Hallo vielleicht kann mir ja jemand helfen.
Meine Homebridge startet nicht mehr und aus dem nachfolgenden Log werde ich nicht schlau.
Vielleicht kann ja jemand helfen bzw. hat eine Idee.
ZitatAlles anzeigenJun 18 09:07:06 raspberrypi homebridge[29943]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 18 09:07:06 raspberrypi homebridge[29943]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
Jun 18 09:07:06 raspberrypi homebridge[29943]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
Jun 18 09:07:06 raspberrypi homebridge[29943]: at Module.load (internal/modules/cjs/loader.js:950:32)
Jun 18 09:07:06 raspberrypi homebridge[29943]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
Jun 18 09:07:06 raspberrypi homebridge[29943]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
Jun 18 09:07:06 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 09:07:06 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jun 18 09:07:10 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jun 18 09:07:10 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jun 18 09:07:11 raspberrypi homebridge[29993]: Initializing HAP-NodeJS v0.9.4...
Jun 18 09:07:12 raspberrypi homebridge[29993]: [18.6.2021, 09:07:12] There was a problem reading your config.json file.
Jun 18 09:07:12 raspberrypi homebridge[29993]: [18.6.2021, 09:07:12] Please try pasting your config.json file here to validate it: http://jsonlint.com
Jun 18 09:07:12 raspberrypi homebridge[29993]: SyntaxError: Unexpected token in JSON at position 2
Jun 18 09:07:12 raspberrypi homebridge[29993]: at JSON.parse (<anonymous>)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Function.loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:212:21)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:92:26)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:79:18)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Module.load (internal/modules/cjs/loader.js:950:32)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
Jun 18 09:07:12 raspberrypi homebridge[29993]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
Jun 18 09:07:12 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 09:07:12 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jun 18 09:07:22 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jun 18 09:07:22 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 3198.
Jun 18 09:07:22 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jun 18 09:07:22 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jun 18 09:07:24 raspberrypi homebridge[30109]: Initializing HAP-NodeJS v0.9.4...
Jun 18 09:07:24 raspberrypi homebridge[30109]: [18.6.2021, 09:07:24] There was a problem reading your config.json file.
Jun 18 09:07:24 raspberrypi homebridge[30109]: [18.6.2021, 09:07:24] Please try pasting your config.json file here to validate it: http://jsonlint.com
Jun 18 09:07:24 raspberrypi homebridge[30109]: SyntaxError: Unexpected token in JSON at position 2
Jun 18 09:07:24 raspberrypi homebridge[30109]: at JSON.parse (<anonymous>)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Function.loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:212:21)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:92:26)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:79:18)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Module.load (internal/modules/cjs/loader.js:950:32)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
Jun 18 09:07:24 raspberrypi homebridge[30109]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
Jun 18 09:07:24 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 09:07:24 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jun 18 09:07:34 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jun 18 09:07:34 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 3199.
Jun 18 09:07:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jun 18 09:07:34 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jun 18 09:07:36 raspberrypi homebridge[30275]: Initializing HAP-NodeJS v0.9.4...
Jun 18 09:07:36 raspberrypi homebridge[30275]: [18.6.2021, 09:07:36] There was a problem reading your config.json file.
Jun 18 09:07:36 raspberrypi homebridge[30275]: [18.6.2021, 09:07:36] Please try pasting your config.json file here to validate it: http://jsonlint.com
Jun 18 09:07:36 raspberrypi homebridge[30275]: SyntaxError: Unexpected token in JSON at position 2
Jun 18 09:07:36 raspberrypi homebridge[30275]: at JSON.parse (<anonymous>)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Function.loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:212:21)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:92:26)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:79:18)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Module.load (internal/modules/cjs/loader.js:950:32)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
Jun 18 09:07:36 raspberrypi homebridge[30275]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
Jun 18 09:07:36 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 09:07:36 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
