Bootloader-Version "2020-09-03" Raspberry Pi 4: Aktueller Bootloader unterstützt nun auch USB-Boot
"Könnte mir jemand Hilfestellung geben wie man da vorgehen muss um das Update auszuführen?"
Siehe
https://www.raspberrypi.org/do…2711_bootloader_config.md
This option may be set to 0 to block self-update without requiring the EEPROM configuration to be updated. This is sometimes useful when updating multiple Pis via network boot because this option can be controlled per Raspberry Pi (e.g. via a serial number filter in config.txt).
Default: 1 (0 in versions prior to 2020-09-03)
Version: 2020-04-16
For network or USB mass storage boot we recommend updating to bootloader version 2020-09-03 and Raspberry Pi OS 2020-08-20 or newer.
The easiest method to update the bootloader with a factory default configuration supporting USB boot is to use the Raspberry Pi Imager.
Use Custom to reformat and flash a blank SD card with the EEPROM update enabling USB MSD boot support.Oder manuell
vcgencmd bootloader_config to check your current configuration and decide whether to use the factory default config or migrate your existing boot settings.......
