request 19: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:48:41 HPX312 homebridge[6741]: [2019-1-25 23:48:41] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:48:41 HPX312 homebridge[6741]: [2019-1-25 23:48:41] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:48:56 HPX312 homebridge[6741]: [2019-1-25 23:48:56] [Phillips Hue] Philips hue: bridge request 20: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:48:56 HPX312 homebridge[6741]: [2019-1-25 23:48:56] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:48:56 HPX312 homebridge[6741]: [2019-1-25 23:48:56] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:49:11 HPX312 homebridge[6741]: [2019-1-25 23:49:11] [Phillips Hue] Philips hue: bridge request 21: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:49:11 HPX312 homebridge[6741]: [2019-1-25 23:49:11] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:49:11 HPX312 homebridge[6741]: [2019-1-25 23:49:11] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:49:26 HPX312 homebridge[6741]: [2019-1-25 23:49:26] [Phillips Hue] Philips hue: bridge request 22: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:49:26 HPX312 homebridge[6741]: [2019-1-25 23:49:26] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:49:26 HPX312 homebridge[6741]: [2019-1-25 23:49:26] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:49:41 HPX312 homebridge[6741]: [2019-1-25 23:49:41] [Phillips Hue] Philips hue: bridge request 23: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:49:41 HPX312 homebridge[6741]: [2019-1-25 23:49:41] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:49:41 HPX312 homebridge[6741]: [2019-1-25 23:49:41] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    Jan 25 23:49:56 HPX312 homebridge[6741]: [2019-1-25 23:49:56] [Phillips Hue] Philips hue: bridge request 24: post / {"devicetype":"homebridge-hue#HPX312"}
    Jan 25 23:49:56 HPX312 homebridge[6741]: [2019-1-25 23:49:56] [Phillips Hue] Philips hue: bridge error 101: link button not pressed
    Jan 25 23:49:56 HPX312 homebridge[6741]: [2019-1-25 23:49:56] [Phillips Hue] Philips hue: press link button on the bridge to create a user
    und hier meine config:
    "accessories": [
    "bridge": {
    "port": 51826
    "platforms": [
    "port": 8888,
    "sudo": true,
    "theme": "red",
    "auth": "form",
    "log": {
    "method": "systemd"
    "name": "Config"
    "sensors": true,
    "users": {},
    "platform": "Hue",
    "lights": true
    was genau muss sich einstellen damit das nicht mehr passiert ?
    des Weiteren habe ich noch ein paar sehr interessante plugins gesehen und auch bereits installiert:
    homebridge-fritz v0.7.5
    homebridge-harmonyhub v0.3.0-alpha.2
    homebridge-soundtouch v5.3.1
    aktuell habe ich noch etwas angst etwas falsch zu machen und damit die config oder selbst die Homebridge zu versauen.....
    gibt es dazu auch Anleitungen ?
    danke euch
