[22/03/2023, 21:14:06] [@conquistadore/homebridge-ecowitt] Creating data report service
[22/03/2023, 21:14:06] [@conquistadore/homebridge-ecowitt] Port: 8080
[22/03/2023, 21:14:06] [@conquistadore/homebridge-ecowitt] Path: /data/report
[22/03/2023, 21:14:07] [@conquistadore/homebridge-ecowitt] Listening for data reports on: http://[::]:8080
[22/03/2023, 21:14:08] Homebridge v1.5.1 (HAP v0.10.4) (@conquistadore/homebridge-ecowitt) is running on port 39752.
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Data report: {
"PASSKEY": "",
"stationtype": "GW1100A_V2.2.3",
"runtime": "96058",
"dateutc": "2023-03-22 20:18:39",
"tempinf": "62.06",
"humidityin": "50",
"baromrelin": "29.518",
"baromabsin": "29.518",
"tempf": "69.26",
"humidity": "46",
"winddir": "296",
"windspeedmph": "0.00",
"windgustmph": "0.00",
"maxdailygust": "1.12",
"solarradiation": "0.34",
"uv": "0",
"rainratein": "0.000",
"eventrainin": "0.000",
"hourlyrainin": "0.000",
"dailyrainin": "0.012",
"weeklyrainin": "0.012",
"monthlyrainin": "0.012",
"yearlyrainin": "0.012",
"totalrainin": "0.012",
"temp1f": "55.40",
"humidity1": "70",
"wh65batt": "0",
"batt1": "0",
"freq": "868M",
"model": "GW1100A",
"interval": "20"
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Registering accessories
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] stationTypeInfo: ["GW1100A_V2.2.3","GW1100A","V2.2.3"]
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] modelInfo: ["GW1100A","GW1100A",null,null]
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Adding sensor: GW1100A
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Discovering sensors
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Adding sensor: WH65
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] Adding sensor: WH31 channel: 1
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] StationInfo: {
"model": "GW1100A",
"deviceName": "GW1100A-WIFI931D",
"serialNumber": "7C:87:CE:BE:93:1D",
"hardwareRevision": "GW1100A_V2.2.3",
"softwareRevision": "",
"firmwareRevision": "V2.2.3",
"frequency": "868M",
"PASSKEY": "",
"sensors": [
"type": "GW1100A"
"type": "WH65"
"type": "WH31",
"channel": 1
[22/03/2023, 21:18:39] [@conquistadore/homebridge-ecowitt] sensorId: 7C:87:CE:BE:93:1D-GW1100A uuid: xxxxxx
[22/03/2023, 21:18:40] [@conquistadore/homebridge-ecowitt] Adding new accessory type: GW1100A channel: undefined
[22/03/2023, 21:18:40] [@conquistadore/homebridge-ecowitt] sensorId: 7C:87:CE:BE:93:1D-WH65 uuid: xxxxxx
[22/03/2023, 21:18:40] [@conquistadore/homebridge-ecowitt] uvThreshold: 0
[22/03/2023, 21:18:40] [@conquistadore/homebridge-ecowitt] Adding new accessory type: WH65 channel: undefined
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] sensorId: 7C:87:CE:BE:93:1D-WH31-1 uuid: xxxxxx
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] Adding new accessory type: WH31 channel: 1
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] Report time: 2023-03-22T19:18:39.000Z
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] Updating: GW1100A channel: undefined
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] GW1100A Update
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] tempinf: 62.06
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] humidityin: 50
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] baromrelin 29.518
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] baromabsin 29.518
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] Updating: WH65 channel: undefined
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] WH65 Update
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] wh65batt: 0
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] tempf: 69.26
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] humidity: 46
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] solarradiation: 0.34
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] uv: 0
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] winddir: 296
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] windspeedmph: 0
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] windgustmph: 0
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] maxdailygust: 1.12
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] rainratein: 0.000
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] eventrainin: 0.000
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] hourlyrainin: 0.000
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] dailyrainin: 0.012
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] weeklyrainin: 0.012
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] monthlyrainin: 0.012
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] yearlyrainin: 0.012
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] totalrainin: 0.012
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] Updating: WH31 channel: 1
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] WH31 Channel 1 Update
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] batt: 0
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] tempf: 55.40
[22/03/2023, 21:18:41] [@conquistadore/homebridge-ecowitt] humidity: 70
[22/03/2023, 21:47:45] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Temperature': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:47:45] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Relative Humidity': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:47:45] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:04] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Temperature': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:04] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Relative Humidity': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:04] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:26] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Temperature': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:26] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Relative Humidity': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
[22/03/2023, 21:48:26] [@conquistadore/homebridge-ecowitt] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic value expected valid finite number and received "NaN" (number). See https://homebridge.io/w/JtMGR for more info.
