das als Root. Habe den Kill all befehl ausgeführt aber scheint noch irgendwas aktiv zu sein
root@raspberrypi:~# homebridge -U /var/homebridge
[9/13/2018, 6:59:11 PM] Loaded config.json with 1 accessories and 0 platforms.
[9/13/2018, 6:59:11 PM] ---
[9/13/2018, 6:59:11 PM] Loaded plugin: homebridge-avea-bulb
[9/13/2018, 6:59:11 PM] Registering accessory 'homebridge-avea-bulb.AveaBulb'
[9/13/2018, 6:59:11 PM] Loaded plugin: homebridge-config-ui-x
[9/13/2018, 6:59:11 PM] Registering platform 'homebridge-config-ui-x.config'
[9/13/2018, 6:59:11 PM] Loading 0 platforms...
[9/13/2018, 6:59:11 PM] Loading 1 accessories...
[9/13/2018, 6:59:11 PM] [table lamp] Initializing AveaBulb accessory...
Setup Payload:
X-HM://0023ISYWYB3I2
? 031-45-154 ?
Error: listen EADDRINUSE :::51826
at Object.exports._errnoException (util.js:1022:11)
at exports._exceptionWithHostPort (util.js:1045:20)
at Server._listen2 (net.js:1259:14)
at listen (net.js:1295:10)
at Server.listen (net.js:1391:5)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:607:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:128:16)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:97:10)
