Hab es auch installiert und bei mir sind morgen auch zwei Mülltonnen dran ?
Beiträge von to0b
Habe es gerade mal aktualisiert und Zonen hinzugefügt aber das Plugin läd nicht. Ohne die Zonen läd es ebenfalls nicht mehr.
Kann das vielleicht am der stored Option liegen die aktiv ist?
Alles anzeigen/usr/lib/node_modules/homebridge-automation-switches/src/SecuritySystemAccessory.js:136 Feb 18 19:59:27 raspberrypi homebridge[27599]: .updateValue(this._state.zonesAlarm[zoneLabel] || false); Feb 18 19:59:27 raspberrypi homebridge[27599]: ^ Feb 18 19:59:27 raspberrypi homebridge[27599]: TypeError: Cannot read property 'Außen' of undefined Feb 18 19:59:27 raspberrypi homebridge[27599]: at SecuritySystemAccessory.getZoneServices (/usr/lib/node_modules/homebridge-automation-switches/src/SecuritySystemAccessory.js:136:44) Feb 18 19:59:27 raspberrypi homebridge[27599]: at SecuritySystemAccessory.createServices (/usr/lib/node_modules/homebridge-automation-switches/src/SecuritySystemAccessory.js:78:15) Feb 18 19:59:27 raspberrypi homebridge[27599]: at new SecuritySystemAccessory (/usr/lib/node_modules/homebridge-automation-switches/src/SecuritySystemAccessory.js:53:27) Feb 18 19:59:27 raspberrypi homebridge[27599]: at AutomationSwitchesPlatform._createSecuritySwitch (/usr/lib/node_modules/homebridge-automation-switches/src/index.js:120:12) Feb 18 19:59:27 raspberrypi homebridge[27599]: at switches.forEach.sw (/usr/lib/node_modules/homebridge-automation-switches/src/index.js:80:25) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Array.forEach (<anonymous>) Feb 18 19:59:27 raspberrypi homebridge[27599]: at AutomationSwitchesPlatform.accessories (/usr/lib/node_modules/homebridge-automation-switches/src/index.js:59:14) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Server._loadPlatformAccessories (/usr/lib/node_modules/homebridge/lib/server.js:364:20) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Server._loadPlatforms (/usr/lib/node_modules/homebridge/lib/server.js:308:16) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Server.run (/usr/lib/node_modules/homebridge/lib/server.js:85:36) Feb 18 19:59:27 raspberrypi homebridge[27599]: at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:40:10) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Module._compile (module.js:643:30) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Object.Module._extensions..js (module.js:654:10) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Module.load (module.js:556:32) Feb 18 19:59:27 raspberrypi homebridge[27599]: at tryModuleLoad (module.js:499:12) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Function.Module._load (module.js:491:3) Feb 18 19:59:27 raspberrypi homebridge[27599]: at Function.Module.runMain (module.js:684:10) Feb 18 19:59:27 raspberrypi homebridge[27599]: at startup (bootstrap_node.js:187:16) Feb 18 19:59:27 raspberrypi homebridge[27599]: at bootstrap_node.js:608:3Edit: Ok lag an der stored Option
einmal auf false gestellt und es läd -
Hey,
I don’t use openhab to control my marantz receiver. I‘ve only used openhab to control an innogy smart home system with homekit in the past.
I use homebridge-denon-marantz and homebridge-marantz-volume for the HomeKit Integration.
EADDRINUSE :::51826 bedeutet, dass der Port "51826" bereits in Verwendung ist. Wahrscheinlich läuft deine Homebridge bereits als Service.
Schau mal mit sudo service homebridge status ob die nicht schon läuft.
Du hast zweimal Platforms definiert. Müsste so aussehen:
Alles anzeigen{ "bridge": { "name": "Homebridge", "username": "CC:22:3D:E3:CE:30", "port": 51826, "pin": "031-45-154" }, "accessories": [ ], "platforms": [ { "platform": "MaxCubePlatform", "name": "MaxCube Platform", "ip": "192.168.5.104", "port": 62910 }, { "platform":"BroadlinkRM", "name":"Broadlink RM", "host":"192.168.5.106", "hideScanFrequencyButton": false, "hideLearnButton": false } ] } -
Bin mir nicht sicher ob ein Hue Motion über die Hue Bride mit Hue Plugin einen Temperatur-, Bewegungs- und Helligkeitsverlauf anzeigt. Meine Laufen aktuell noch über den nativen HK Support .
Bei den Xiaomi Sensoren über deCONZ funktionier das wunderbar.
Changelog:
- Added improved handling of unknown Broadlink devices
- Improved error logging when sending data to RM devices
Theoretisch müsste es ja funktionieren wenn man einen stärkeren Magneten verwendet. Dann sollte der Radius vielleicht größer werden.
Dann den Sensor unter die Tonne kleben und aufm Boden den Magneten anbringen :D. Ich glaub ich bestell nochmal ein paar Sensoren
Ich habe für ein anderes Thema den automation-switch für stündliche telegram-erinnerung, bis der switch ausgeschalten wird, nachdem ich es erledigt habe.
Jetzt noch den Standort der Mülltonnen mit Kontaksensoren bestücken und du müsstest den Schalter nicht mal mehr manuell deaktivieren ?
Aber wird wahrscheinlich schwer, da der Radius meist zu klein ist und Feuchtigkeit ein Problem wird
Die Historie kann jetzt auf Google Drive oder lokal gespeichert werden
Bei mir läuft die Aufzeichnung super! Danke naofireblade
Ich teste es gerade.
Man muss noch fakegato-history im weather-station-extended Ordner installieren
Edit:
Die ersten Werte wurden nach 10 Minuten erfolgreich geloggt.
Was blabbert der eigentlich genau?
Hat schon jemand die neue Version mit wischfunktion? Wollte mir die Tage endlich auch mal einen bestellen aber bin mir noch nicht sicher ob sich die neuere Version lohnt.
Ganz normal über die Emoji Tastatur ? Einfach zwischen den " " Text mit Emoji einfügen und fertig
Z.b über dein iPhone oder ein mac. Entweder über Config-ui (Browser) oder über eine ssh App.
Schade, finde die Idee vom Produkt recht cool. Dann werde ich lieber noch etwas warten.
xMAIKx einfach über ein Gerät die Config editieren welches Unicode Smileys unterstützt und ja die werden in Telegram angezeigt.
Vielleicht liegt es auch an den Plugins selber, das diese immer geladen werden.
schau mal hier rein: /etc/ssh/sshd_config
und such nach PermitRootLogin und setz das auf yes
Danach noch sudo service ssh restart und dann sollte der SFTP Zugriff mit root funktionieren.
