Keine Ahnung was da jetzt los ist! Ich kann alle Plugins installieren, nur mit Camera-ui gelingt mit das nicht.
Jetzt kommt mit:
das :
Codepi@raspberrypi:~ $ sudo npm i -g --unsafe-perm homebridge-camera-ui@latest npm WARN deprecated [email protected]: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3. npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules npm WARN notsup Unsupported engine for [email protected]: wanted: {"node":"^8.9.1","homebridge":"^0.4.49"} (current: {"node":"12.15.0","npm":"6.13.4"}) npm WARN notsup Not compatible with your version of node/npm: [email protected]die Hombridge startet nicht und das Log zeigt an:
CodeAlles anzeigen-- Logs begin at Sat 2020-02-08 07:30:52 CET. -- Feb 08 07:35:15 raspberrypi homebridge[3606]: '/usr/local/lib/node_modules/h omebridge/lib/plugin.js', Feb 08 07:35:15 raspberrypi homebridge[3606]: '/usr/local/lib/node_modules/h omebridge/lib/server.js', Feb 08 07:35:15 raspberrypi homebridge[3606]: '/usr/local/lib/node_modules/h omebridge/lib/cli.js', Feb 08 07:35:15 raspberrypi homebridge[3606]: '/usr/local/lib/node_modules/h omebridge/bin/homebridge' Feb 08 07:35:15 raspberrypi homebridge[3606]: ] Feb 08 07:35:15 raspberrypi homebridge[3606]: } Feb 08 07:35:15 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Feb 08 07:35:15 raspberrypi systemd[1]: homebridge.service: Failed with result ' exit-code'. Feb 08 07:35:24 raspberrypi systemd[1]: Stopped Node.js HomeKit Server. Feb 08 07:35:24 raspberrypi systemd[1]: Started Node.js HomeKit Server. Feb 08 07:35:25 raspberrypi homebridge[3811]: [2020-2-8 7:35:25] Loaded config.j son with 30 accessories and 7 platforms. Feb 08 07:35:25 raspberrypi homebridge[3811]: [2020-2-8 7:35:25] --- Feb 08 07:35:25 raspberrypi homebridge[3811]: [2020-2-8 7:35:25] Plugin /usr/loc al/lib/node_modules/homebridge-camera-ui requires Node version of ^8.9.1 which d oes not satisfy the current Node version of v12.15.0. You may need to upgrade yo ur installation of Node. Feb 08 07:35:25 raspberrypi homebridge[3811]: [2020-2-8 7:35:25] Loaded plugin: homebridge-camera-ui Feb 08 07:35:25 raspberrypi homebridge[3811]: internal/modules/cjs/loader.js:796 Feb 08 07:35:25 raspberrypi homebridge[3811]: throw err; Feb 08 07:35:25 raspberrypi homebridge[3811]: ^ Feb 08 07:35:25 raspberrypi homebridge[3811]: Error: Cannot find module 'form-da ta' Feb 08 07:35:25 raspberrypi homebridge[3811]: Require stack: Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge-camera-ui/src/accessories/camera.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge-camera-ui/src/platform.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge-camera-ui/index.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge/lib/plugin.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge/lib/server.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge/lib/cli.js Feb 08 07:35:25 raspberrypi homebridge[3811]: - /usr/local/lib/node_modules/home bridge/bin/homebridge Feb 08 07:35:25 raspberrypi homebridge[3811]: at Function.Module._resolveFil ename (internal/modules/cjs/loader.js:793:17) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Function.Module._load (inte rnal/modules/cjs/loader.js:686:27) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Module.require (internal/mo dules/cjs/loader.js:848:19) Feb 08 07:35:25 raspberrypi homebridge[3811]: at require (internal/modules/c js/helpers.js:74:18) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Object.<anonymous> (/usr/lo cal/lib/node_modules/homebridge-camera-ui/src/accessories/camera.js:14:18) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Module._compile (internal/m odules/cjs/loader.js:955:30) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Object.Module._extensions.. js (internal/modules/cjs/loader.js:991:10) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Module.load (internal/modul es/cjs/loader.js:811:32) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Function.Module._load (inte rnal/modules/cjs/loader.js:723:14) Feb 08 07:35:25 raspberrypi homebridge[3811]: at Module.require (internal/mo dules/cjs/loader.js:848:19) { Feb 08 07:35:25 raspberrypi homebridge[3811]: code: 'MODULE_NOT_FOUND', Feb 08 07:35:25 raspberrypi homebridge[3811]: requireStack: [ Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge-camera-ui/src/accessories/camera.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge-camera-ui/src/platform.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge-camera-ui/index.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge/lib/plugin.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge/lib/server.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge/lib/cli.js', Feb 08 07:35:25 raspberrypi homebridge[3811]: '/usr/local/lib/node_modules/h omebridge/bin/homebridge' Feb 08 07:35:25 raspberrypi homebridge[3811]: ] Feb 08 07:35:25 raspberrypi homebridge[3811]: } Feb 08 07:35:25 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Feb 08 07:35:25 raspberrypi systemd[1]: homebridge.service: Failed with result ' exit-code'. Feb 08 07:35:35 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart. Feb 08 07:35:35 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 22. Feb 08 07:35:35 raspberrypi systemd[1]: Stopped Node.js HomeKit Server. Feb 08 07:35:35 raspberrypi systemd[1]: Started Node.js HomeKit Server. Feb 08 07:35:36 raspberrypi homebridge[3937]: [2020-2-8 7:35:36] Loaded config.json with 30 accessories and 7 platforms. Feb 08 07:35:36 raspberrypi homebridge[3937]: [2020-2-8 7:35:36] --- Feb 08 07:35:36 raspberrypi homebridge[3937]: [2020-2-8 7:35:36] Plugin /usr/local/lib/node_modules/homebridge-camera-ui requires Node version of ^8.9.1 which does not satisfy the current Node version of v12.15.0. You may need to upgrade your installation of Node. Feb 08 07:35:36 raspberrypi homebridge[3937]: [2020-2-8 7:35:36] Loaded plugin: homebridge-camera-ui Feb 08 07:35:37 raspberrypi homebridge[3937]: internal/modules/cjs/loader.js:796 Feb 08 07:35:37 raspberrypi homebridge[3937]: throw err; Feb 08 07:35:37 raspberrypi homebridge[3937]: ^ Feb 08 07:35:37 raspberrypi homebridge[3937]: Error: Cannot find module 'form-data' Feb 08 07:35:37 raspberrypi homebridge[3937]: Require stack: Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge-camera-ui/src/accessories/camera.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge-camera-ui/src/platform.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge-camera-ui/index.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge/lib/plugin.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge/lib/server.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge/lib/cli.js Feb 08 07:35:37 raspberrypi homebridge[3937]: - /usr/local/lib/node_modules/homebridge/bin/homebridge Feb 08 07:35:37 raspberrypi homebridge[3937]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:793:17) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Function.Module._load (internal/modules/cjs/loader.js:686:27) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Module.require (internal/modules/cjs/loader.js:848:19) Feb 08 07:35:37 raspberrypi homebridge[3937]: at require (internal/modules/cjs/helpers.js:74:18) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-camera-ui/src/accessories/camera.js:14:18) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Module._compile (internal/modules/cjs/loader.js:955:30) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Module.load (internal/modules/cjs/loader.js:811:32) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Function.Module._load (internal/modules/cjs/loader.js:723:14) Feb 08 07:35:37 raspberrypi homebridge[3937]: at Module.require (internal/modules/cjs/loader.js:848:19) { Feb 08 07:35:37 raspberrypi homebridge[3937]: code: 'MODULE_NOT_FOUND', Feb 08 07:35:37 raspberrypi homebridge[3937]: requireStack: [ Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge-camera-ui/src/accessories/camera.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge-camera-ui/src/platform.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge-camera-ui/index.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge/lib/plugin.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge/lib/server.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge/lib/cli.js', Feb 08 07:35:37 raspberrypi homebridge[3937]: '/usr/local/lib/node_modules/homebridge/bin/homebridge' Feb 08 07:35:37 raspberrypi homebridge[3937]: ] Feb 08 07:35:37 raspberrypi homebridge[3937]: } Feb 08 07:35:37 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Feb 08 07:35:37 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'. ^C
Beiträge von EinMalik
Was mich etwas stört ist, dass Siri sehr langatmig auf den Befehl antwortet, sinngemäß etwa "die Garage wird geöffnet. Frage mich in ein paar Minuten nochmal ob das Öffnen der Garage erfolgt ist". Oder so ähnlich, jedenfalls kann ich auf den zweiten Satz gut verzichten. Kann man Siri das abgewöhnen?
... das wüsste ich auch gerne... *nervt*
dafür gibt es im hue-plugin doch
"wallSwitch": true
hilft zwar nicht dass die Lampen irgendwann als nicht erreichbar erscheinen aber sie sind zumindest nicht angeschalten
Ja das war auch mein erster Gedanke, aber die liebe Frau möchte es dann wenn schon bunt haben. Nach dem Motto ganz oder gar nicht.
=> Shelly RGBW + Einbauspot ?
du könntest 12V-Lampen an einen Shelly anschliessen, dann kannst du diese zumindest smart schalten
... mich würde mal die techn. Begründung für „läuft um Welten besser“ außerhalb DHCP-Bereich interessieren?
Was ist da besser, die WLAN-Verbindungsqualität?
Ich vergebe immer statische IPs von meiner Fritzbox aus. Sollte ja aufs selbe rauskommen?!
Interessant. Das habe ich auch, aber mein Raspi läuft auf 55º. Liegt wahrscheinlich daran, dass er sich in einer warmen Umgebung befindet. Dort war er im Standardgehäuse zwischen 75º und 80º heiß.
... versuch mal deinen Pi auf solche Befestigungswinkel die es im Baumarkt zu kaufen gibt (oder noch in der Garage/Werkstatt-Kruschtelkiste liegen) zu legen... vergrößert die Kühlfläche und die Wärme des Gehäuses wird über die Winkel abgeleitet... hatte dies mal noch als weiteren tweak irgendwo gelesen, selbst aber noch nicht getestet, da nicht für notwendig gehalten
... ich kann das flirc-case empfehlen
mein RPi 4, 4GB läuft auf 42°C
der shelly1 kann 12V DC... evtl geht damit etwas?!?
Jau, bei den Rollläden steht auch immer noch öffnen, statt geöffnet. Wenn das auch so einfach zu lösen wäre.
schon versucht und mal den Rollladen 5x hintereinander auf und zu gemacht.. haha
... mit SD-Karten hatte ich noch nie Probleme
aber ja, funktioniert so wie es soll und homebridge läuft weiterhin... top, danke!
Zitat
Dazu musst du dem User homebridge ein password setzen:
sudo passwd homebridge
ok das erscheint mir eigentlich auch die sinnvollste und einfachste Möglichkeit und war eigentlich auch schon vor Fragestellung mein Favorit... nur bringe ich damit irgendwas in dem homebridge setup durcheinander wenn ich ein Passwort vergebe?
mir fehlt der nötige Befehl um den User Pi ebenso zusätzlich Schreibrechte für das Verzeichnis /var/homebridge zu geben.
Homebridge läuft unter User "homebridge" und die Rechte wurden gemäß Forenanleitung so gesetzt (sudo chown -R homebridge:homebridge /var/homebridge).
Ich möchte jetzt aber via Cyberduck eine Datei in das Verzeichnis kopieren und hab keine Schreibrechte... wo/wie kann ich diese hinzufügen?
Hm bei der Konstellation bin ich überfragt. Bei mir läuft mosquitto auf den hombridge-Pi und das Dafang Plugin empfängt die mqtt topics der cam
Hab es diverse Male mit dem dafang plugin versucht ... bekomme aber keinen Stream auf das Handy.
Deshalb habe ich nochmal dieses PlugIn genommen und da habe ich sowohl ein Still Frame und auch
den Stream laufen ... aber wie kann ich sehen ob der Motion Sensor auch eine Bewegung erkennt und an den MQTT Broker schickt?
lausche mal mit mosquitto_sub -d -v -t \# was so alles an topics anfliegt
ich bin auch gerade dabei eine xiaomifang 1S mit dem dafang plugin zu integrieren. aber wie du schreibst, der stream funktioniert nicht, alles andere aber schon, bekomme ne schöne Homekit-notification gepusht mit Vorschaubild - also auch nicht wirklich zufriedenstellend
Hallo zusammen ...
Habe nun meine beiden Kameras im Homekit/Homebridge danke camera-ui
Aber irgendwie habe ich den Bewegungssensor nicht dazu bekommen?
Wird der bei der Initialisierung der Kamera gleich mit erstellt, oder muss ich den besonders einrichten?
Es sind 2 - Xiaomi Xiaofang 1S die eigentlich ja auch nen eigenen Sensor haben
Muss ich dann unbedingt Telegram nutzen, oder kann ich mir bei Bewegung auch die Push-Nachricht über
das Homekit schicken lassen?
CU und Danke Kai
schon mal mit diesem plugin probiert? -> homebridge-dafang
in Kombi mit den mqtt-Einstellungen...
haben andere zufällig auch den Effekt dass das Shelly-Device von unterwegs im LTE/4g-Netz oftmals mit "keine Antwort" erscheint.
im WLAN dagegen keinerlei Auffälligkeiten, immer erreichbar und schaltbar??
... ich wäre am node für die IP-Camera (rtp stream) interessiert
Konnte ich dort im Wiki nicht wirklich was zu finden
N’Abend!
Also ich habe das plugin nach langem Gewurschtel für meine Combo aus RasPi4+Buster zum laufen gebracht... oder sagen wir so, ich bekomme in der Home app den Screenshot als Vorschaubild angezeigt, beim Klick darauf passiert aber nichts.
Kann mir jmd kurz berichten wie es sich unter einem älteren OS verhält, kommt da das Bild dann als Vollbild im Stream oder bleibt der Screen schwarz?
Wie bekommt man das optimiert/schärfer dargestellt?
geht das hier auch mit einem Shelly 1 mit Standard-FW und 2 Aqara Fensterkontakten via deCONZ?
