hallo zusammen,
ich habe nun schon etlich plugins versucht, wie zb. http switch oder homebridge-dreambox.
https://github.com/grzegorz914…ridge-openwebif-tv#readme
ich bekomme es einfach nicht hin meine dreambox one mit einzubinden.
hier meine configs:
"devices": [
"name": "Dreambox One",
"host": "192.168.178.82",
"port": 80,
"auth": false,
"user": "xxx",
"pass": "xxx",
"volumeControl": 0,
"switchInfoMenu": false,
"manufacturer": "Manufacturer",
"modelName": "Model",
"serialNumber": "Serial Number",
"firmwareRevision": "Firmware Revision"
"platform": "OpenWebIfTv"
nachdem ich den receiver in hk hinzugefügt habe zeigt er immer "keine antwort"
der log zeigt das hier:
Nov 15 21:35:15 Homebridge homebridge[29181]: [15.11.2020, 21:35:15] Please add [Dreambox One 5A05] manually in Home app. Setup Code: 303-97-669
Nov 15 21:35:15 Homebridge homebridge[29181]: [15.11.2020, 21:35:15] [HomeConnect] No saved authorisation data found
Nov 15 21:35:15 Homebridge homebridge[29181]: [15.11.2020, 21:35:15] [HomeConnect] Requesting Home Connect authorisation using the Device Flow
Nov 15 21:35:15 Homebridge homebridge[29181]: [15.11.2020, 21:35:15] [OpenWebIfTv] Device: 192.168.178.82 Dreambox One, getDeviceInfo eror: Error: Request failed with status code 404
Nov 15 21:35:15 Homebridge homebridge[29181]: at createError (/usr/local/lib/node_modules/homebridge-openwebif-tv/node_modules/axios/lib/core/createError.js:16:15)
Nov 15 21:35:15 Homebridge homebridge[29181]: at settle (/usr/local/lib/node_modules/homebridge-openwebif-tv/node_modules/axios/lib/core/settle.js:17:12)
Nov 15 21:35:15 Homebridge homebridge[29181]: at IncomingMessage.handleStreamEnd (/usr/local/lib/node_modules/homebridge-openwebif-tv/node_modules/axios/lib/adapters/http.js:236:11)
Nov 15 21:35:15 Homebridge homebridge[29181]: at IncomingMessage.emit (events.js:327:22)
Nov 15 21:35:15 Homebridge homebridge[29181]: at endReadableNT (_stream_readable.js:1327:12)
Nov 15 21:35:15 Homebridge homebridge[29181]: at processTicksAndRejections (internal/process/task_queues.js:80:21) {
Nov 15 21:35:15 Homebridge homebridge[29181]: config: [Object],
Nov 15 21:35:15 Homebridge homebridge[29181]: request: [ClientRequest],
Nov 15 21:35:15 Homebridge homebridge[29181]: response: [Object],
Nov 15 21:35:15 Homebridge homebridge[29181]: isAxiosError: true,
Nov 15 21:35:15 Homebridge homebridge[29181]: toJSON: [Function (anonymous)]
Nov 15 21:35:15 Homebridge homebridge[29181]: }, state: Offline
