Habe gerade versucht das Plugin zu installieren, aber aus welchem Grund auch immer hat es das nicht gemacht?
pi@raspberrypi:~ $ npm i homebridge-dummy
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:314:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! System Linux 4.19.97-v7+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/pi/node_modules/bluetooth-hci-socket
gyp ERR! node -v v12.19.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/xpc-connection):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for [email protected]: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/bluetooth-hci-socket):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] install: `node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
+ [email protected]
added 7 packages from 7 contributors and audited 299 packages in 67.825s
3 packages are looking for funding
run `npm fund` for details
found 47 vulnerabilities (37 low, 10 high)
run `npm audit fix` to fix them, or `npm audit` for details
pi@raspberrypi:~ $ sudo npm list -g --depth=0
/usr/local/lib
├── [email protected]
└── [email protected]
