hallo zusammen
ich habe gerade im webvif ein paar plugins deinstalliert und nun startet Nichte mehr ![]()
root@HPX312 ~ > sudo systemctl restart homebridge; sudo journalctl -fau homebridge
-- Logs begin at Sat 2019-01-26 00:49:06 CET. --
Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
Jan 26 00:55:20 HPX312 homebridge[8351]: [2019-1-26 00:55:20] Loading 1 accessories...
Jan 26 00:55:20 HPX312 homebridge[8351]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
Jan 26 00:55:20 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 26 00:55:21 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
Jan 26 00:55:21 HPX312 systemd[1]: Started Node.js HomeKit Server.
Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded config.json with 1 accessories and 2 platforms.
Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] ---
Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded plugin: homebridge-config-ui-x
Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Registering platform 'homebridge-config-ui-x.config'
Jan 26 00:55:24 HPX312 homebridge[8523]: [2019-1-26 00:55:24] Loaded plugin: homebridge-harmonyhub
Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] Registering platform 'homebridge-harmonyhub.HarmonyHub'
Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] ---
Jan 26 00:55:25 HPX312 homebridge[8523]: [2019-1-26 00:55:25] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
Jan 26 00:55:26 HPX312 homebridge[8523]: [2019-1-26 00:55:26] Loaded plugin: homebridge-hue
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Registering platform 'homebridge-hue.Hue'
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] ---
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Loading 2 platforms...
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Config] Initializing config platform...
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Config] Spawning homebridge-config-ui-x with PID 8592
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] Initializing Hue platform...
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
Jan 26 00:55:27 HPX312 homebridge[8523]: [2019-1-26 00:55:27] Loading 1 accessories...
Jan 26 00:55:27 HPX312 homebridge[8523]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
Jan 26 00:55:27 HPX312 homebridge[8523]: throw new Error("The requested accessory '" + name + "' was not registered by any plugin.");
Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
Jan 26 00:55:27 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 26 00:55:37 HPX312 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Jan 26 00:55:37 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
Jan 26 00:55:37 HPX312 systemd[1]: Started Node.js HomeKit Server.
Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded config.json with 1 accessories and 2 platforms.
Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] ---
Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded plugin: homebridge-config-ui-x
Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Registering platform 'homebridge-config-ui-x.config'
Jan 26 00:55:39 HPX312 homebridge[8742]: [2019-1-26 00:55:39] Loaded plugin: homebridge-harmonyhub
Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] Registering platform 'homebridge-harmonyhub.HarmonyHub'
Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] ---
Jan 26 00:55:41 HPX312 homebridge[8742]: [2019-1-26 00:55:41] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loaded plugin: homebridge-hue
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Registering platform 'homebridge-hue.Hue'
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] ---
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loading 2 platforms...
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Config] Initializing config platform...
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Config] Spawning homebridge-config-ui-x with PID 8866
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] Initializing Hue platform...
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
Jan 26 00:55:42 HPX312 homebridge[8742]: [2019-1-26 00:55:42] Loading 1 accessories...
Jan 26 00:55:42 HPX312 homebridge[8742]: /usr/local/lib/node_modules/homebridge/lib/api.js:64
Jan 26 00:55:42 HPX312 homebridge[8742]: throw new Error("The requested accessory '" + name + "' was not registered by any plugin.");
Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Unit entered failed state.
Jan 26 00:55:42 HPX312 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 26 00:55:53 HPX312 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Jan 26 00:55:53 HPX312 systemd[1]: Stopped Node.js HomeKit Server.
Jan 26 00:55:53 HPX312 systemd[1]: Started Node.js HomeKit Server.
Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded config.json with 1 accessories and 2 platforms.
Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] ---
Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded plugin: homebridge-config-ui-x
Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Registering platform 'homebridge-config-ui-x.config'
Jan 26 00:55:55 HPX312 homebridge[9015]: [2019-1-26 00:55:55] Loaded plugin: homebridge-harmonyhub
Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] Registering platform 'homebridge-harmonyhub.HarmonyHub'
Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] ---
Jan 26 00:55:56 HPX312 homebridge[9015]: [2019-1-26 00:55:56] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.15.0 which does not satisfy the current Node version of v11.8.0. You may need to upgrade your installation of Node.
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Loaded plugin: homebridge-hue
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Registering platform 'homebridge-hue.Hue'
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] ---
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] Loading 2 platforms...
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Config] Initializing config platform...
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Config] Spawning homebridge-config-ui-x with PID 9083
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] Initializing Hue platform...
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] homebridge-hue v0.11.11, node v11.8.0, homebridge v0.4.46
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] warning: not using recommended node version v10.15.0 LTS
Jan 26 00:55:58 HPX312 homebridge[9015]: [2019-1-26 00:55:58] [Phillips Hue] warning: not using recommended homebridge version v0.4.45
hier meine config
"accessories": [{
"name": "Test lamp",
"accessory": "FakeBulb",
"bulb_name": "Lamp1"
"bridge": {
"name": "Homebridge",
"pin": "031-45-154",
"port": 51826
"platforms": [{
"port": 8888,
"sudo": true,
"platform": "config",
"theme": "red",
"auth": "form",
"log": {
"service": "homebridge",
"method": "systemd"
"name": "Config"
"sensors": true,
"users": {
"xx": "xx"
"platform": "Hue",
"name": "Phillips Hue",
"nativeHomeKitSensors": false,
"lights": true
normal müsste alles richtig sein aber es geht nicht
hoffentlich kann mir jemand helfen
