ich hänge gerade beim rebooten vom raspberry..
es kommt folgende meldung nachdem ich den raspberry reboote nachdem ich ein plugin installiert habe:
Jan 15 23:04:21 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jan 15 23:04:21 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 4.
Jan 15 23:04:21 raspberrypi homebridge[1292]: [15/01/2021, 23:04:21] Loaded config.json with 1 accessories and 1 platforms.
Jan 15 23:04:22 raspberrypi homebridge[1292]: [15/01/2021, 23:04:22] Loaded plugin: [email protected]
Jan 15 23:04:22 raspberrypi homebridge[1292]: [15/01/2021, 23:04:22] Registering platform 'homebridge-config-ui-x.config'
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] Loaded plugin: [email protected]
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] Plugin 'homebridge-tuya-smartlamp' tried to register with an incorrect plugin identifier: 'homebridge-tuya-smartdevice'. Please report this to the developer!
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] Registering accessory 'homebridge-tuya-smartlamp.TuyaSmartDevice'
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] [Config] Initializing config platform...
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] [Config] Spawning homebridge-config-ui-x with PID 1312
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] [Coffee Machine] Initializing TuyaSmartDevice accessory...
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] TypeError: Key is missing or incorrect.
Jan 15 23:04:24 raspberrypi homebridge[1292]: at new TuyaDevice (/usr/local/lib/node_modules/homebridge-tuya-smartlamp/node_modules/tuyapi/index.js:48:13)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at new TuyaAccessory (/usr/local/lib/node_modules/homebridge-tuya-smartlamp/lib/TuyaAccessory.js:23:21)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at new TuyaOutlet (/usr/local/lib/node_modules/homebridge-tuya-smartlamp/lib/TuyaOutlet.js:13:9)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at new TuyaSmartDevice (/usr/local/lib/node_modules/homebridge-tuya-smartlamp/index.js:48:25)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at /usr/local/lib/node_modules/homebridge/src/server.ts:357:50
Jan 15 23:04:24 raspberrypi homebridge[1292]: at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/src/server.ts:330:29)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:156:12)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Jan 15 23:04:24 raspberrypi homebridge[1292]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 15 23:04:24 raspberrypi homebridge[1292]: [15/01/2021, 23:04:24] Got SIGTERM, shutting down Homebridge...
Jan 15 23:04:28 raspberrypi homebridge[1292]: [15/01/2021, 23:04:28] [Homebridge UI] Homebridge Config UI X v4.36.0 is listening on :: port 8080
weiß jemand was hier zu machen ist?
lg ben
