Habe es bereinigt in der config. Leider ohne Erfolg.
Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Mar 4 01:45:50 2020 from 192.168.178.22
Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.
pi@raspberrypi:~ $
pi@raspberrypi:~ $ 1
-bash: 1: command not found
pi@raspberrypi:~ $ sudo systemctl restart homebridge; sudo journalctl -fau homebridge
Warning: The unit file, source configuration file or drop-ins of homebridge.service changed on disk. Run 'systemctl daemon-reload' to reload units.
-- Logs begin at Wed 2020-03-04 00:42:58 CET. --
Mar 04 01:49:20 raspberrypi homebridge[10613]: [3/4/2020, 01:49:20] [Hue] Initializing platform accessory 'Philips hue'...
Mar 04 01:49:20 raspberrypi homebridge[10613]: [3/4/2020, 01:49:20] [Hue] Philips hue: 2 services
Mar 04 01:49:20 raspberrypi homebridge[10613]: [3/4/2020, 01:49:20] [Hue] Initializing platform accessory 'Plug Vitrine'...
Mar 04 01:49:20 raspberrypi homebridge[10613]: [3/4/2020, 01:49:20] [Hue] Initializing platform accessory 'Glasherz'...
Mar 04 01:49:20 raspberrypi homebridge[10613]: [3/4/2020, 01:49:20] [Hue] Initializing platform accessory 'Sauna'...
Mar 04 01:49:24 raspberrypi homebridge[10613]: [3/4/2020, 01:49:23] [Config] Homebridge Config UI X v4.11.0 is listening on :: port 8080
Mar 04 01:49:24 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Mar 04 01:49:24 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Mar 04 01:49:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Mar 04 01:49:34 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Mar 04 01:49:36 raspberrypi homebridge[10719]: [3/4/2020, 01:49:36] Loaded config.json with 6 accessories and 6 platforms.
Mar 04 01:49:36 raspberrypi homebridge[10719]: [3/4/2020, 01:49:36] ---
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Loaded plugin: homebridge-alexa
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Registering platform 'homebridge-alexa.Alexa'
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] ---
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Loaded plugin: homebridge-config-ui-x
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Registering platform 'homebridge-config-ui-x.config'
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Loaded plugin: homebridge-dummy
Mar 04 01:49:38 raspberrypi homebridge[10719]: [3/4/2020, 01:49:38] Registering accessory 'homebridge-dummy.DummySwitch'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Loaded plugin: homebridge-hue
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering platform 'homebridge-hue.Hue'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] ---
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Loaded plugin: homebridge-mobilealerts
Mar 04 01:49:40 raspberrypi homebridge[10719]: homebridge API Version: 2.4
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering platform 'homebridge-mobilealerts.MobileAlerts'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Loaded plugin: homebridge-people
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering platform 'homebridge-people.People'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering accessory 'homebridge-people.PeopleAccessory'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering accessory 'homebridge-people.PeopleAllAccessory'
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Loaded plugin: homebridge-pi
Mar 04 01:49:40 raspberrypi homebridge[10719]: [3/4/2020, 01:49:40] Registering accessory 'homebridge-pi.PiTemperature'
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Loaded plugin: homebridge-samsung-tizen
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Registering platform 'homebridge-samsung-tizen.SamsungTizen'
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] ---
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Loaded plugin: homebridge-tuya-lan
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Registering platform 'homebridge-tuya-lan.TuyaLan'
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] Loading 6 platforms...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing People platform...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'Martin'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'Ramona'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'Sabine'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'Uwe'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'Anyone'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] Initializing platform accessory 'No One'...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [People] WebHook: Started server on port '51828'.
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [Config] Initializing config platform...
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [Config] Spawning homebridge-config-ui-x with PID 10753
Mar 04 01:49:41 raspberrypi homebridge[10719]: [3/4/2020, 01:49:41] [Hue] Initializing Hue platform...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Hue] homebridge-hue v0.11.57, node v12.16.1, homebridge v0.4.52
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Hue] warning: not using recommended homebridge version v0.4.50
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [MobileAlerts] Initializing MobileAlerts platform...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [MobileAlerts] iPhone-ID was set to 666922332141...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [MobileAlerts] Poling Interval not configured properly! >> Using default of 420s...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [MobileAlerts] Fetching Data...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [SamsungTizen] Initializing SamsungTizen platform...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Alexa] Initializing Alexa platform...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Alexa] homebridge-alexa v0.4.52, node v12.16.1, homebridge v0.4.52
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] Loading 6 accessories...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Xiaomi Mi Robot Vaccum 1st Generation] Initializing XiaomiRoborockVacuum accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Raspberry PI Temperatur] Initializing PiTemperature accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [Raspberry PI Temperatur] Model BCM2835/a020d3 Serial 00000000f4550184Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [WT] Initializing DummySwitch accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [WT] Setting switch to true
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [SA] Initializing DummySwitch accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [SA] Setting switch to false
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [SO] Initializing DummySwitch accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [SO] Setting switch to false
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [1 Minute] Initializing DummySwitch accessory...
Mar 04 01:49:42 raspberrypi homebridge[10719]: Load homebridge-tuya-lan.TuyaLan
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] TypeError: Cannot read property 'devices' of null
Mar 04 01:49:42 raspberrypi homebridge[10719]: at new TuyaLan (/usr/local/lib/node_modules/homebridge-tuya-lan/index.js:51:43)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Server._loadDynamicPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:358:30)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:92:8)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Module._compile (internal/modules/cjs/loader.js:1158:30)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1178:10)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Module.load (internal/modules/cjs/loader.js:1002:32)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Function.Module._load (internal/modules/cjs/loader.js:901:14)
Mar 04 01:49:42 raspberrypi homebridge[10719]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [People] Changed occupancy state for Ramonas-iPhone to true. Last successful ping 2020-03-04T01:49:42+01:00 , last webhook none .
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] Got SIGTERM, shutting down Homebridge...
Mar 04 01:49:42 raspberrypi homebridge[10719]: [3/4/2020, 01:49:42] [MobileAlerts] Updating Accessory Data...
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Philips hue: Philips BSB002 bridge v1937045000, api v1.36.0
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Philips hue: 4 accessories
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Initializing platform accessory 'Philips hue'...
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Philips hue: 2 services
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Initializing platform accessory 'Plug Vitrine'...
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Initializing platform accessory 'Glasherz'...
Mar 04 01:49:43 raspberrypi homebridge[10719]: [3/4/2020, 01:49:43] [Hue] Initializing platform accessory 'Sauna'...
Mar 04 01:49:46 raspberrypi homebridge[10719]: [3/4/2020, 01:49:46] [Config] Homebridge Config UI X v4.11.0 is listening on :: port 8080
Mar 04 01:49:47 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Mar 04 01:49:47 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
