Kannst du mal probieren, den Zeitplan ganz zu entfernen bzw. den Zeitplan auf EIN und dann ein Zeitprofil mit 30Grad und den ganzen Tag ein.
Eve Thermo - keine Funktion nach erfolgreicher Installation
i already tried to play with schedule on, off.
same results
Sehr sehr merkwürdig. Habt Ihr Euch denn schon an den Support gewendet? Sooo schlecht ist der gar nicht...
yes, but no reply until now
I also contacted the support on Wednesday, but I guess caused by the bank holiday I'm still waiting for a reply.
Motanu200 I have the same model and Firmware Version - how did you get one of your three to work - by accident?
After several install and uninstalls, hard- and soft resets I got none of my three thermos to work.
yes,
first device worked perfect.Second one started to work after pressing OFF / ON mode multiple times.
third one does not want to work at all, I saw that when I remove the battery it open the valve and then it close the valve backopen the valve and then close again after a few seconds
hi MichaDD,
I was able to fix it today. Now it's working. Remove the battery for half an hour
Hope you fix your eve devices.
Regardsyou welcome, i have been contacted by them. But no luck with what they recommended. Soft reset for 15 seconds and hard reset
which were already made multiple times by me.yes, leave the device connected, calibrated, remove one battery for 30 minutes, then mode on / off/ on for maxim heat.
