Hallo zusammen
Seit einigen Tagen oder evtl. WOchen (ich weiß nicht so genau) startet meine Homebrige jedesmal sozusagen unkontrolliert.
Schau ich ins Log dann sehe ich folgendes:
[28.3.2022, 10:08:03] [Hue] Bad Multisensor: set homekit temperature from 27°C to 27.1°C
[28.3.2022, 10:08:03] [Hue] Bad Multisensor: set homekit humidity from 41% to 35%
[28.3.2022, 10:08:03] [Hue] Bad Multisensor: set homekit pressure from 963 hPa to 962 hPa
[28.3.2022, 10:08:52] [Hue] Bewegungsmelder Flur: set homekit motion from 1 to 0
[28.3.2022, 09:49:58] [HB Supervisor] OS: Linux 5.10.103-v7l+ arm
[28.3.2022, 09:49:58] [HB Supervisor] Node.js v16.14.2 /usr/local/bin/node
[28.3.2022, 09:49:58] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[28.3.2022, 09:49:58] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[28.3.2022, 09:50:09] [Homebridge UI] Homebridge Config UI X v4.42.0 is listening on :: port 8581
[28.3.2022, 09:50:10] [HB Supervisor] Starting Homebridge with extra flags: -I
[28.3.2022, 09:50:10] [HB Supervisor] Started Homebridge v1.4.0 with PID: 1343
[28.3.2022, 10:11:08] Loaded config.json with 2 accessories and 5 platforms.
[28.3.2022, 10:11:09] Loaded 22 cached accessories from cachedAccessories.
[28.3.2022, 10:11:09] ---
[28.3.2022, 10:11:11] Loaded plugin: [email protected]
[28.3.2022, 10:11:11] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[28.3.2022, 10:11:11] ---
[28.3.2022, 10:11:11] Registering platform 'homebridge-config-ui-x.config'
[28.3.2022, 10:11:11] Registering accessory 'homebridge-dummy.DummySwitch'
[28.3.2022, 10:11:13] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[28.3.2022, 10:11:13] ---
[28.3.2022, 10:11:16] Loaded plugin: [email protected]
[28.3.2022, 10:11:16] Registering platform 'homebridge-hue.Hue'
[28.3.2022, 10:11:16] ---
[28.3.2022, 10:11:16] Registering platform 'homebridge-webos-tv.webostv'
[28.3.2022, 10:11:16] Loading 5 platforms...
[28.3.2022, 10:11:16] [Config] Initializing config platform...
[28.3.2022, 10:11:16] [Config] Running in Service Mode
[28.3.2022, 10:11:16] [Hue] Initializing Hue platform...
[28.3.2022, 10:11:16] [Hue] Initializing child bridge 0E:8C:81:58:BC:97
[28.3.2022, 10:11:16] [AVM] Initializing FritzPlatform platform...
[28.3.2022, 10:11:19] [webostv] Initializing webostv platform...
[28.3.2022, 10:11:19] [Camera FFmpeg] Initializing Camera-ffmpeg platform...
[28.3.2022, 10:11:19] [Camera FFmpeg] Initializing child bridge 0E:84:0D:35:AB:D4
[28.3.2022, 10:11:19] Loading 2 accessories...
[28.3.2022, 10:11:19] [Dummy-Flur] Initializing DummySwitch accessory...
[28.3.2022, 10:11:20] [Dummy-Flur] Setting switch to false
[28.3.2022, 10:11:20] [Dummy-WoZi] Initializing DummySwitch accessory...
[28.3.2022, 10:11:20] [Dummy-WoZi] Setting switch to false
[28.3.2022, 10:11:20] [webostv] Init - initializing devices
[28.3.2022, 10:11:20] [webostv] [LG-TV] Init - got TV configuration, initializing device with name: LG-TV
Setup Payload:
X-HM://0024TG7O41LTT
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 814-91-924 │
[28.3.2022, 10:11:20] LG-TV 6EDF is running on port 38065.
[28.3.2022, 10:11:20] Please add [LG-TV 6EDF] manually in Home app. Setup Code: 814-91-924
[28.3.2022, 10:11:20] Homebridge v1.4.0 (HAP v0.10.0) (Homebridge F7CE) is running on port 51591.
[28.3.2022, 10:11:20] [AVM] Callmonitor connection established with 192.168.178.1:1012
[28.3.2022, 10:11:20] [AVM] Fritz-Box Wifi 2ghz: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Fritz-Box Wifi 5ghz: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Fritz-Box Wifi guest: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Repeater 2400: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Repeater 2400 Led: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Zirkulationspumpe: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Vitrine: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Subwoofer: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Soundbar : Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Flur: Configuring cached accessory...
[28.3.2022, 10:11:20] [AVM] Tripod: Configuring cached accessor
ich hab keinen Restart angestossen. In der Crontab seht auch nichts.
Jetzt weiß ich auch nicht wieter
Vielleicht kann mir jemand einen Tipp geben
Danke Roger
