Nabend,
habe gerade den zweiten Versuch unternommen Homebridge zu installieren (Smartapfel Homebridge Anleitung). Bin an dem Punkt, wo ich Homebridge starten und mir das Logfile anzeigen lassen soll.
Das klappt aber nicht... :-/
Hab schon zwei Tippfehler in der config.json behoben.
Irgendwo muss noch ein Fehler sein, könnt ihr mir da auf die Sprünge helfen?
Feb 03 22:53:48 raspberrypi homebridge[3321]: [03/02/2021, 22:53:48] There was a problem reading your config.json file.
Feb 03 22:53:48 raspberrypi homebridge[3321]: [03/02/2021, 22:53:48] Please try pasting your config.json file here to validate it: http://jsonlint.com
Feb 03 22:53:48 raspberrypi homebridge[3321]: SyntaxError: Unexpected token h in JSON at position 85
Feb 03 22:53:48 raspberrypi homebridge[3321]: at JSON.parse (<anonymous>)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Function._loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:218:21)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:120:44)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:54:18)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Module.load (internal/modules/cjs/loader.js:928:32)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
Feb 03 22:53:48 raspberrypi homebridge[3321]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
Feb 03 22:53:48 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Feb 03 22:53:48 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
