? xxx-xx-xxx?
[2018-4-7 09:34:35] Homebridge is running on port 51826.
/homebridge/node_modules/mdns/lib/resolver_sequence_tasks.js:199
var e = new Error(syscall + ' ' + errorno);
Error: getaddrinfo -3008
at errnoException (/homebridge/node_modules/mdns/lib/resolver_sequence_tasks.js:199:11)
at getaddrinfo_complete (/homebridge/node_modules/mdns/lib/resolver_sequence_tasks.js:112:10)
at GetAddrInfoReqWrap.oncomplete (/homebridge/node_modules/mdns/lib/resolver_sequence_tasks.js:120:9)
*** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
[2018-4-7 09:34:43] Loaded plugin: homebridge-soundtouch
[2018-4-7 09:34:43] Registering accessory 'homebridge-soundtouch.SoundTouch'
[2018-4-7 09:34:43] ---
[2018-4-7 09:34:43] Loaded plugin: homebridge-soundtouch-preset
[2018-4-7 09:34:43] Registering accessory 'homebridge-soundtouch.SoundTouch-Preset'
[2018-4-7 09:34:43] Loaded plugin: homebridge-config-ui-x
[2018-4-7 09:34:43] Registering platform 'homebridge-config-ui-x.config'
[2018-4-7 09:34:43] Loaded config.json with 1 accessories and 0 platforms.
[2018-4-7 09:34:43] Loading 0 platforms...
[2018-4-7 09:34:43] Loading 1 accessories...
[2018-4-7 09:34:43] [Lautsprecher Badezimmer] Initializing SoundTouch accessory...
Started Searching...
Setup Payload:
X-HM://0023ISYWYHDDH
