Great thank you. I have 3 files.
And with this model i can use this aluminium prorfile: https://www.alu-profile-led.de…ckung-spree_227284_145350
To be sure i fully understand you ![]()
yes
Any recommendation for silver wire i can buy? Strong one that make the model very nice as well?
nope, no specific recommendation for 3D filament. use whatever you like ![]()
I have a test model created with a friends place. We used 1.75 filament. Order the aluminum led from the German company. The all is 2cmx2cm and inside the 1.62cm to add the led strip.
I tried to put the aluminum into the printed object. But we seen now that the hole is 1.9cm x 1.9cm. So it won't fit.
Do you know what this can be?
Greetings,
Peter
Hallo Patrick,
das Thema ist zwar etwas älter aber ich finde dein Design sehr gelungen und wäre sehr an deinen STL Files interessiert, falls du sie noch haben solltest.
Gruß
RayJey
