-- Logs begin at Thu 2016-11-03 18:16:42 CET. --
Mar 22 18:58:32 raspberrypi homebridge[9515]:
Mar 22 18:58:32 raspberrypi homebridge[9515]: [3/22/2019, 6:58:32 PM] Homebridge is running on port 51826.
Mar 22 18:58:35 raspberrypi homebridge[9515]: [3/22/2019, 6:58:35 PM] [homematic-ccu2] NPM 0.0.109 vs Local 0.0.109
Mar 22 18:58:36 raspberrypi homebridge[9515]: [3/22/2019, 6:58:36 PM] [Config] Using Form Authentication
Mar 22 18:58:36 raspberrypi homebridge[9515]: [3/22/2019, 6:58:36 PM] [Config] Console v3.9.7 is listening on port 8080.
Mar 22 19:03:17 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Mar 22 19:03:17 raspberrypi homebridge[9515]: [3/22/2019, 7:03:17 PM] Got SIGTERM, shutting down Homebridge...
Mar 22 19:03:17 raspberrypi homebridge[9515]: [3/22/2019, 7:03:17 PM] [homematic-ccu2] Removing Event Server for Interface BidCos-RF.
Mar 22 19:03:19 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Mar 22 19:03:19 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] Loaded config.json with 0 accessories and 2 platforms.
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] ---
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] Loaded plugin: homebridge-config-ui-x
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] Registering platform 'homebridge-config-ui-x.config'
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] Loaded plugin: homebridge-homematic
Mar 22 19:03:21 raspberrypi homebridge[11047]: [3/22/2019, 7:03:21 PM] Registering platform 'homebridge-homematic.HomeMatic'
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] Loading 2 platforms...
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [Config] Initializing config platform...
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [Config] Spawning homebridge-config-ui-x with PID 11090
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Initializing HomeMatic platform...
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Homematic Plugin Version 0.0.109
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Plugin by thkl https://github.com/thkl
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Homematic is a registered trademark of the EQ-3 AG
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Please report any issues to https://github.com/thkl/homebridge-homematic/issues
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] running in production mode
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] will connect to your ccu at 192.168.178.125
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] using binrpc for communication with BidCos-RF
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] init RPC for BidCos-RF.
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] local ip used : 192.168.1.152. you may change that with local_ip parameter in config
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] Loading 0 accessories...
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] RPC server for interface BidCos-RF. is listening on port 9090.
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] Creating Local HTTP Client for CCU RPC Events
Mar 22 19:03:22 raspberrypi homebridge[11047]: [3/22/2019, 7:03:22 PM] [homematic-ccu2] if PONG is PONG CCU is alive
Mar 22 19:03:25 raspberrypi homebridge[11047]: [3/22/2019, 7:03:25 PM] [Config] Using Form Authentication
Mar 22 19:03:25 raspberrypi homebridge[11047]: [3/22/2019, 7:03:25 PM] [Config] Console v3.9.7 is listening on port 8080.
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] [homematic-ccu2] timeout while executing rega script
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] [homematic-ccu2] Error Error: socket hang upwhile executing rega script string sDeviceId;string sChannelId;boolean df = true;Write('{"devices":[');foreach(sDeviceId, root.Devices().EnumIDs()){object oDevice = dom.GetObject(sDeviceId);if(oDevice){var oInterface = dom.GetObject(oDevice.Interface());if(df) {df = false;} else { Write(',');}Write('{');Write('"id": "' # sDeviceId # '",');Write('"name": "' # oDevice.Name() # '",');Write('"address": "' # oDevice.Address() # '",');Write('"type": "' # oDevice.HssType() # '",');Write('"channels": [');boolean bcf = true;foreach(sChannelId, oDevice.Channels().EnumIDs()){object oChannel = dom.GetObject(sChannelId);if(bcf) {bcf = false;} else {Write(',');}Write('{');Write('"cId": ' # sChannelId # ',');Write('"name": "' # oChannel.Name() # '",');if(oInterface){Write('"intf": "' # oInterface.Name() # '",');Write('"address": "' # oInterface.Name() #'.' # oChannel.Address() # '",');}Write('"type": "' # oChannel.HssType() # '",');Write('"access": "' # oChannel.UserAccessRights(iulOtherThanAdmin)# '"');Write('}');}Write(']}');}}Write(']');var s = dom.GetObject("Homekit");string cid;boolean sdf = true;if (s) {Write(',"subsection":[');foreach(cid, s.EnumUsedIDs()){ if(sdf) {sdf = false;} else { Write(',');}Write(cid);}Write(']');}Write('}');
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] [homematic-ccu2] ok local cache is set to /var/homebridge/ccu.json
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] [homematic-ccu2] Unable to load cached ccu data. giving up
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] [homematic-ccu2] Programs :
Mar 22 19:05:22 raspberrypi homebridge[11047]: Setup Payload:
Mar 22 19:05:22 raspberrypi homebridge[11047]: X-HM://0023ISYWYP74A
Mar 22 19:05:22 raspberrypi homebridge[11047]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Mar 22 19:05:22 raspberrypi homebridge[11047]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Mar 22 19:05:22 raspberrypi homebridge[11047]: ??????????????
Mar 22 19:05:22 raspberrypi homebridge[11047]: ? 031-45-154 ?
Mar 22 19:05:22 raspberrypi homebridge[11047]: [3/22/2019, 7:05:22 PM] Homebridge is running on port 51826.
Mar 22 19:05:25 raspberrypi homebridge[11047]: [3/22/2019, 7:05:25 PM] [homematic-ccu2] NPM 0.0.109 vs Local 0.0.109
