Hallo Forengemeinde,
Auf meinem mac mini (OSX 10.14.5) der hier zuhause unter anderem auch als plex server läuft habe ich, so glaube ich jedenfalls, ein Problem mit den Zugriffsrechten, das Log erzeugt mir beim Start folgende Fehlermeldung:
[9/20/2019, 10:43:43 PM] Loaded config.json with 0 accessories and 1 platforms.
[9/20/2019, 10:43:43 PM] ---
[9/20/2019, 10:43:43 PM] Loaded plugin: homebridge-config-ui-x
[9/20/2019, 10:43:43 PM] Registering platform 'homebridge-config-ui-x.config'
[9/20/2019, 10:43:43 PM] Loading 1 platforms...
[9/20/2019, 10:43:43 PM] [Config] Initializing config platform...
[9/20/2019, 10:43:43 PM] [Config] Spawning homebridge-config-ui-x with PID 508
[9/20/2019, 10:43:43 PM] Loading 0 accessories...
[9/20/2019, 10:43:43 PM] Error: EACCES: permission denied, open '/Users/bbuch/.homebridge/persist/AccessoryInfo.CC223DE3CE30.json'
at Object.openSync (fs.js:443:3)
at Object.writeFileSync (fs.js:1194:35)
at LocalStorage.persistKeySync (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/node-persist/src/local-storage.js:476:16)
at LocalStorage.setItemSync (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/node-persist/src/local-storage.js:277:14)
at Object.nodePersist.setItemSync (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/node-persist/src/node-persist.js:99:29)
at AccessoryInfo.save (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/model/AccessoryInfo.js:163:11)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:552:23)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:132:16)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:101:10)
[9/20/2019, 10:43:43 PM] Got SIGTERM, shutting down Homebridge...
[9/20/2019, 10:43:43 PM] Error: EACCES: permission denied, open '/Users/benbuchloh/.homebridge/accessories/cachedAccessories'
at LocalStorage.persistKeySync (/usr/local/lib/node_modules/homebridge/node_modules/node-persist/local-storage.js:457:12)
at LocalStorage.setItemSync (/usr/local/lib/node_modules/homebridge/node_modules/node-persist/local-storage.js:275:14)
at Server._updateCachedAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:581:20)
at Server._teardown (/usr/local/lib/node_modules/homebridge/lib/server.js:586:8)
at process.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/cli.js:44:14)
at process.emit (events.js:198:13)
[9/20/2019, 10:43:49 PM] [Config] Homebridge Config UI X v4.6.1 is listening on :: port 8080
Kann jemand helfen und weiß was zu tun ist?
Danke und beste Grüße!
