Hi Leute
Ich versuche gerade auf meinem Homebridge Server (Debian 10.5) das o.g. Plugin zu installieren, über das Webif von HB
Ich bekomme folgende Fehlermeldung:
USER: homebridge
DIR: /usr/local
CMD: sudo -E -n npm install -g homebridge-zigbee-nt@latest
> @serialport/[email protected] install /usr/local/lib/node_modules/homebridge-zigbee-nt/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.15.1 runtime=node arch=x64 libc= platform=linux)
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqCallback.oncomplete (fs.js:183:21)
gyp ERR! System Linux 4.19.0-11-amd64
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/homebridge-zigbee-nt/node_modules/@serialport/bindings
gyp ERR! node -v v14.15.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/homebridge-zigbee-nt/node_modules/zigbee-herdsman/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for [email protected]: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/homebridge-zigbee-nt/node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/homebridge-zigbee-nt/node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/homebridge-zigbee-nt/node_modules/zigbee-herdsman-converters/node_modules/fsevents):
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/[email protected] install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/[email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/homebridge/.npm/_logs/2020-12-23T14_52_16_411Z-debug.log
Command failed. Please review log for details.
Kann mir da eventuell einer helfen?
Möchte meinen C2531 Stick damit betreiben, da der Conbee nicht so schön läuft
Danke euch
LOG im Anhang
