Hoi zusammen,
ich wollte heute mein System neu aufsetzten und versucht das Openhab-Complete Plugin zu installieren.
Leider bekomme ich immer die Fehlermeldung und finde nix, was mir dabei helfen könnte.
pi@raspberrypi:~ $ sudo npm install -g homebridge-openhab2-complete
> [email protected] install /usr/local/lib/node_modules/homebridge-openhab2-complete/node_modules/sleep
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/12.0.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/homebridge-openhab2-complete/node_modules/sleep/.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/homebridge-openhab2-complete/node_modules/sleep/.node-gyp'
gyp ERR! System Linux 4.19.93-v7+
gyp ERR! cwd /usr/local/lib/node_modules/homebridge-openhab2-complete/node_modules/sleep
gyp ERR! node -v v12.0.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! /root/.npm/_logs/2020-02-04T15_21_58_510Z-debug.log
Kann mir jemand sagen was ich machen kann?
Danke Joe
