root@NetRS-Raspi:/home/pi# dmesg /var/log/syslog
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.41-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 SMP Tue Aug 8 16:00:15 BST 2017
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80c6eec0, node_mem_map b9faa000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @b9f64000 s25600 r8192 d23552 u57344
[ 0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936296K/966656K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22168K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c79094 ( 485 kB)
.bss : 0x80c7b000 - 0x80d3da64 ( 779 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000299] Console: colour dummy device 80x30
[ 0.001187] console [tty1] enabled
[ 0.001231] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001299] pid_max: default: 32768 minimum: 301
[ 0.001631] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001673] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002569] Disabling cpuset control group subsystem
[ 0.002727] CPU: Testing write buffer coherency: ok
[ 0.002790] ftrace: allocating 22396 entries in 66 pages
[ 0.049277] CPU0: update cpu_capacity 1024
[ 0.049330] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.049390] Setting up static identity map for 0x100000 - 0x100034
[ 0.051257] CPU1: update cpu_capacity 1024
[ 0.051263] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.051945] CPU2: update cpu_capacity 1024
[ 0.051951] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.052615] CPU3: update cpu_capacity 1024
[ 0.052622] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.052709] Brought up 4 CPUs
[ 0.052882] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.052911] CPU: All CPU(s) started in HYP mode.
[ 0.052937] CPU: Virtualization extensions available.
[ 0.053756] devtmpfs: initialized
[ 0.064828] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.065147] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.065209] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.065768] pinctrl core: initialized pinctrl subsystem
[ 0.066686] NET: Registered protocol family 16
[ 0.068962] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.077747] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.077795] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.077967] Serial: AMBA PL011 UART driver
[ 0.079867] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080413] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.150102] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[ 0.151954] SCSI subsystem initialized
[ 0.152136] usbcore: registered new interface driver usbfs
[ 0.152238] usbcore: registered new interface driver hub
[ 0.152352] usbcore: registered new device driver usb
[ 0.159081] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:01
[ 0.160494] clocksource: Switched to clocksource arch_sys_counter
[ 0.207664] VFS: Disk quotas dquot_6.6.0
[ 0.207775] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.207995] FS-Cache: Loaded
[ 0.208265] CacheFiles: Loaded
[ 0.220341] NET: Registered protocol family 2
[ 0.221275] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.221412] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.221623] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.221737] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.221804] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.222037] NET: Registered protocol family 1
[ 0.222473] RPC: Registered named UNIX socket transport module.
[ 0.222505] RPC: Registered udp transport module.
[ 0.222533] RPC: Registered tcp transport module.
[ 0.222560] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.223511] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.225816] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.241889] FS-Cache: Netfs 'nfs' registered for caching
[ 0.242885] NFS: Registering the id_resolver key type
[ 0.242936] Key type id_resolver registered
[ 0.242964] Key type id_legacy registered
[ 0.245415] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.245559] io scheduler noop registered
[ 0.245589] io scheduler deadline registered (default)
[ 0.245916] io scheduler cfq registered
[ 0.251573] BCM2708FB: allocated DMA memory fa910000
[ 0.251625] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ 0.309455] Console: switching to colour frame buffer device 240x67
[ 0.344859] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.345118] vc-cma: Videocore CMA driver
[ 0.345239] vc-cma: vc_cma_base = 0x00000000
[ 0.345379] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.345535] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.345895] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.361592] brd: module loaded
[ 0.370687] loop: module loaded
[ 0.370822] Loading iSCSI transport class v2.0-870.
[ 0.371525] usbcore: registered new interface driver smsc95xx
[ 0.371709] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.599932] Core Release: 2.80a
[ 0.600042] Setting default values for core params
[ 0.600212] Finished setting default values for core params
[ 0.800790] Using Buffer DMA mode
[ 0.800897] Periodic Transfer Interrupt Enhancement - disabled
[ 0.801067] Multiprocessor Interrupt Enhancement - disabled
[ 0.801229] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.801365] Dedicated Tx FIFOs mode
[ 0.801836] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[ 0.802134] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.802739] dwc_otg: Microframe scheduler enabled
[ 0.802784] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058f7fc
[ 0.802961] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058fb6c length 36
[ 0.803148] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[ 0.803372] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.803550] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.803786] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.803993] Init: Port Power? op_state=1
[ 0.811476] Init: Power Port (0)
[ 0.819037] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.826503] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.834045] usb usb1: Product: DWC OTG Controller
[ 0.841554] usb usb1: Manufacturer: Linux 4.9.41-v7+ dwc_otg_hcd
[ 0.849068] usb usb1: SerialNumber: 3f980000.usb
[ 0.857340] hub 1-0:1.0: USB hub found
[ 0.864784] hub 1-0:1.0: 1 port detected
[ 0.872802] dwc_otg: FIQ enabled
[ 0.872807] dwc_otg: NAK holdoff enabled
[ 0.872811] dwc_otg: FIQ split-transaction FSM enabled
[ 0.872824] Module dwc_common_port init
[ 0.873054] usbcore: registered new interface driver usb-storage
[ 0.880664] mousedev: PS/2 mouse device common for all mice
[ 0.889030] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.896732] bcm2835-cpufreq: min=600000 max=1200000
[ 0.904564] sdhci: Secure Digital Host Controller Interface driver
[ 0.912125] sdhci: Copyright(c) Pierre Ossman
[ 0.919960] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 0.929761] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.937453] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.947620] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.955392] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.963157] usbcore: registered new interface driver usbhid
[ 0.970746] usbhid: USB HID core driver
[ 0.979134] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[ 0.988830] Initializing XFRM netlink socket
[ 0.996505] NET: Registered protocol family 17
[ 1.004231] Key type dns_resolver registered
[ 1.012209] Registering SWP/SWPB emulation handler
[ 1.020563] registered taskstats version 1
[ 1.028486] vc-sm: Videocore shared memory driver
[ 1.036163] [vc_sm_connected_init]: start
[ 1.044235] [vc_sm_connected_init]: end - returning 0
[ 1.057839] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.067274] sdhost: log_buf @ ba907000 (fa907000)
[ 1.095582] Indeed it is in host mode hprt0 = 00021501
[ 1.190524] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.190943] random: fast init done
[ 1.208599] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.216492] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.280644] of_cfs_init
[ 1.288513] of_cfs_init: OK
[ 1.296858] Waiting for root device /dev/mmcblk0p7...
[ 1.297776] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.299792] mmc0: new high speed SDHC card at address 0007
[ 1.300586] mmcblk0: mmc0:0007 SL16G 14.5 GiB
[ 1.304702] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.306301] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.307865] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.310543] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.310717] Indeed it is in host mode hprt0 = 00001101
[ 1.370762] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.378440] mmcblk0: p1 p2 < p5 p6 p7 >
[ 1.477902] mmc1: new high speed SDIO card at address 0001
[ 1.500684] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 1.508469] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 1.529342] devtmpfs: mounted
[ 1.539018] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[ 1.550849] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.558888] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.567802] hub 1-1:1.0: USB hub found
[ 1.575892] hub 1-1:1.0: 5 ports detected
[ 1.900548] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.030896] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.039082] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.050239] smsc95xx v1.0.5
[ 2.136951] systemd[1]: System time before build time, advancing clock.
[ 2.144742] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:af:f9:ac
[ 2.314698] NET: Registered protocol family 10
[ 2.337209] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.376808] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.386572] systemd[1]: Detected architecture arm.
[ 2.426239] systemd[1]: Set hostname to <NetRS-Raspi>.
[ 3.054543] systemd[1]: Configuration file /etc/systemd/system/homebridge.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.063855] systemd[1]: Configuration file /etc/systemd/system/homebridge.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 3.103786] systemd[1]: Created slice User and Session Slice.
[ 3.123853] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.143693] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.163631] systemd[1]: Listening on udev Kernel Socket.
[ 3.183587] systemd[1]: Listening on Syslog Socket.
[ 3.618408] i2c /dev entries driver
[ 3.843267] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 3.983173] systemd-journald[126]: Received request to flush runtime journal from PID 1
[ 4.479387] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.849978] usbcore: registered new interface driver brcmfmac
[ 4.936594] smsc95xx 1-1.1:1.0 enxb827ebaff9ac: renamed from eth0
[ 5.147823] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[ 6.893255] uart-pl011 3f201000.serial: no DMA platform data
[ 7.150911] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.150924] brcmfmac: power management disabled
[ 7.350310] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 7.712772] smsc95xx 1-1.1:1.0 enxb827ebaff9ac: hardware isn't capable of remote wakeup
[ 7.713019] IPv6: ADDRCONF(NETDEV_UP): enxb827ebaff9ac: link is not ready
[ 8.156101] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.332136] Bluetooth: Core ver 2.22
[ 15.332226] NET: Registered protocol family 31
[ 15.332231] Bluetooth: HCI device and connection manager initialized
[ 15.332254] Bluetooth: HCI socket layer initialized
[ 15.332269] Bluetooth: L2CAP socket layer initialized
[ 15.332303] Bluetooth: SCO socket layer initialized
[ 15.372562] Bluetooth: HCI UART driver ver 2.3
[ 15.372576] Bluetooth: HCI UART protocol H4 registered
[ 15.372581] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.372751] Bluetooth: HCI UART protocol Broadcom registered
[ 15.890388] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.890398] Bluetooth: BNEP filters: protocol multicast
[ 15.890414] Bluetooth: BNEP socket layer initialized
[ 16.205501] Bluetooth: RFCOMM TTY layer initialized
[ 16.205543] Bluetooth: RFCOMM socket layer initialized
[ 16.205580] Bluetooth: RFCOMM ver 1.11
[ 24.325647] fuse init (API version 7.26)
[ 28.674876] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 43.395397] random: crng init done
[ 44.817563] NET: Registered protocol family 38
