Genauso installiere ich es ja..
Kann es vielleicht sein das gyp und HCI was damit zu tun hat? Ich kriege nämlich folgende Meldung bei der Installation
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:196:23)
gyp ERR! stack at ChildProcess.emit (events.js:209:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
gyp ERR! System Linux 4.19.66-v7l+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" "--module_name=binding" "--module_path=/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/lib/binding" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
gyp ERR! cwd /usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket
gyp ERR! node -v v12.9.1
gyp ERR! node-gyp -v v5.0.3
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node --module_name=binding --module_path=/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/lib/binding --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:209:13)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1021:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
node-pre-gyp ERR! System Linux 4.19.66-v7l+
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/@abandonware/bluetooth-hci-socket
node-pre-gyp ERR! node -v v12.9.1
node-pre-gyp ERR! node-pre-gyp -v v0.12.0
node-pre-gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @abandonware/[email protected] install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @abandonware/[email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2019-09-04T09_48_50_861Z-debug.log
und sehe da nix das es installiert ist.
Zudem kommt folgende Meldung wenn ich die HP neustarte:
ERROR LOADING PLUGIN homebridge-mi-flower-care:
[2019-9-4 11:56:03] Error: Cannot find module '@abandonware/bluetooth-hci-socket'
Require stack:
- /usr/local/lib/node_modules/@abandonware/noble/lib/hci-socket/hci.js
- /usr/local/lib/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
- /usr/local/lib/node_modules/@abandonware/noble/lib/resolve-bindings.js
- /usr/local/lib/node_modules/@abandonware/noble/index.js
- /usr/local/lib/node_modules/homebridge-mi-flower-care/node_modules/node-mi-flora/index.js
- /usr/local/lib/node_modules/homebridge-mi-flower-care/index.js
- /usr/local/lib/node_modules/homebridge/lib/plugin.js
- /usr/local/lib/node_modules/homebridge/lib/server.js
- /usr/local/lib/node_modules/homebridge/lib/cli.js
- /usr/local/lib/node_modules/homebridge/bin/homebridge
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:772:15)
at Function.Module._load (internal/modules/cjs/loader.js:677:27)
at Module.require (internal/modules/cjs/loader.js:830:19)
at require (internal/modules/cjs/helpers.js:68:18)
