es kam die Anzeig homebridge service wurde isntalliert....
Nix geht mehr... der pi läuft
bei isnatllation hat er gesagt ich müsste sudo nutzen... das hab ich getan.... ich find gar keine error in dem log
pi@raspberrypi:~ $ hb-service logs
[12.4.2021, 16:07:56] [HB Supervisor] OS: Linux 4.19.118-v7l+ arm
[12.4.2021, 16:07:56] [HB Supervisor] Node.js v14.16.0 /usr/local/bin/node
[12.4.2021, 16:07:56] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[12.4.2021, 16:07:56] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[12.4.2021, 16:08:00] [Homebridge UI] Homebridge Config UI X v4.41.0 is listening on :: port 8581
[12.4.2021, 16:08:00] [HB Supervisor] Starting Homebridge with extra flags: -I
[12.4.2021, 16:08:00] [HB Supervisor] Started Homebridge v1.3.4 with PID: 1875
[12.4.2021, 16:08:01] [Homebridge UI] Added new user: admin
[12.4.2021, 16:08:01] [Homebridge UI] Username and password have been set to default:
[12.4.2021, 16:08:01] [Homebridge UI] Username: admin
[12.4.2021, 16:08:01] [Homebridge UI] Password: admin
Initializing HAP-NodeJS v0.9.4...
[12.4.2021, 16:08:01] Loaded config.json with 0 accessories and 1 platforms.
[12.4.2021, 16:08:01] ---
[12.4.2021, 16:08:02] Loaded plugin: [email protected]
[12.4.2021, 16:08:02] Registering platform 'homebridge-bravia.BraviaPlatform'
[12.4.2021, 16:08:02] ---
[12.4.2021, 16:08:02] Registering platform 'homebridge-calendar.Calendar'
[12.4.2021, 16:08:03] Loaded plugin: [email protected]
[12.4.2021, 16:08:03] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[12.4.2021, 16:08:03] ---
[12.4.2021, 16:08:03] Registering platform 'homebridge-config-ui-x.config'
[12.4.2021, 16:08:03] Registering platform 'homebridge-denon-tv.DenonTv'
[12.4.2021, 16:08:03] Registering accessory 'homebridge-dummy.DummySwitch'
[12.4.2021, 16:08:04] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[12.4.2021, 16:08:04] ---
[12.4.2021, 16:08:05] Loaded plugin: [email protected]
[12.4.2021, 16:08:05] Registering platform 'homebridge-hue.Hue'
[12.4.2021, 16:08:05] ---
[12.4.2021, 16:08:06] Registering platform 'homebridge-shelly.Shelly'
[12.4.2021, 16:08:06] ---
[12.4.2021, 16:08:07] Loaded plugin: [email protected]
[12.4.2021, 16:08:07] Registering platform 'homebridge-videodoorbell.Video-doorbell'
[12.4.2021, 16:08:07] ---
[12.4.2021, 16:08:07] Loading 1 platforms...
[12.4.2021, 16:08:07] [Config] Initializing config platform...
[12.4.2021, 16:08:07] [Config] Running in Service Mode
Preparing Advertiser for 'Homebridge 3BAB 6D73' using bonjour-hap backend!
Setup Payload:
X-HM://0024JFZRT1Q3L
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 646-85-529 │
Starting to advertise 'Homebridge 3BAB 6D73' using bonjour-hap backend!
[12.4.2021, 16:08:08] Homebridge v1.3.4 (Homebridge 3BAB) is running on port 51897.
[12.4.2021, 16:07:04] [HB Supervisor] OS: Linux 4.19.118-v7l+ arm
[12.4.2021, 16:07:04] [HB Supervisor] Node.js v14.16.0 /usr/local/bin/node
[12.4.2021, 16:07:04] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[12.4.2021, 16:07:04] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[12.4.2021, 16:07:12] [Homebridge UI] Homebridge Config UI X v4.41.0 is listening on :: port 8581
[12.4.2021, 16:07:13] [HB Supervisor] Starting Homebridge with extra flags: -I
[12.4.2021, 16:07:13] [HB Supervisor] Started Homebridge v1.3.4 with PID: 1307
[12.4.2021, 16:07:14] Loaded config.json with 0 accessories and 1 platforms.
[12.4.2021, 16:07:14] ---
[12.4.2021, 16:07:15] Loaded plugin: [email protected]
[12.4.2021, 16:07:15] Registering platform 'homebridge-bravia.BraviaPlatform'
[12.4.2021, 16:07:15] ---
[12.4.2021, 16:07:15] Registering platform 'homebridge-calendar.Calendar'
[12.4.2021, 16:07:16] Loaded plugin: [email protected]
[12.4.2021, 16:07:16] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[12.4.2021, 16:07:16] ---
[12.4.2021, 16:07:16] Registering platform 'homebridge-config-ui-x.config'
[12.4.2021, 16:07:16] Registering platform 'homebridge-denon-tv.DenonTv'
[12.4.2021, 16:07:16] Registering accessory 'homebridge-dummy.DummySwitch'
[12.4.2021, 16:07:18] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[12.4.2021, 16:07:18] ---
[12.4.2021, 16:07:21] Loaded plugin: [email protected]
[12.4.2021, 16:07:21] Registering platform 'homebridge-hue.Hue'
[12.4.2021, 16:07:21] ---
[12.4.2021, 16:07:22] Registering platform 'homebridge-shelly.Shelly'
[12.4.2021, 16:07:22] ---
[12.4.2021, 16:07:25] Loaded plugin: [email protected]
[12.4.2021, 16:07:25] Registering platform 'homebridge-videodoorbell.Video-doorbell'
[12.4.2021, 16:07:25] ---
[12.4.2021, 16:07:25] Loading 1 platforms...
[12.4.2021, 16:07:25] [Config] Initializing config platform...
[12.4.2021, 16:07:25] [Config] Running in Service Mode
Setup Payload:
│ 646-85-529 │
[12.4.2021, 16:07:25] Homebridge v1.3.4 (Homebridge 3BAB) is running on port 51897.
[12.4.2021, 16:14:19] [HB Supervisor] OS: Linux 4.19.118-v7l+ arm
[12.4.2021, 16:14:19] [HB Supervisor] Node.js v14.16.0 /usr/local/bin/node
[12.4.2021, 16:14:19] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[12.4.2021, 16:14:19] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[12.4.2021, 16:14:27] [Homebridge UI] Homebridge Config UI X v4.41.0 is listening on :: port 8581
[12.4.2021, 16:14:28] [HB Supervisor] Starting Homebridge with extra flags: -I
[12.4.2021, 16:14:28] [HB Supervisor] Started Homebridge v1.3.4 with PID: 1267
[12.4.2021, 16:14:29] Loaded config.json with 0 accessories and 1 platforms.
[12.4.2021, 16:14:29] ---
[12.4.2021, 16:14:30] Loaded plugin: [email protected]
[12.4.2021, 16:14:30] Registering platform 'homebridge-bravia.BraviaPlatform'
[12.4.2021, 16:14:30] ---
[12.4.2021, 16:14:30] Registering platform 'homebridge-calendar.Calendar'
[12.4.2021, 16:14:31] Loaded plugin: [email protected]
[12.4.2021, 16:14:31] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[12.4.2021, 16:14:31] ---
[12.4.2021, 16:14:31] Registering platform 'homebridge-config-ui-x.config'
[12.4.2021, 16:14:31] Registering platform 'homebridge-denon-tv.DenonTv'
[12.4.2021, 16:14:31] Registering accessory 'homebridge-dummy.DummySwitch'
[12.4.2021, 16:14:33] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[12.4.2021, 16:14:33] ---
[12.4.2021, 16:14:36] Loaded plugin: [email protected]
[12.4.2021, 16:14:36] Registering platform 'homebridge-hue.Hue'
[12.4.2021, 16:14:36] ---
[12.4.2021, 16:14:37] Registering platform 'homebridge-shelly.Shelly'
[12.4.2021, 16:14:37] ---
[12.4.2021, 16:14:40] Loaded plugin: [email protected]
[12.4.2021, 16:14:40] Registering platform 'homebridge-videodoorbell.Video-doorbell'
[12.4.2021, 16:14:40] ---
[12.4.2021, 16:14:40] Loading 1 platforms...
[12.4.2021, 16:14:40] [Config] Initializing config platform...
[12.4.2021, 16:14:40] [Config] Running in Service Mode
Setup Payload:
│ 646-85-529 │
[12.4.2021, 16:14:40] Homebridge v1.3.4 (Homebridge 3BAB) is running on port 51897.
[12.4.2021, 16:20:46] [HB Supervisor] Stopping services...
[12.4.2021, 16:20:46] Got SIGTERM, shutting down Homebridge...
[12.4.2021, 16:20:51] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
