May 10 21:40:06 raspberrypi homebridge[2067]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
May 10 21:40:06 raspberrypi homebridge[2067]: *** WARNING *** Please fix your application to use the native API of Avahi!
May 10 21:40:06 raspberrypi homebridge[2067]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
May 10 21:40:06 raspberrypi homebridge[2067]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May 10 21:40:06 raspberrypi homebridge[2067]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
May 10 21:40:08 raspberrypi homebridge[2067]: ????????????????????????????????????????????????????????????????
May 10 21:40:08 raspberrypi homebridge[2067]: ? npm update check failed ?
May 10 21:40:08 raspberrypi homebridge[2067]: ? Try running with sudo or get access ?
May 10 21:40:08 raspberrypi homebridge[2067]: ? to the local update config store via ?
May 10 21:40:08 raspberrypi homebridge[2067]: ? sudo chown -R $USER:$(id -gn $USER) /home/homebridge/.config ?
May 10 21:40:08 raspberrypi homebridge[2067]: [2017-5-10 21:40:08] Loaded plugin: homebridge-broadlink-rm
May 10 21:40:08 raspberrypi homebridge[2067]: [2017-5-10 21:40:08] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
May 10 21:40:08 raspberrypi homebridge[2067]: [2017-5-10 21:40:08] ---
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] Loaded plugin: homebridge-synology
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] Registering accessory 'homebridge-synology.Synology'
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] ---
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] Loaded config.json with 1 accessories and 1 platforms.
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] Loading 1 platforms...
May 10 21:40:09 raspberrypi homebridge[2067]: [2017-5-10 21:40:09] [Broadlink RM] Initializing BroadlinkRM platform...
May 10 21:40:09 raspberrypi homebridge[2067]: /usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/mkdirp/index.js:90
May 10 21:40:09 raspberrypi homebridge[2067]: throw err0;
May 10 21:40:09 raspberrypi homebridge[2067]: ^
May 10 21:40:09 raspberrypi homebridge[2067]: Error: EACCES: permission denied, mkdir '/home/homebridge'
May 10 21:40:09 raspberrypi homebridge[2067]: at Object.fs.mkdirSync (fs.js:895:18)
May 10 21:40:09 raspberrypi homebridge[2067]: at sync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/mkdirp/index.js:71:13)
May 10 21:40:09 raspberrypi homebridge[2067]: at sync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/mkdirp/index.js:77:24)
May 10 21:40:09 raspberrypi homebridge[2067]: at Function.sync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/mkdirp/index.js:77:24)
May 10 21:40:09 raspberrypi homebridge[2067]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:600:20)
May 10 21:40:09 raspberrypi homebridge[2067]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:141:14)
May 10 21:40:09 raspberrypi homebridge[2067]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/node-persist.js:37:32)
May 10 21:40:09 raspberrypi homebridge[2067]: at Object.init (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/helpers/persistentState.js:10:15)
May 10 21:40:09 raspberrypi homebridge[2067]: at BroadlinkRMPlatform.HomebridgePlatform (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/platform.js:14:21)
May 10 21:40:09 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
May 10 21:40:09 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
May 10 21:40:19 raspberrypi systemd[1]: homebridge.service holdoff time over, scheduling restart.
