Beiträge von DJay
    [email protected]
    v0.14.0
    Added
    • Added an experimental configuration schema (config.schema.json) for homebridge-config-ui-x. The schema is dynamically updated by the plugin to add the authorisation link and settings for appliance programs. This only works if the plugin has write access to the schema file in its installation directory. (config.json / Programs)
    • New configuration option "language": { "api": "en-GB" } enables selection of the Home Connect API language. This affects the names of program Switch services and options in the configuration schema. (config.json / Programs)
    Changed
    • CleaningRobot/CoffeeMaker/CookProcessor/Dishwasher/Dryer/Hob/Oven/Washer/WasherDryer: Created a new Switch service to indicate when a program is active. This replaces the Active characteristic that was previously on the main power Switch service (which caused problems with Siri switching the appliance power on or off). The Remaining Duration, Status Active, and Status Fault characteristics have also been relocated to the new Switch. (HomeKit Mapping / #10)
    • Hood: The Remaining Duration characteristic has been relocated to the Fan service. The Activecharacteristic has been removed. (HomeKit Mapping / #10)
    • CoffeeMaker/Dishwasher/Dryer/Hob/Hood/Oven/Washer/WasherDryer: Updates to the Program Modecharacteristic are delayed until all of the state on which it depends has been updated. This prevents it from being temporarily set to an incorrect value.
    • The appliance name is no longer included in HomeKit service names. This only affects newly created accessories.
    • Oven: Program options are now hidden in the Identify log output for appliances without Control scope authorised. (Programs / Scopes)
    • Upgraded node-persist from version 0.0.8 to 3.0.5. Any authorisation tokens saved by the previous version are imported and migrated to the new format.
    • Cached appliance capabilities are now expired after 24 hours, or when the API language is changed. This ensures that any new API capabilities, or changes to the language configuration, are detected when Homebridge is restarted.
    • Hood/Oven: Expected API errors are now only logged at debug log level. This includes queries for settings or programs that are not supported by a specific appliance. (#2)
    Fixed
    • Hood: The active program is now checked when an appliance reconnects to the Home Connect servers. This was already done for other appliance types that support programs. (#2)
    Die Erfahrung teile ich nicht. Ich habe zwei Eufy Cams 2c und eine Eufy Cam 2 an einer HomeBase 2. Mit individuellen Einstellungen habe ich JEDE relevante Bewegung von Menschen komplett drauf.
    wer hat von euch die Eufycam 2 schon im Einsatz?
    JJ260879 Bitte zukünftig keine Doppelpost. Deinen Beitrag mit genau der selben Frage im anderen Thread, habe ich entfernt.
    Vielleicht stellst Du die Frage die Du zur EufyCam 2 hast und was Dich interessiert, anstelle zu fragen wer eine hat?
    In jedem Fall weiterhin eine gute Zeit und Austausch hier.
    Was ich noch habe ist ein neuer Schalter „Active Program“, der eigentlich immer auf aus steht.
    Ja das habe ich auch noch nicht herausgefunden für was Active Program ist.
    Aber all-in-all top Plugin und lange ersehnt. Spitze was der Entwickler in der kurzen Zeit da hervorgebracht hat.
    Bei mir ebenso. Mit der aktuellen Version läuft bisher nahezu alles einwandfrei.
    Funktioniert bei Dir „Tür zu/auf“? Bei mir nicht. Was mich aber auch nicht stört.
    Alles in allem haben beide Plugins ihre Daseinsberechtigung und ihre eigenen Vor- und Nachteile, denke ich.
    Ein schönes Fazit! Und die Wahl zu haben als Nutzer, ist immer gut. :thumbup:
    Danke an Euch beide Benzman81  lukas.roegner für die Hintergründe auch zur historisch gewachsenen Entwicklung der Plugins und zu den Funktionsweisen.
    Und meine absolute Wertschätzung für Eure Arbeit, die Zeit und das Teilen mit Eurer Community.
    Denn die Fangemeinde habt Ihr offensichtlich beide. Schön, dass Ihr auch hier im Forum vertreten und aktiv seid.
    Oder mal den Ordner cachedAccessories löschen im Homebridge Ordner und dann Homebridge neu starten. Bei mir hilft das immer bei so etwas wie Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory:
    /home/pi/.homebridge/accessories/cachedAccessories
    Oder je nachdem, wo bei Dir der Homebridge Ordner ist.
    sudo rm /var/homebridge/accessories/cachedAccessories oder was auch immer Dein Ordner ist.
    sudo systemctl start homebridge
    Mehr nicht?
    Wie auf der Website angegeben...
    Zitat
    In der laundrify App kannst du dir den Status des aktuellen Waschgangs jederzeit ansehen und dich per Push-Notification auf deinem Smartphone benachrichtigen lassen, sobald die Wäsche fertig ist.
    Die Platform wird aktiv weiterentwickelt, sodass mit der Zeit weitere Features wie z.B. die Analyse des Stromverbrauchs, eine Hochrechnung der anfallenden Stromkosten oder ein Vergleich Energieeffizienz mit anderen Waschmaschinen hinzukommen.
    Konstruktive Kritik, Anregungen, Verbesserungsvorschläge, Liebesbriefe und Lobeshymnen sind immer gerne gesehen. Wir sind auch stets offen für einen Wissens- oder Erfahrungsaustausch und allen anderen Vorhaben die in Zusammenhang mit dem Projekt stehen.
    Mal so ganz offen gesprochen... Wir haben mit Benzman81 und lukas.roegner ja zwei hilfreiche und talentierte Entwickler in unseren Reihen.
    Aber genug der Schmeichelei... :* Warum sollte sich jemand für https://github.com/benzman81/homebridge-nukiio oder für https://github.com/lukasroegner/homebridge-nuki entscheiden?
    Wo sind die Unterschiede? Aktuell sind beide Plugins und fleißig sind auch beide Männer. Einen Wettbewerb würde ich auch mal nicht vermuten. Eine Zusammenarbeit aber auch nicht. So.. ? 8)
    Aha aha ahaaa.. :thumbup: Danke.
                        "id": "sensor2",
                        "name": "Haustürkontakt",
                        "type": "contact",
                        "autoRelease": true,
                        "autoReleaseTime": 10000
    Und in IFTTT ein Applet erstellt...
    Meine URL die ich auch für den Sleep Sensor nutze, nun mit der weiteren accessoryId=sensor2
    http://username:[email protected]:51828/?accessoryId=sensor2&state=false
    Test ich die URL im Browser wird der Kontaktsensor in HomeKit geöffnet und nach 10 Sekunden wieder automatisch geschlossen.
    Sollte so passen, oder? Mit dem Opener testen, kann ich erst heute Abend.
    Ich versuche gerade eine Lampe blinken zu lassen, wenn die Hauseinganstür vom Nuki Opener geöffnet wurde.
    Ring to Open und Dauermodus sind aktiv. Wenn jetzt der Paketzusteller klingelt und die Tür vom Opener aufgrund dessen geöffnet wird, wird dies durch das Plugin in HomeKit irgendwie registriert? Dann könnte ich damit ja eine Automation anlegen die eine Szene startet und das Licht schaltet.
    Ich komm nur gerade gedanklich nicht weiter ob das so geht? :/
    Nach Rücksprache mit dem Entwickler des laundrify WLAN-Adapter für die Waschmaschine, hat dieser auch ein Homebridge Plugin in Aussicht gestellt.
    So freut sich Mike schon darauf ein Plugin dafür zu schreiben. Wir dürfen wohl noch in den nächsten 4-8 Wochen damit rechnen.
    Wer sich also nicht selbst etwas aus Sonoff & Co. basteln möchte und zudem in der zugehörigen laundrify-App und deren Funktionen auch einen Mehrwert sieht, ist hier sicher ganz gut bedient.
    Den Adapter habe ich mir auch bestellt und werde natürlich gerne berichten.
    Da Mike fleißig an der Weiterentwicklung Interessiert ist, ist er für Feedback und Ideen sicher auch dankbar. Ich persönlich freue mich auf das Homebridge Plugin und eine Verwendung auch für z.B. die Spülmaschine wäre ebenfalls in meinem ganz eigennützigen Interesse. ;)
    Der laundrify WLAN-Adaper ist aktuell für 24,95 € inkl. Versand, direkt über die Website des Entwicklers zu bekommen.
    Danke. Na denn mal hier auch auf iOS 13.3.1 warten und hoffen. :)
    Ein andere Herausforderung vor der ich gerade stand und vielleicht auch jemandem zukünftig eine Hilfe ist.
    Ich hätte gerne, dass die Rollos automatisch stoppen wenn sie geschlossen werden, wenn ein Fenster offen ist.
    Meine ersten Versuche mit einer Automation hatten keinen Erfolg gebracht. Weder mit der Option "Wenn schließen", oder auch nicht mit einer bestimmten Position.
    Auslöser wenn Rollos Position 80% , Bedingung Kontakt Auf, dann Szene Rollo Notfall Stop.
    Szene Rollo Notfall Stop = Rollos Position 100%
    Letztendlich habe ich herausgefunden, dass eine Position genau 80% oder <>80% nicht von der Automation erkannt wird. Setze ich die Position aber auf 82% klappt es bisher bei jedem Versuch.
    Beim Öffnen und Schließen der Rollos werden immer ein paar Prozent übersprungen und daher wird z.B. die 80% nie genau als Auslöser für die Automation getroffen. In meinem Fall bei 82% scheint das aber dann doch zu funktioniert. Auch ein bisschen seltsam. :/
    Seit ein paar Wochen reagieren meine Hue Dimmer Switch total langsam in HomeKit.
    So richtig nachvollziehen kann ich allerdings nicht, woran das liegt.
    Ich habe in der Apple Home App z.B. auf Taste 4 die Gute Nacht Szene und 2-3 einzelne Geräte hinterlegt.
    Wenn ich am Dimmer Switch nun die Taste drücke dauert es gut 10 Sek. bis sich überhaupt etwas tut.
    Es führt dann zwar alles aus, aber dauert wie gesagt ewig, bis es überhaupt dazu kommt.
    Nicht so versierte Hausbewohner drücken dann natürlich x-mal die Taste weil sie glauben es passiert nichts. Das macht das Chaos dann perfekt. ;)
    Ist das noch jemandem gerade im Zusammenhang mit HomeKit aufgefallen? Und natürlich gibt es eine Lösung? Ich hab jetzt mal den Zigbee Kanal gewechselt, glaube aber nicht, dass das damit irgendwas zu tun hat.
    Und bei mir gab es heute Morgen keinen Kaffee weil das Bett nicht gewusst hat, dass es nicht mehr belegt ist.
    Ob manchen Entwicklern die dramatische Reichweite ihrer Arbeit und Updates bewusst ist? 😅😉❤️
    Jemand ne idee, weshalb die rollos auf „beim schließen“ stehen
    https://github.com/meg768/home…tradfri-gateway/issues/55
    Hab mal beim Entwickler angefragt von homebridge-ikea-tradfri-gateway
    Entweder ist wirklich irgendwas bei der Programmierung komisch, oder es ist ein iOS Übersetzungsfehler.
    Funktionieren tut alles einwandfrei. Nur eben irritierend wenn der Status komisch angezeigt wird, gerade wenn man nicht in der Wohnung ist und von außerhalb steuert.
