Benzman81 habe es nun mit Port 8081 eingetragen um Konflikte zu vermeiden. Dennoch kann die HB nicht mehr über den Browser angesprochen werden, sobald ich die Zeilen hinzufüge.
Ob das mit dem Error zusammenhängt den das Log-File schreibt?
Homebridge Log nach restart
Feb 02 20:39:08 raspberrypi homebridge[4024]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Feb 02 20:39:08 raspberrypi homebridge[4024]: [2/2/2020, 20:39:08] Got SIGTERM, shutting down Homebridge...
Feb 02 20:39:10 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Feb 02 20:39:12 raspberrypi homebridge[4024]: [2/2/2020, 20:39:12] [Config] Homebridge Config UI X v4.9.0 is listening on :: port 8080
Feb 02 20:39:13 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Feb 02 20:39:13 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Feb 02 20:39:13 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Feb 02 20:39:13 raspberrypi systemd[1]: homebridge.service: Found left-over process 4044 (homebridge-conf) in control group while starting unit. Ignoring.
Feb 02 20:39:13 raspberrypi systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Feb 02 20:39:13 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Loaded config.json with 6 accessories and 4 platforms.
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] ---
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Loaded plugin: homebridge-config-ui-x
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Registering platform 'homebridge-config-ui-x.config'
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Loaded plugin: homebridge-nukiio
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Registering platform 'homebridge-nukiio.NukiBridge'
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Registering accessory 'homebridge-nukiio.NukiLock'
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Registering accessory 'homebridge-nukiio.NukiOpener'
Feb 02 20:39:15 raspberrypi homebridge[4076]: [2/2/2020, 20:39:15] Registering accessory 'homebridge-nukiio.NukiBridgeMaintainanceSwitch'
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] Loaded plugin: homebridge-rademacher-homepilot
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] Registering platform 'homebridge-rademacher-homepilot.RademacherHomePilot'
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] ---
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] Loaded plugin: homebridge-tuya-lan
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] Registering platform 'homebridge-tuya-lan.TuyaLan'
Feb 02 20:39:16 raspberrypi homebridge[4076]: [2/2/2020, 20:39:16] Loaded plugin: homebridge-weather
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] Registering accessory 'homebridge-weather.Weather'
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] ---
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] Loading 4 platforms...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [Config] Initializing config platform...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [Config] Spawning homebridge-config-ui-x with PID 4105
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [RademacherHomePilot] Initializing RademacherHomePilot platform...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [TuyaLan] Initializing TuyaLan platform...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [NukiBridge] Initializing NukiBridge platform...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] [NukiBridge] Initializing Nuki bridge 'http://192.168.1.59:8081'...
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] Error: EACCES: permission denied, mkdir '/.node-persist'
Feb 02 20:39:18 raspberrypi homebridge[4076]: at Object.mkdirSync (fs.js:823:3)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at sync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/mkdirp/index.js:71:13)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at Function.sync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/mkdirp/index.js:77:24)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/local-storage.js:600:20)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/local-storage.js:141:14)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/node-persist.js:37:32)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at new NukiBridge (/usr/local/lib/node_modules/homebridge-nukiio/src/nuki/NukiBridge.js:48:16)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at new NukiBridgePlatform (/usr/local/lib/node_modules/homebridge-nukiio/src/homekit/NukiBridgePlatform.js:16:21)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:337:32)
Feb 02 20:39:18 raspberrypi homebridge[4076]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Feb 02 20:39:18 raspberrypi homebridge[4076]: [2/2/2020, 20:39:18] Got SIGTERM, shutting down Homebridge...
Feb 02 20:39:22 raspberrypi homebridge[4076]: [2/2/2020, 20:39:22] [Config] Homebridge Config UI X v4.9.0 is listening on :: port 8080
Feb 02 20:39:23 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Feb 02 20:39:23 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Feb 02 20:39:33 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Feb 02 20:39:33 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 1.
Feb 02 20:39:33 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Feb 02 20:39:33 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Loaded config.json with 6 accessories and 4 platforms.
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] ---
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Loaded plugin: homebridge-config-ui-x
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Registering platform 'homebridge-config-ui-x.config'
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Loaded plugin: homebridge-nukiio
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Registering platform 'homebridge-nukiio.NukiBridge'
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Registering accessory 'homebridge-nukiio.NukiLock'
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Registering accessory 'homebridge-nukiio.NukiOpener'
Feb 02 20:39:35 raspberrypi homebridge[4129]: [2/2/2020, 20:39:35] Registering accessory 'homebridge-nukiio.NukiBridgeMaintainanceSwitch'
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] Loaded plugin: homebridge-rademacher-homepilot
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] Registering platform 'homebridge-rademacher-homepilot.RademacherHomePilot'
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] ---
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] Loaded plugin: homebridge-tuya-lan
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] Registering platform 'homebridge-tuya-lan.TuyaLan'
Feb 02 20:39:36 raspberrypi homebridge[4129]: [2/2/2020, 20:39:36] Loaded plugin: homebridge-weather
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] Registering accessory 'homebridge-weather.Weather'
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] ---
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] Loading 4 platforms...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [Config] Initializing config platform...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [Config] Spawning homebridge-config-ui-x with PID 4149
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [RademacherHomePilot] Initializing RademacherHomePilot platform...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [TuyaLan] Initializing TuyaLan platform...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [NukiBridge] Initializing NukiBridge platform...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] [NukiBridge] Initializing Nuki bridge 'http://192.168.1.59:8081'...
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] Error: EACCES: permission denied, mkdir '/.node-persist'
Feb 02 20:39:38 raspberrypi homebridge[4129]: at Object.mkdirSync (fs.js:823:3)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at sync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/mkdirp/index.js:71:13)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at Function.sync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/mkdirp/index.js:77:24)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/local-storage.js:600:20)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/local-storage.js:141:14)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/node-persist/src/node-persist.js:37:32)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at new NukiBridge (/usr/local/lib/node_modules/homebridge-nukiio/src/nuki/NukiBridge.js:48:16)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at new NukiBridgePlatform (/usr/local/lib/node_modules/homebridge-nukiio/src/homekit/NukiBridgePlatform.js:16:21)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:337:32)
Feb 02 20:39:38 raspberrypi homebridge[4129]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Feb 02 20:39:38 raspberrypi homebridge[4129]: [2/2/2020, 20:39:38] Got SIGTERM, shutting down Homebridge...
u.A.: Error beim Erstellen vom Ordner ./.node-persist
