heute nicht ![]()
Beiträge von det
Kein Plugin aktualisiert,
kein Instanz neustart
Plugin: RingToOpen ungesichert/gesichert funktioniert
APP: Anzeige passt
Plugin: Continous auf ungesichert
Anzeige
Plugin continous gesichert, RingToOpen ungesichert
APP: RingToOpen Timer läuft runter
Sep 25 12:46:37 hbridge3 homebridge[19489]: [2019-9-25 12:46:37] [Nuki] Process lock action '1' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 25 12:46:37 hbridge3 homebridge[19489]: [2019-9-25 12:46:37] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"456335602","deviceType":2,"action":"1"}'.
Sep 25 12:46:42 hbridge3 homebridge[19489]: [2019-9-25 12:46:42] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 25 12:46:42 hbridge3 homebridge[19489]: [2019-9-25 12:46:42] [Nuki] HomeKit state change complete.
Sep 25 12:46:44 hbridge3 homebridge[19489]: [2019-9-25 12:46:44] [Nuki] Cached lock state is isLocked = 'false'.
Sep 25 12:46:45 hbridge3 homebridge[19489]: [2019-9-25 12:46:45] [Nuki] Cached lock state is isLocked = 'false'.
Sep 25 12:46:50 hbridge3 homebridge[19489]: [2019-9-25 12:46:50] [Nuki] Cached lock state is isLocked = 'true'.
Sep 25 12:46:50 hbridge3 homebridge[444]: #033[37m[2019-9-25 12:46:50]#033[39m #033[36m[Uschi Vacuum Cleaner]#033[39m INF getCleaning | rockrobo.vacuum.v1 | Cleaning is false
Sep 25 12:46:50 hbridge3 homebridge[447]: [2019-9-25 12:46:50] [Sony STR-DN1080] Speaker is currently OFF
Sep 25 12:46:52 hbridge3 homebridge[19489]: [2019-9-25 12:46:52] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'false' (Nuki state '3' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 25 12:46:52 hbridge3 homebridge[19489]: [2019-9-25 12:46:52] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'false' and batteryCritical = 'false' and mode = '2'.
jetzt iOS 13.1
Plugin: RingToOpen auf gesichert
APP: RingToOpen weg anzeige normal
Sep 25 12:49:35 hbridge3 homebridge[19489]: [2019-9-25 12:49:35] [Nuki] Process lock action '2' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 25 12:49:35 hbridge3 homebridge[19489]: [2019-9-25 12:49:35] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"2"}'.
Sep 25 12:49:38 hbridge3 homebridge[19489]: [2019-9-25 12:49:38] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 25 12:49:38 hbridge3 homebridge[19489]: [2019-9-25 12:49:38] [Nuki] HomeKit state change complete.
Sep 25 12:49:40 hbridge3 homebridge[19489]: [2019-9-25 12:49:40] [Nuki] Cached lock state is isLocked = 'true'.
Sep 25 12:49:42 hbridge3 homebridge[19489]: [2019-9-25 12:49:42] [Nuki] Cached lock state is isLocked = 'true'.
Sep 25 12:49:49 hbridge3 homebridge[19489]: [2019-9-25 12:49:49] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '45xxxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Continous im Plugin bleibt nicht auf Ungesichert
habe remote mal das Plugin aktualisiert, Version ist immernoch 0.8.0
Wenn Du ringToOpen in der App aktivierst und dann den DauerModus in der App aktivierst und kurz danach dort wieder deaktivierst,
ist dann ringToOpen in der App mit einem laufenden Timer von vorher noch aktiv oder ist dann ring to open auch direkt aus? Bei mir behält er nämlich z.Z. den Status von vorher, sprich ich gehe davon aus, dass ringToOpen dann noch aktiv ist. Müsste ich dann noch anpassen falls sich die App hier anders verhält.
APP: RingToOpen aktiviert-> Timer läuft los, Anzeige RingToOpen
Plugin: RingToOpen auf ungesichert
APP: DauerModus aktiviert -> Timer läuft weiter runter, Anzeige RingToOpen
Plugin: RingToOpen und Continous auf ungesichert
APP: DauerModus deaktiviert -> Timer läuft weiter runter, Anzeige RingToOpen
Plugin: Continous auf gesichert, RingToOpen weiter auf ungesichert
wenn RingToOpen aktiviert ist schein Dauermodus erstmal keine auswirkungen zu haben
DauerModus wieder aktiviert und warten bis Timer beendet ist
Timer abgelaufen (DauerModus an), rest bleibt wie vorher
APP: anzeige RingToOpen, Timer weg
Plugin: Continous und RingToOpen auf ungesichert
APP: DauerModus auf aus, ausgangszustand hergestellt
Plugin alles auf gesichert
Plugin RingToOpen geht auf ungesichert
APP: zeigt RingToOpen an
es kommt 1 Messages
"RingToOpen wurde aufgeschlossen"
Plugin: Continous auf gesichert geht nicht (wieder zurück auf ungesichert)
Sep 24 13:45:46 hbridge3 homebridge[19489]: [2019-9-24 13:45:46] [Nuki] HomeKit change for ring to open back to unlock state complete as continous mode is still active.
Sep 24 13:45:47 hbridge3 homebridge[19489]: [2019-9-24 13:45:47] [Nuki] Cached lock state is isLocked = 'true'.
Sep 24 13:45:49 hbridge3 homebridge[19489]: [2019-9-24 13:45:49] [Nuki] Cached lock state is isLocked = 'true'.
Plugin: RingToOpen auf gesichert geht nicht (wieder zurück auf ungesichert)
Sep 24 13:47:14 hbridge3 homebridge[19489]: [2019-9-24 13:47:14] [Nuki] HomeKit change for ring to open back to unlock state complete as continous mode is still active.
Sep 24 13:47:14 hbridge3 homebridge[19489]: [2019-9-24 13:47:14] [Nuki] Cached lock state is isLocked = 'true'.
Abschalten des aktivierten Continous Mode mit dem Plugin, konnte nur mit NukiAPP wieder deaktiviert werden.
zu2.
RingToOpener aktiviert in der NukiAPP
Dein RingToOpen geht auf ungesichert,
Message kommt: Bridge RingToOpen wurde aufgeschlossen
(NukiAPP zählt 20min runter)
Sep 23 17:02:51 hbridge3 homebridge[20150]: [2019-9-23 17:02:51] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'false' (Nuki state '3' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 23 17:02:51 hbridge3 homebridge[20150]: [2019-9-23 17:02:51] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'false' and batteryCritical = 'false' and mode = '2'.
Sep 23 17:02:52 hbridge3 homebridge[20150]: [2019-9-23 17:02:52] [Nuki] Cached lock state is isLocked = 'false'.
Code{"bridgeType": 1, "ids": {"hardwareId": 11xxxxx, "serverId": 17xxxxx}, "versions": {"firmwareVersion": "1.13.1", "wifiFirmwareVersion": "1.2.0"}, "uptime": 108084, "currentTime": "2019-09-23T15:05:14+00:00", "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": 45xxxxx, "name": "Nuki_Opener_1Bxxxxx", "rssi": -65, "paired": true}, {"deviceType": 0, "nukiId": 36xxxxx, "name": "Nuki_15xxxxx", "rssi": -63, "paired": true}]}20min abgelaufen!!
Dein RingToOpen: springt auf gesichert
NukiAPP: RingToOpen Timer abgelaufen, ist auf aus
Sep 23 17:23:21 hbridge3 homebridge[20150]: [2019-9-23 17:23:21] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 23 17:23:21 hbridge3 homebridge[20150]: [2019-9-23 17:23:21] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
Code{"bridgeType": 1, "ids": {"hardwareId": 11xxxxx, "serverId": 17xxxxx}, "versions": {"firmwareVersion": "1.13.1", "wifiFirmwareVersion": "1.2.0"}, "uptime": 109193, "currentTime": "2019-09-23T15:23:43+00:00", "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": 45xxxxx, "name": "Nuki_Opener_1Bxxxxx", "rssi": -64, "paired": true}, {"deviceType": 0, "nukiId": 36xxxxx, "name": "Nuki_15xxxxx", "rssi": -62, "paired": true}]}NukiAPP Dauermodus auf ein
Dein Dauer modus auf ungesichert
Dein RingToOpen auf gesichert
NukiApp
Dauermodus ein
Anzeige im Kreis RingToOpen
Message HK Bridge Continous Made wurde aufgeschlossen
Sep 23 17:26:38 hbridge3 homebridge[20150]: [2019-9-23 17:26:38] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '3'.
Sep 23 17:26:38 hbridge3 homebridge[20150]: [2019-9-23 17:26:38] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '3'.
Sep 23 17:26:38 hbridge3 homebridge[20150]: [2019-9-23 17:26:38] [Nuki] Cached lock state is isLocked = 'true'.
Sep 23 17:26:39 hbridge3 homebridge[20150]: [2019-9-23 17:26:39] [Nuki] Cached lock state is isLocked = 'true'.
Message ohne das was gemacht wurde
Dein Continous geht auf gesichert
(NukiApp ist immer noch Dauermodus ein)
Sep 23 17:30:02 hbridge3 WiFi_check: process is complete, removing lockfile
Sep 23 17:30:04 hbridge3 homebridge[20150]: [2019-9-23 17:30:04] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 23 17:30:04 hbridge3 homebridge[20150]: [2019-9-23 17:30:04] [Nuki] HomeKit state change complete.
Sep 23 17:30:10 hbridge3 homebridge[444]: #033[37m[2019-9-23 17:30:10]#033[39m #033[36m[Uschi Vacuum Cleaner]#033[39m INF getBattery | rockrobo.vacuum.v1 | Batterylevel is 100%
Sep 23 17:30:10 hbridge3 homebridge[444]: #033[37m[2019-9-23 17:30:10]#033[39m #033[36m[Uschi Vacuum Cleaner]#033[39m INF getBatteryLow | rockrobo.vacuum.v1 | Batterylevel is 100%
Sep 23 17:30:14 hbridge3 homebridge[20150]: [2019-9-23 17:30:14] [Nuki] Cached lock state is isLocked = 'true'.
Dauermodus in NukiAPP auf aus
Sep 23 17:36:04 hbridge3 homebridge[20150]: [2019-9-23 17:36:04] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 23 17:36:04 hbridge3 homebridge[20150]: [2019-9-23 17:36:04] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
Code{"bridgeType": 1, "ids": {"hardwareId": 11xxxxx, "serverId": 17xxxxx}, "versions": {"firmwareVersion": "1.13.1", "wifiFirmwareVersion": "1.2.0"}, "uptime": 109989, "currentTime": "2019-09-23T15:36:59+00:00", "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": 45xxxxx, "name": "Nuki_Opener_1Bxxxxx", "rssi": -64, "paired": true}, {"deviceType": 0, "nukiId": 36xxxxx, "name": "Nuki_15xxxxx", "rssi": -62, "paired": true}]}in Deinem Plugin RingToOpen auf ungesichert
in Deiner App kurz auf ungesichert geht aber sofort zurück aug gesichert
NukiAPP keine Änderungen
Sep 23 17:38:31 hbridge3 homebridge[20150]: [2019-9-23 17:38:31] [Nuki] Process lock action '3' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 23 17:38:31 hbridge3 homebridge[20150]: [2019-9-23 17:38:31] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 23 17:38:32 hbridge3 homebridge[444]: #033[37m[2019-9-23 17:38:32]#033[39m #033[36m[Uschi Vacuum Cleaner]#033[39m INF getBattery | rockrobo.vacuum.v1 | Batterylevel is 100%
Sep 23 17:38:32 hbridge3 homebridge[444]: #033[37m[2019-9-23 17:38:32]#033[39m #033[36m[Uschi Vacuum Cleaner]#033[39m INF getBatteryLow | rockrobo.vacuum.v1 | Batterylevel is 100%
Sep 23 17:38:40 hbridge3 homebridge[20150]: [2019-9-23 17:38:40] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 23 17:38:40 hbridge3 homebridge[20150]: [2019-9-23 17:38:40] [Nuki] HomeKit state change complete.
Sep 23 17:38:41 hbridge3 homebridge[20150]: [2019-9-23 17:38:41] [Nuki] Cached lock state is isLocked = 'true'.
Sep 23 17:38:41 hbridge3 homebridge[20150]: [2019-9-23 17:38:41] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 23 17:38:59 hbridge3 homebridge[20150]: [2019-9-23 17:38:59] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 23 17:38:59 hbridge3 homebridge[20150]: [2019-9-23 17:38:59] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
Code"bridgeType": 1, "ids": {"hardwareId": 110906881, "serverId": 17xxxxx}, "versions": {"firmwareVersion": "1.13.1", "wifiFirmwareVersion": "1.2.0"}, "uptime": 110271, "currentTime": "2019-09-23T15:41:41+00:00", "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": 45xxxxx, "name": "Nuki_Opener_1Bxxx", "rssi": -63, "paired": true}, {"deviceType": 0, "nukiId": 36xxxxx, "name": "Nuki_15xxx", "rssi": -65, "paired": true}]}in Deinem Plugin Continous auf ungesichert
geht wieder zurück auf gesichert
Message HK Bridge Haustür Aufgeschlossen
Message HK Bridge Haustür Abgeschlossen
keine Änderung in NukiAPP
Sep 23 17:44:12 hbridge3 homebridge[20150]: [2019-9-23 17:44:12] [Nuki] Process lock action '3' for Nuki lock '456335602' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 23 17:44:12 hbridge3 homebridge[20150]: [2019-9-23 17:44:12] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 23 17:44:21 hbridge3 homebridge[20150]: [2019-9-23 17:44:21] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 23 17:44:21 hbridge3 homebridge[20150]: [2019-9-23 17:44:21] [Nuki] HomeKit state change complete.
Sep 23 17:44:21 hbridge3 homebridge[20150]: [2019-9-23 17:44:21] [Nuki] Cached lock state is isLocked = 'true'.
Sep 23 17:44:22 hbridge3 homebridge[20150]: [2019-9-23 17:44:22] [Nuki] Cached lock state is isLocked = 'true'.
Sep 23 17:44:22 hbridge3 homebridge[20150]: [2019-9-23 17:44:22] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 23 17:45:02 hbridge3 homebridge[20150]: [2019-9-23 17:45:02] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 23 17:45:02 hbridge3 homebridge[20150]: [2019-9-23 17:45:02] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
Code{"bridgeType": 1, "ids": {"hardwareId": 110906881, "serverId": 17xxx}, "versions": {"firmwareVersion": "1.13.1", "wifiFirmwareVersion": "1.2.0"}, "uptime": 110657, "currentTime": "2019-09-23T15:48:07+00:00", "serverConnected": true, "scanResults": [{"deviceType": 2, "nukiId": 45xxxxx, "name": "Nuki_Opener_1Bxxx", "rssi": -64, "paired": true}, {"deviceType": 0, "nukiId": 36xxxxx, "name": "Nuki_15xxx", "rssi": -67, "paired": true}]}webhok mit http://192.168.23.xxx:8080/info?token=Gs0Dt7 erstellt
hoffe habe nix vergessen
zu 1) Gibt es in der App nur einen Button "Ring to Open", der auch für den Dauermodus genutzt wird ?
RingToOpen ist in der Hauptansicht unten hoch ziehen
oder es ist so konfiguriert das es aktiviert wird wen man den Kreis nach re/li schiebt.
Der Dauermodus ist in den Administrator einstellungen versteckt
Beenden kann man den Dauermodus nur wenn man in den Administrator einstellungen diesen wieder deaktiviert.
RingToOpen kann nicht den Dauermodus und RingToOpen beenden!!
Man muss erst Dauermodus beenden, dann wird RingToOpen auch beendet.
Jetzt kann man mit RingToOpen, RingToOpen aktivieren.
Hoffe das ist verstädlich
1) Was passiert in der Nuki App, wenn Continous ein ist ( und somit ja auch Ring to Open) und man
dann ring to open in der App deaktiviert. Geht dann Continous auch aus? So hab ich das jetzt nämlich
mal im Plugin implementiert, weil es für mich nur so sinn macht.
Sorry etwas genauer, bitte.
wo? Nuki APP oder Plugin?
1. nur Nuki APP
Countinous an -> zeigt RingToOpen (ohne Timer) an
wenn man beenden will, auf RingToOpen geht der Timer rückwerts los , timer läuft ab und geht wieder zu RingToOpen Anzeige
lässt sich nur durch Continous deaktivieren wieder abschalten.
LOGs kann ich nur zu Hause machen!
habe mit der App auf Ring To Open gestellt, da beginnt in der App ein Timer ab zu laufen. So lange wie dies aktiv sein soll
Dein Plugin-Schalter geht auf ungesichert, was auch richtig ist.
Ist die Zeit abgelaufen, geht die APP in normal betrieb.
Dein Plugin-Schalter geht nicht wieder zurück auf gesichert. das ist Falsch!!
schalte in der APP "Dauer modus" ein. Die App zeigt RingToOpen an
Dein Plugin Continous ein, RingToOpen aus, (hier sollte Ring To Open auch auf an gehen)
Dauermodus in APP auf aus, Plugin alle auf gesichert. Das ist richtig
jetzt wieder in der App auf Ring To Open
keine Reaktion bei den Plugin Schaltern!!
HK-APP neu gesartet damit Daten neu gelesen werden, HK-APP geöffnet Haustür kein Schalter auf ungesichert.
in der Nuki APP ist RingToOpen noch aktiv
Sep 22 18:13:20 hbridge3 homebridge[20150]: [2019-9-22 18:13:20] [Nuki] Cached lock state is isLocked = 'true'.
Sep 22 18:13:22 hbridge3 homebridge[20150]: [2019-9-22 18:13:22] [Nuki] Cached lock state is isLocked = 'true'.
RingToOpen in Nuki-APP beendet.
Sep 22 18:16:31 hbridge3 homebridge[20150]: [2019-9-22 18:16:31] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 22 18:16:31 hbridge3 homebridge[20150]: [2019-9-22 18:16:31] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
Dein Plugin, RingToOpen auf ungesichert gesetzt, kommt HK-Message "Haustür wurde aufgeschlossen"
in der Nuki APP kein Änderung der Anzeige
Dein Plugin pringt wieder von selbst auf gesichert zurück
Sep 22 18:18:43 hbridge3 homebridge[20150]: [2019-9-22 18:18:43] [Nuki] Process lock action '3' for Nuki lock '45xxxxx (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 22 18:18:43 hbridge3 homebridge[20150]: [2019-9-22 18:18:43] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 22 18:18:55 hbridge3 homebridge[20150]: [2019-9-22 18:18:54] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 22 18:18:55 hbridge3 homebridge[20150]: [2019-9-22 18:18:55] [Nuki] HomeKit state change complete.
Sep 22 18:18:55 hbridge3 homebridge[20150]: [2019-9-22 18:18:55] [Nuki] Cached lock state is isLocked = 'true'.
Sep 22 18:18:56 hbridge3 homebridge[20150]: [2019-9-22 18:18:56] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 22 18:19:07 hbridge3 homebridge[20150]: [2019-9-22 18:19:07] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 22 18:19:07 hbridge3 homebridge[20150]: [2019-9-22 18:19:07] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
das selbe beim Dauermodus Aktiviren
springt wieder zurück auf gesichert,
Sep 22 18:22:44 hbridge3 homebridge[20150]: [2019-9-22 18:22:44] [Nuki] Process lock action '3' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 22 18:22:44 hbridge3 homebridge[20150]: [2019-9-22 18:22:44] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxx","deviceType":2,"action":"3"}'.
Sep 22 18:22:52 hbridge3 homebridge[20150]: [2019-9-22 18:22:52] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 22 18:22:52 hbridge3 homebridge[20150]: [2019-9-22 18:22:52] [Nuki] HomeKit state change complete.
Sep 22 18:22:53 hbridge3 homebridge[20150]: [2019-9-22 18:22:53] [Nuki] Cached lock state is isLocked = 'true'.
Sep 22 18:22:53 hbridge3 homebridge[20150]: [2019-9-22 18:22:53] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 22 18:24:02 hbridge3 homebridge[20150]: [2019-9-22 18:24:02] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 22 18:24:02 hbridge3 homebridge[20150]: [2019-9-22 18:24:02] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
hoffe es fehlt nix
nochmal Plugin-Update und diesmal reboot des Raspberry gemacht.
PluginVersion 0.8.0
Meine Nuki-Bridge sollte noch die V1 sein.
einmal "Haustür ungesichert" ausgelöst.
Sep 22 16:42:12 hbridge3 homebridge[20150]: [2019-9-22 16:42:12] [Nuki] Request to Nuki bridge 'http://192.168.23.2xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 22 16:42:12 hbridge3 homebridge[20150]: [2019-9-22 16:42:12] [Nuki] HomeKit state change complete.
Sep 22 16:42:12 hbridge3 homebridge[20150]: [2019-9-22 16:42:12] [Nuki] Cached lock state is isLocked = 'true'.
Sep 22 16:42:13 hbridge3 homebridge[20150]: [2019-9-22 16:42:13] [Nuki] Cached lock state is isLocked = 'true'.
Sep 22 16:42:13 hbridge3 homebridge[20150]: [2019-9-22 16:42:13] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 22 16:42:24 hbridge3 homebridge[20150]: [2019-9-22 16:42:24] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '45xxxxx' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 22 16:42:24 hbridge3 homebridge[20150]: [2019-9-22 16:42:24] [Nuki] HomeKit state change by webhook complete. New isRingToOpenLocked = 'true' and batteryCritical = 'false' and mode = '2'.
konnte bis jetzt keinen Absturz sehen!
Deine Schalter Ring To Open und Dauermodus zeigen nur den Akt. Status an ?
Da sie immer wieder zu Rückspringen wen man diese aktiviert und diese Änderung nicht in der Nuki-APP sichtbar ist.
(bei jeder Änderung kommt jeweils die Message "Bridge Haustür wurde aufgeschlossen" und "Bridge Haustür wurde abgeschlossen")
Lassen diese sich auch als Schalter (speziell. zum aktivieren der "Ring To Open Funktion") realisieren?
Komisch ist das heute kein Tür-Öffner (Summer) geht wenn ich auf öffnen im Plugin und in der Nuki-APP gehe, geht.
Mit Ring To Open und dann klingeln geht der Tür-Offner.
Habe mir mal die Unterlagen gezogen von meiner Gegensprechanlage und Nuki Opener.
Ich denke das die Verkabelung noch nicht ganz stimmt. obwohl es funktioniert.
(dummerweise sind heute vom Messgerät die Batterien leer, war ja klar
)Werde die Unterlagen auswerten, und mir nochmal die Verkabelung prüfen.
Falls noch was ist melde ich mich wieder.
Wenn Du was neues hast zum Testen, kein Thema.
Seit dem ich den Opener und das APP Update auf 2.4.0 habe, funktioniert auch das öffnen/schliesen der Wohnungstür (mir SmartLook V2) mit Geofencing wieder hervorragend!
Woran erkenne Ich die Bridge Version?
Vermute es ist V1 da ich nur das SmartLook aktualisiert hatte.
Werde morgen wieder testen.
Vorab schonmal Danke.
Doch nochmal schnell ein Update eingespielt.
Nach Haustür öffnen kommt:
Sep 21 22:17:52 hbridge3 homebridge[12480]: [2019-9-21 22:17:52] [Nuki] HomeKit state change complete.
Sep 21 22:17:53 hbridge3 homebridge[12480]: [2019-9-21 22:17:53] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 21 22:18:02 hbridge3 homebridge[12480]: [2019-9-21 22:18:02] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 21 22:18:02 hbridge3 homebridge[12480]: [2019-9-21 22:18:02] ReferenceError: isLocked is not defined
Sep 21 22:18:02 hbridge3 homebridge[12480]: at NukiOpenerAccessory.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/index.js:325:123)
Sep 21 22:18:02 hbridge3 homebridge[12480]: at NukiBridge.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/nukibridge.js:136:16)
Sep 21 22:18:02 hbridge3 homebridge[12480]: at IncomingMessage.emit (events.js:214:15)
Sep 21 22:18:02 hbridge3 homebridge[12480]: at endReadableNT (_stream_readable.js:1178:12)
Sep 21 22:18:02 hbridge3 homebridge[12480]: at processTicksAndRejections (internal/process/task_queues.js:80:21)
Sep 21 22:18:02 hbridge3 homebridge[12480]: [2019-9-21 22:18:02] Got SIGTERM, shutting down Homebridge...
Sep 21 22:18:07 hbridge3 systemd[1]: homebridge-nuki.service: Main process exited, code=exited, status=143/n/a
Sep 21 22:18:07 hbridge3 systemd[1]: homebridge-nuki.service: Unit entered failed state.
Sep 21 22:18:07 hbridge3 systemd[1]: homebridge-nuki.service: Failed with result 'exit-code'.
Sep 21 22:18:17 hbridge3 systemd[1]: homebridge-nuki.service: Service hold-off time over, scheduling restart.
Sep 21 22:18:17 hbridge3 systemd[1]: Stopped Node.js HomeKit homebridge-nuki.
Sep 21 22:18:17 hbridge3 systemd[1]: Started Node.js HomeKit homebridge-nuki.
Habe aber vorher das Plugin nicht erst deinstalliert.
Habe gerade die Instanz neu gestartet und Haustür geöffnet, habe keinen Absturz gesehen.
Das wird heute nix mehr, mache morgen nochmal in Ruhe von Forn.
habe die Instanz beendet, das Plugin noch deinstalliert neu installiert , die Instanz gestartet
leider weiterhin Abstürze
Sep 21 14:06:34 hbridge3 homebridge[9824]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Sep 21 14:06:34 hbridge3 homebridge[9824]: ??????????????
Sep 21 14:06:34 hbridge3 homebridge[9824]: ? 031-45-134 ?
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] Homebridge is running on port 51834.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockState' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2}'.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Request to Nuki bridge 'http://192.168.23.26:8080' finished with status code '503' and body 'HTTP 503 Unavailable'. null
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Request for lock state aborted. This is no problem and might happen due to canceled request or due to long response time of the Nuki bridge. Using cached value isLocked = 'true'.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Initial is locked request finished.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/callback/list' with '{"token":"Gs0Dt7"}'.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"callbacks": [{"id": 1, "url": "http://192.168.23.230:51827/"},{"id": 2, "url": "http://192.168.23.232:51827/"}]}'. null
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Webhook for plugin already exists.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockState' with '{"token":"Gs0Dt7","nukiId":"36xxxxx","deviceType":0}'.
Sep 21 14:06:37 hbridge3 homebridge[9824]: [2019-9-21 14:06:37] [Nuki] Request to Nuki bridge 'http://192.168.23.xx:8080' finished with status code '200' and body '{"mode": 2, "state": 3, "stateName": "unlocked", "batteryCritical": false, "success": true}'. null
Sep 21 14:06:37 hbridge3 homebridge[9824]: [2019-9-21 14:06:37] [Nuki] Lock state is isLocked = 'false' (Nuki state '3' ) with battery critical = 'false' and mode = '2'
Sep 21 14:06:37 hbridge3 homebridge[9824]: [2019-9-21 14:06:37] [Nuki] Initial is locked request finished.
Sep 21 14:06:39 hbridge3 homebridge[9824]: [2019-9-21 14:06:39] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 14:06:47 hbridge3 homebridge[9824]: #033[0;37m[2019-9-21 14:06:47] #033[0m#033[0;36m[Config-UI34]#033[0m #033[0;33mHomebridge Config UI X v4.6.1 is listening on :: port 8034#033[0m
Sep 21 14:06:52 hbridge3 homebridge[9824]: [2019-9-21 14:06:52] [Nuki] Process lock action '3' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 21 14:06:52 hbridge3 homebridge[9824]: [2019-9-21 14:06:52] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 21 14:07:00 hbridge3 homebridge[9824]: [2019-9-21 14:07:00] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'false' (Nuki state '3' ) for lock '363417349' (instance id '0') with batteryCritical = 'false' and mode = '2'.
Sep 21 14:07:00 hbridge3 homebridge[9824]: [2019-9-21 14:07:00] [Nuki] HomeKit state change by webhook complete. New isLocked = 'false' and batteryCritical = 'false'.
Sep 21 14:07:02 hbridge3 homebridge[9824]: [2019-9-21 14:07:02] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '-1' and body 'undefined'. Error: socket hang up
Sep 21 14:07:02 hbridge3 homebridge[9824]: at connResetException (internal/errors.js:561:14)
Sep 21 14:07:02 hbridge3 homebridge[9824]: at Socket.socketOnEnd (_http_client.js:440:23)
Sep 21 14:07:02 hbridge3 homebridge[9824]: at Socket.emit (events.js:214:15)
Sep 21 14:07:02 hbridge3 homebridge[9824]: at endReadableNT (_stream_readable.js:1178:12)
Sep 21 14:07:02 hbridge3 homebridge[9824]: at processTicksAndRejections (internal/process/task_queues.js:80:21) {
Sep 21 14:07:02 hbridge3 homebridge[9824]: code: 'ECONNRESET'
Sep 21 14:07:02 hbridge3 homebridge[9824]: }
Sep 21 14:07:02 hbridge3 homebridge[9824]: [2019-9-21 14:07:02] [Nuki] An error occured processing open action. Reason: Error: socket hang up
Sep 21 14:07:02 hbridge3 homebridge[9824]: [2019-9-21 14:07:02] [Nuki] HomeKit state change complete.
Sep 21 14:07:02 hbridge3 homebridge[9824]: [2019-9-21 14:07:02] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 14:07:03 hbridge3 homebridge[9824]: [2019-9-21 14:07:03] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 14:07:03 hbridge3 homebridge[9824]: [2019-9-21 14:07:03] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 21 14:07:12 hbridge3 homebridge[9824]: [2019-9-21 14:07:12] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'false' (Nuki state '3' ) for lock '363417349' (instance id '0') with batteryCritical = 'false' and mode = '2'.
Sep 21 14:07:12 hbridge3 homebridge[9824]: [2019-9-21 14:07:12] [Nuki] HomeKit state change by webhook complete. New isLocked = 'false' and batteryCritical = 'false'.
Sep 21 14:07:18 hbridge3 homebridge[9824]: [2019-9-21 14:07:18] [Nuki] Process lock action '3' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.xxx:8080'.
Sep 21 14:07:18 hbridge3 homebridge[9824]: [2019-9-21 14:07:18] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 21 14:07:27 hbridge3 homebridge[9824]: [2019-9-21 14:07:27] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 21 14:07:27 hbridge3 homebridge[9824]: [2019-9-21 14:07:27] [Nuki] HomeKit state change complete.
Sep 21 14:07:27 hbridge3 homebridge[9824]: [2019-9-21 14:07:27] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 14:07:28 hbridge3 homebridge[9824]: [2019-9-21 14:07:28] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 14:07:28 hbridge3 homebridge[9824]: [2019-9-21 14:07:28] [Nuki] HomeKit change for door opener back to locked state complete.
Sep 21 14:07:31 hbridge3 homebridge[7668]: [2019-9-21 14:07:31] [CameraUI] [INFO] Cam-Flur: Snapshot from Cam-Flur at 480x270
Sep 21 14:07:38 hbridge3 homebridge[9824]: [2019-9-21 14:07:38] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'true' (Nuki state '1' ) for lock '456335602' (instance id '1') with batteryCritical = 'false' and mode = '2'.
Sep 21 14:07:38 hbridge3 homebridge[9824]: [2019-9-21 14:07:38] ReferenceError: newHomeKitStateLocked is not defined
Sep 21 14:07:38 hbridge3 homebridge[9824]: at NukiOpenerAccessory.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/index.js:304:95)
Sep 21 14:07:38 hbridge3 homebridge[9824]: at NukiBridge.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/nukibridge.js:136:16)
Sep 21 14:07:38 hbridge3 homebridge[9824]: at IncomingMessage.emit (events.js:214:15)
Sep 21 14:07:38 hbridge3 homebridge[9824]: at endReadableNT (_stream_readable.js:1178:12)
Sep 21 14:07:38 hbridge3 homebridge[9824]: at processTicksAndRejections (internal/process/task_queues.js:80:21)
Sep 21 14:07:38 hbridge3 homebridge[9824]: [2019-9-21 14:07:38] Got SIGTERM, shutting down Homebridge...
Sep 21 14:07:43 hbridge3 systemd[1]: homebridge-nuki.service: Main process exited, code=exited, status=143/n/a
Sep 21 14:07:43 hbridge3 systemd[1]: homebridge-nuki.service: Unit entered failed state.
Sep 21 14:07:43 hbridge3 systemd[1]: homebridge-nuki.service: Failed with result 'exit-code'.
Sep 21 14:06:34 hbridge3 homebridge[9824]: [2019-9-21 14:06:34] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '503' and body 'HTTP 503 Unavailable'. null
Sep 21 14:06:37 hbridge3 homebridge[9824]: [2019-9-21 14:06:37] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"mode": 2, "state": 3, "stateName": "unlocked", "batteryCritical": false, "success": true}'. null
Sep 21 14:06:37 hbridge3 homebridge[7668]: [2019-9-21 14:06:37] [CameraUI] [INFO] Cam-Flur: Snapshot from Cam-Flur at 480x270
wird auch Batterie Status angezeigt?
kann ich bestätigen, geht
werde das Plugin jetzt updaten
erstmal Danke für Deine Arbeit
sorry habe einen Fehler beim installieren:
Fehler gefunden, Plugin ist installiert.
Bei der Anzahl der Geräte ist eins hinzu gekommen.
in der Instanz Nuki ist dies hinzu gekommen
(Wohnungstür ist das SmartLoock 2)
der Inhalt von "Ring To Open"
"Ring To Open" wurde nochmal als separater Schalter hinzugefügt
Was bedeutet der Status der Schalter bei Ring To Open und Continous ?
gesichert = aus ?
demnach dann ungesichert = ein
(kann man den Status der 2 Schalter mit ein/aus Beschriften?)
Hier noch Meldungen die beim ein und aus schalten Ring To Open nahmen
Sep 21 10:33:57 hbridge3 homebridge[20048]: [2019-9-21 10:33:57] [Nuki] Process lock action '3' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.26:8080'.
Sep 21 10:33:57 hbridge3 homebridge[20048]: [2019-9-21 10:33:57] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxx","deviceType":2,"action":"3"}'.
Sep 21 10:33:58 hbridge3 homebridge[20048]: [2019-9-21 10:33:58] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '503' and body 'HTTP 503 Unavailable'. null
Sep 21 10:33:58 hbridge3 homebridge[20048]: [2019-9-21 10:33:58] [Nuki] An error occured processing lock action. Reason: Error: Request to Nuki bridge was not succesful.
Sep 21 10:33:58 hbridge3 homebridge[20048]: at NukiBridge.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/nukibridge.js:399:23)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at Request.self.callback (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:185:22)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at Request.emit (events.js:209:13)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:1157:10)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:1079:12)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at Object.onceWrapper (events.js:298:28)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at IncomingMessage.emit (events.js:214:15)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at endReadableNT (_stream_readable.js:1178:12)
Sep 21 10:33:58 hbridge3 homebridge[20048]: at processTicksAndRejections (internal/process/task_queues.js:80:21)
Sep 21 10:33:58 hbridge3 homebridge[20048]: [2019-9-21 10:33:58] [Nuki] HomeKit state change complete.
Sep 21 10:33:58 hbridge3 homebridge[20048]: [2019-9-21 10:33:58] [Nuki] Cached lock state is isLocked = 'false'.
Sep 21 10:33:59 hbridge3 homebridge[20048]: [2019-9-21 10:33:59] [Nuki] HomeKit change for door latch back to locked state complete.
Sep 21 10:34:01 hbridge3 homebridge[20048]: [2019-9-21 10:34:01] [Nuki] [INFO Nuki WebHook Server] Updated lock state from webhook to isLocked = 'false' (Nuki state '3' ) for lock '363417349' (instance id '0') with batteryCritical = 'false' and mode = '2'.
Sep 21 10:34:01 hbridge3 homebridge[20048]: [2019-9-21 10:34:01] [Nuki] HomeKit state change by webhook complete. New isLocked = 'false' and batteryCritical = 'false'.
Sep 21 10:34:06 hbridge3 homebridge[20048]: [2019-9-21 10:34:06] [Nuki] Cached lock state is isLocked = 'false'.
Sep 21 10:34:08 hbridge3 homebridge[20048]: [2019-9-21 10:34:08] [Nuki] Process lock action '2' for Nuki lock '45xxxxx' (instance id '1') on Nuki bridge 'http://192.168.23.26:8080'.
Sep 21 10:34:08 hbridge3 homebridge[20048]: [2019-9-21 10:34:08] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/lockAction' with '{"token":"Gs0Dt7","nukiId":"45xxxxxx","deviceType":2,"action":"2"}'.
Sep 21 10:34:12 hbridge3 homebridge[20048]: [2019-9-21 10:34:12] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"success": true, "batteryCritical": false}'. null
Sep 21 10:34:12 hbridge3 homebridge[20048]: [2019-9-21 10:34:12] [Nuki] HomeKit state change complete.
Sep 21 10:34:12 hbridge3 homebridge[20048]: [2019-9-21 10:34:12] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 10:34:13 hbridge3 homebridge[20048]: [2019-9-21 10:34:13] [Nuki] Cached lock state is isLocked = 'true'.
Nachtrag:
beim öffnen der Haustür (Summer hat gesummt) ist das Plugin abgestürzt.
(mittlerweile sind es 3 Abstürze)
Wenn der Haustürsummer geht, geht RingToOpen auf ungesichert und danach wieder zurück auf gesichert.
Sep 21 10:41:38 hbridge3 homebridge[32744]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Sep 21 10:41:38 hbridge3 homebridge[32744]: ??????????????
Sep 21 10:41:38 hbridge3 homebridge[32744]: ? 031-45-134 ?
Sep 21 10:41:38 hbridge3 homebridge[32744]: [2019-9-21 10:41:38] Homebridge is running on port 51834.
Sep 21 10:41:38 hbridge3 homebridge[32744]: [2019-9-21 10:41:38] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx8080' on '/lockState' with '{"token":"Gs0Dt7","nukiId":"45xxxxxx","deviceType":2}'.
Sep 21 10:41:41 hbridge3 homebridge[32744]: [2019-9-21 10:41:41] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '200' and body '{"mode": 2, "state": 1, "stateName": "online", "batteryCritical": false, "success": true}'. null
Sep 21 10:41:41 hbridge3 homebridge[32744]: [2019-9-21 10:41:41] [Nuki] Lock state is isLocked = 'true' (Nuki state '1' ) with battery critical = 'false' and mode = '2'
Sep 21 10:41:41 hbridge3 homebridge[32744]: [2019-9-21 10:41:41] [Nuki] Initial is locked request finished.
Sep 21 10:41:41 hbridge3 homebridge[32744]: [2019-9-21 10:41:41] [Nuki] Send request to Nuki bridge 'http://192.168.23.xxx:8080' on '/callback/list' with '{"token":"Gs0Dt7"}'.
Sep 21 10:41:42 hbridge3 homebridge[32744]: [2019-9-21 10:41:42] [Nuki] Request to Nuki bridge 'http://192.168.23.xxx:8080' finished with status code '503' and body 'HTTP 503 Unavailable'. null
Sep 21 10:41:42 hbridge3 homebridge[32744]: [2019-9-21 10:41:42] Error: Request for webhooks failed: Error: Request to Nuki bridge was not succesful.
Sep 21 10:41:42 hbridge3 homebridge[32744]: at NukiBridge.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/nukibridge.js:150:13)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at NukiBridge.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/nukibridge.js:399:7)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at Request.self.callback (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:185:22)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at Request.emit (events.js:209:13)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:1157:10)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-nukiio/node_modules/request/request.js:1079:12)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at Object.onceWrapper (events.js:298:28)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at IncomingMessage.emit (events.js:214:15)
Sep 21 10:41:42 hbridge3 homebridge[32744]: at endReadableNT (_stream_readable.js:1178:12)
Sep 21 10:41:44 hbridge3 homebridge[32744]: [2019-9-21 10:41:44] Got SIGTERM, shutting down Homebridge...
Sep 21 10:41:50 hbridge3 homebridge[32744]: [2019-9-21 10:41:45] [Nuki] Cached lock state is isLocked = 'true'.
Sep 21 10:41:50 hbridge3 systemd[1]: homebridge-nuki.service: Main process exited, code=exited, status=143/n/a
Sep 21 10:41:50 hbridge3 systemd[1]: homebridge-nuki.service: Unit entered failed state.
Sep 21 10:41:50 hbridge3 systemd[1]: homebridge-nuki.service: Failed with result 'exit-code'.
Sep 21 10:41:59 hbridge3 systemd[1]: homebridge-nuki.service: Service hold-off time over, scheduling restart.
Sep 21 10:41:59 hbridge3 systemd[1]: Stopped Node.js HomeKit homebridge-nuki.
Sep 21 10:41:59 hbridge3 systemd[1]: Started Node.js HomeKit homebridge-nuki.
Sep 21 10:42:02 hbridge3 homebridge[1425]: [2019-9-21 10:42:02] Loaded config.json with 0 accessories and 2 platforms.
Sep 21 10:42:02 hbridge3 homebridge[1425]: [2019-9-21 10:42:02] ---
Sep 21 10:42:02 hbridge3 homebridge[1425]: [2019-9-21 10:42:02] Loaded plugin: homebridge-config-ui-x
Sep 21 10:42:02 hbridge3 homebridge[1425]: [2019-9-21 10:42:02] Registering platform 'homebridge-config-ui-x.config'
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Loaded plugin: homebridge-nukiio
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Registering platform 'homebridge-nukiio.NukiBridge'
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Registering accessory 'homebridge-nukiio.NukiLock'
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Registering accessory 'homebridge-nukiio.NukiOpener'
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Registering accessory 'homebridge-nukiio.NukiBridgeMaintainanceSwitch'
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] ---
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Loading 2 platforms...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Initializing NukiBridge platform...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Initializing Nuki bridge 'http://192.168.23.xxx:8080'...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Started server for webhooks on port '51827'.
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Adding webhook for plugin to bridge...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Initialized Nuki bridge.
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Initializing platform accessory 'Wohnungstür'...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Nuki] Initializing platform accessory 'Haustür'...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Config-UI34] Initializing config platform...
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] [Config-UI34] Spawning homebridge-config-ui-x with PID 1633
Sep 21 10:42:03 hbridge3 homebridge[1425]: [2019-9-21 10:42:03] Loading 0 accessories...
Sep 21 10:42:03 hbridge3 homebridge[1425]: Setup Payload:
Sep 21 10:42:03 hbridge3 homebridge[1425]: X-HM://0023ISYWEK5NH
Sep 21 10:42:03 hbridge3 homebridge[1425]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: #033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[40m #033[0m#033[47m #033[0m#033[47m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[40m #033[0m#033[47m #033[0m
Sep 21 10:42:04 hbridge3 homebridge[1425]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Sep 21 10:42:04 hbridge3 homebridge[1425]: ??????????????
Sep 21 10:42:04 hbridge3 homebridge[1425]: ? 031-45-134 ?
Ich habe Tado im einsatz,
muss langsam mal überlegen wie ich die wieder auf winterbetrieb bekomme (total vergessen).
Im ernst keine Probleme oder Ausfälle bis dato.
Ich glaube es war 10s den Knopf gedrückt halten an der Bridge.
Plugin: homebridge-nukiio
mit der APP: myHome
Wie das Leben so spielt:
Opener ist jetzt da,
bei der Einrichtung stimmt die Installations beschreibung nicht mit meinem Inhalt der Gegensprechanlage überein.
Es ist von der Klemme 7 und einem gelben Draht die Rede, beides habe ich nicht.
Support angeschrieben und warte auf Nachricht.
wenn die Batterien schwach sind und getauscht werden müssen gibt es eine Benachrichtigung in der App.. bei mir klappt das bisher super!
und in der homebridge klappt es auch!
Toll
Noch ist der opener nicht da, habe diese Woche spätschicht und wenn er da ist muss er ja auch erstmal eingerichtet sein.
Danach werde ich es testen.
Muss ich die normale Version erst de installieren ?
Was habe ich dann zu erwarten?
2 konfigurationsschalter und 1 aktionsschalter
Das klingt ja schon mal gut, evtl. kannste mit dieses Plugin vergleichen.
die aktuelle Firmware des Schlosses.
Hat aktuell große Probleme, hat auch die Hotline bestätigt
