Ich habe heute meine neue Fritzbox in Betrieb genommen und wollte mal kurz die Geräte umhängen. alles soweit in Ordnung, ausser das Homebridge folgende Fehlermeldung bringt:
Dez 07 22:32:47 raspberrypi homebridge[1352]: [2017-12-7 22:32:47] [Hue] warning: not using recommended node version v8.9.1 LTS
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:47] Loading 3 accessories...
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:48] [Fake Lampe] Initializing FakeBulb accessory...
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:48] [Fake Lampe] Starting a fake bulb device with name 'Lamp1'...
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:48] [Fake Schalter] Initializing DummySwitch accessory...
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:48] [Fake Schalter] Setting switch to false
Dez 07 22:32:48 raspberrypi homebridge[1352]: [2017-12-7 22:32:48] [Delay Schalter] Initializing DelaySwitch accessory...
Dez 07 22:32:48 raspberrypi homebridge[1352]: /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:258
Dez 07 22:32:48 raspberrypi homebridge[1352]: throw new Error("Cannot add a bridged Accessory with the same UUID as another bridged Accessory: " + existing.UUID);
Dez 07 22:32:48 raspberrypi homebridge[1352]: ^
Dez 07 22:32:48 raspberrypi homebridge[1352]: Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 9622f02a-ddfd-4256-a09c-4c9c818ece40
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Bridge.Accessory.addBridgedAccessory (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:258:13)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Server._configCachedPlatformAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:357:18)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:88:8)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Module._compile (module.js:635:30)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Object.Module._extensions..js (module.js:646:10)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Module.load (module.js:554:32)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at tryModuleLoad (module.js:497:12)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Function.Module._load (module.js:489:3)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at Function.Module.runMain (module.js:676:10)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at startup (bootstrap_node.js:187:16)
Dez 07 22:32:48 raspberrypi homebridge[1352]: at bootstrap_node.js:608:3
Dez 07 22:32:48 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
Dez 07 22:32:48 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
Ich denke, dass hier ein Gerät evtl doppelt registriert hat. Wie finde ich am einfachsten heraus, um welches Gerät es sich handelt? Also quasi was sich hinter der UUID verbirgt?
