Aug 29 20:09:29 raspberrypi homebridge[16440]: at Module.load (internal/modules/cjs/loader.js:985:32)
Aug 29 20:09:29 raspberrypi homebridge[16440]: [8/29/2020, 20:09:29] Got SIGTERM, shutting down Homebridge...
Aug 29 20:09:30 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Aug 29 20:09:32 raspberrypi homebridge[16440]: [8/29/2020, 20:09:32] [Config] Homebridge Config UI X v4.26.0 is listening on :: port 8080
Aug 29 20:09:34 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Aug 29 20:09:34 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Aug 29 20:09:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Aug 29 20:09:34 raspberrypi systemd[1]: homebridge.service: Found left-over process 16460 (node) in control group while starting unit. Ignoring.
Aug 29 20:09:34 raspberrypi systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Aug 29 20:09:34 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Aug 29 20:09:35 raspberrypi homebridge[16491]: [8/29/2020, 20:09:35] Loaded config.json with 0 accessories and 2 platforms.
Aug 29 20:09:35 raspberrypi homebridge[16491]: [8/29/2020, 20:09:35] ---
Aug 29 20:09:35 raspberrypi homebridge[16491]: [8/29/2020, 20:09:35] Loaded plugin: [email protected]
Aug 29 20:09:35 raspberrypi homebridge[16491]: [8/29/2020, 20:09:35] Registering platform 'homebridge-config-ui-x.config'
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Loaded plugin: [email protected]
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Registering accessory 'homebridge-zway.ZWayServer'
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Registering platform 'homebridge-zway.ZWayServer'
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] ---
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Loading 2 platforms...
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] [Config] Initializing config platform...
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] [Config] Spawning homebridge-config-ui-x with PID 16520
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Error loading platform requested in your config.json at position 2
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Error: The requested platform 'Shelly' was not registered by any plugin.
Aug 29 20:09:36 raspberrypi homebridge[16491]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at /usr/local/lib/node_modules/homebridge/src/server.ts:387:37
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Array.forEach (<anonymous>)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:374:27)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:153:29)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
Aug 29 20:09:36 raspberrypi homebridge[16491]: at Module.load (internal/modules/cjs/loader.js:985:32)
Aug 29 20:09:36 raspberrypi homebridge[16491]: [8/29/2020, 20:09:36] Got SIGTERM, shutting down Homebridge...
Aug 29 20:09:39 raspberrypi homebridge[16491]: [8/29/2020, 20:09:39] [Config] Homebridge Config UI X v4.26.0 is listening on :: port 8080
Aug 29 20:09:41 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Aug 29 20:09:41 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Aug 29 20:09:51 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Aug 29 20:09:51 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 1.
Aug 29 20:09:51 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Aug 29 20:09:51 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Aug 29 20:09:52 raspberrypi homebridge[16544]: [8/29/2020, 20:09:52] Loaded config.json with 0 accessories and 2 platforms.
Aug 29 20:09:52 raspberrypi homebridge[16544]: [8/29/2020, 20:09:52] ---
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Loaded plugin: [email protected]
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Registering platform 'homebridge-config-ui-x.config'
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] ---
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Registering accessory 'homebridge-zway.ZWayServer'
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Registering platform 'homebridge-zway.ZWayServer'
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Loading 2 platforms...
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] [Config] Initializing config platform...
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] [Config] Spawning homebridge-config-ui-x with PID 16564
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Error loading platform requested in your config.json at position 2
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Error: The requested platform 'Shelly' was not registered by any plugin.
Aug 29 20:09:53 raspberrypi homebridge[16544]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at /usr/local/lib/node_modules/homebridge/src/server.ts:387:37
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Array.forEach (<anonymous>)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:374:27)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:153:29)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
Aug 29 20:09:53 raspberrypi homebridge[16544]: at Module.load (internal/modules/cjs/loader.js:985:32)
Aug 29 20:09:53 raspberrypi homebridge[16544]: [8/29/2020, 20:09:53] Got SIGTERM, shutting down Homebridge...
Aug 29 20:09:57 raspberrypi homebridge[16544]: [8/29/2020, 20:09:57] [Config] Homebridge Config UI X v4.26.0 is listening on :: port 8080
Aug 29 20:09:58 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Aug 29 20:09:58 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Aug 29 20:10:08 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Aug 29 20:10:08 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 2.
Aug 29 20:10:08 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Aug 29 20:10:08 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Aug 29 20:10:09 raspberrypi homebridge[16588]: [8/29/2020, 20:10:09] Loaded config.json with 0 accessories and 2 platforms.
Aug 29 20:10:09 raspberrypi homebridge[16588]: [8/29/2020, 20:10:09] ---
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Loaded plugin: [email protected]
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Registering platform 'homebridge-config-ui-x.config'
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] ---
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Registering accessory 'homebridge-zway.ZWayServer'
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Registering platform 'homebridge-zway.ZWayServer'
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Loading 2 platforms...
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] [Config] Initializing config platform...
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] [Config] Spawning homebridge-config-ui-x with PID 16608
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Error loading platform requested in your config.json at position 2
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Error: The requested platform 'Shelly' was not registered by any plugin.
Aug 29 20:10:10 raspberrypi homebridge[16588]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at /usr/local/lib/node_modules/homebridge/src/server.ts:387:37
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Array.forEach (<anonymous>)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:374:27)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:153:29)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
Aug 29 20:10:10 raspberrypi homebridge[16588]: at Module.load (internal/modules/cjs/loader.js:985:32)
Aug 29 20:10:10 raspberrypi homebridge[16588]: [8/29/2020, 20:10:10] Got SIGTERM, shutting down Homebridge...
Aug 29 20:10:14 raspberrypi homebridge[16588]: [8/29/2020, 20:10:14] [Config] Homebridge Config UI X v4.26.0 is listening on :: port 8080
Aug 29 20:10:15 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Aug 29 20:10:15 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Aug 29 20:10:26 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Aug 29 20:10:26 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 3.
Aug 29 20:10:26 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Aug 29 20:10:26 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Aug 29 20:10:26 raspberrypi homebridge[16633]: [8/29/2020, 20:10:26] Loaded config.json with 0 accessories and 2 platforms.
Aug 29 20:10:26 raspberrypi homebridge[16633]: [8/29/2020, 20:10:26] ---
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Loaded plugin: [email protected]
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Registering platform 'homebridge-config-ui-x.config'
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] ---
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Registering accessory 'homebridge-zway.ZWayServer'
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Registering platform 'homebridge-zway.ZWayServer'
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Loading 2 platforms...
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] [Config] Initializing config platform...
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] [Config] Spawning homebridge-config-ui-x with PID 16653
Aug 29 20:10:27 raspberrypi homebridge[16633]: [8/29/2020, 20:10:27] Error loading platform requested in your config.json at position 2
Aug 29 20:10:28 raspberrypi homebridge[16633]: [8/29/2020, 20:10:28] Error: The requested platform 'Shelly' was not registered by any plugin.
Aug 29 20:10:28 raspberrypi homebridge[16633]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at /usr/local/lib/node_modules/homebridge/src/server.ts:387:37
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Array.forEach (<anonymous>)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:374:27)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:153:29)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
Aug 29 20:10:28 raspberrypi homebridge[16633]: at Module.load (internal/modules/cjs/loader.js:985:32)
Aug 29 20:10:28 raspberrypi homebridge[16633]: [8/29/2020, 20:10:28] Got SIGTERM, shutting down Homebridge...
Aug 29 20:10:31 raspberrypi homebridge[16633]: [8/29/2020, 20:10:31] [Config] Homebridge Config UI X v4.26.0 is listening on :: port 8080
Aug 29 20:10:33 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Aug 29 20:10:33 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
