Hallo.
Ich habe auch versucht die
Homebridge
zu starten
https://smartapfel.de/homebridge/homebridge-installieren/
Ich bin jetzt ganz unten und bekomme folgende Fehlermeldung
Mar 31 20:22:24 raspberrypi homebridge[17866]: [3/31/2019, 8:22:24 PM]
Mar 31 20:22:24 raspberrypi homebridge[17866]: /usr/local/lib/node_modules/homebridge/lib/server.js:217
Mar 31 20:22:24 raspberrypi homebridge[17866]: throw err;
Mar 31 20:22:24 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Mar 31 20:22:24 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Mar 31 20:22:24 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Mar 31 20:22:34 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Mar 31 20:22:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Mar 31 20:22:34 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Mar 31 20:22:37 raspberrypi homebridge[17888]: [3/31/2019, 8:22:37 PM] There was a problem reading your config.json file.
Mar 31 20:22:37 raspberrypi homebridge[17888]: [3/31/2019, 8:22:37 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
Mar 31 20:22:37 raspberrypi homebridge[17888]: /usr/local/lib/node_modules/homebridge/lib/server.js:217
Mar 31 20:22:37 raspberrypi homebridge[17888]: throw err;
Mar 31 20:22:37 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Mar 31 20:22:37 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Mar 31 20:22:37 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Mar 31 20:22:48 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Mar 31 20:22:48 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Mar 31 20:22:48 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Mar 31 20:22:51 raspberrypi homebridge[17917]: [3/31/2019, 8:22:51 PM] There was a problem reading your config.json file.
Mar 31 20:22:51 raspberrypi homebridge[17917]: [3/31/2019, 8:22:51 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
Mar 31 20:22:51 raspberrypi homebridge[17917]: /usr/local/lib/node_modules/homebridge/lib/server.js:217
Mar 31 20:22:51 raspberrypi homebridge[17917]: throw err;
Mar 31 20:22:51 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Mar 31 20:22:51 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Mar 31 20:22:51 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Ich habe auch mitbekommen beim Installieren das folgende Fehlermeldung kommt:
Last login: Sun Mar 31 19:52:51 on ttys001
PC192-168-2-119:~ maurice$ ssh [email protected]
Enter passphrase for key '/Users/maurice/.ssh/id_rsa':
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Mar 31 19:47:34 2019 from 192.168.2.119
pi@raspberrypi:~ $ sudo apt-get install libavahi-compat-libdnssd-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libavahi-client-dev libavahi-client3 libavahi-common-dev
libavahi-compat-libdnssd1 libdbus-1-dev
The following NEW packages will be installed:
libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 6 newly installed, 0 to remove and 61 not upgraded.
Need to get 474 kB of archives.
After this operation, 1,390 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ramses.wh2.tu-dresden.de/pub/mirrors/raspbian/raspbian stretch/main armhf libavahi-client3 armhf 0.6.32-2 [51.3 kB]
Get:2 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-common-dev armhf 0.6.32-2 [62.6 kB]
Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libdbus-1-dev armhf 1.10.26-0+deb9u1 [201 kB]
Get:4 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-client-dev armhf 0.6.32-2 [56.5 kB]
Get:5 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-compat-libdnssd1 armhf 0.6.32-2 [44.0 kB]
Get:6 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-compat-libdnssd-dev armhf 0.6.32-2 [58.8 kB]
Fetched 474 kB in 2s (216 kB/s)
Selecting previously unselected package libavahi-client3:armhf.
(Reading database ... 34605 files and directories currently installed.)
Preparing to unpack .../0-libavahi-client3_0.6.32-2_armhf.deb ...
Unpacking libavahi-client3:armhf (0.6.32-2) ...
Selecting previously unselected package libavahi-common-dev:armhf.
Preparing to unpack .../1-libavahi-common-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-common-dev:armhf (0.6.32-2) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../2-libdbus-1-dev_1.10.26-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.10.26-0+deb9u1) ...
Selecting previously unselected package libavahi-client-dev:armhf.
Preparing to unpack .../3-libavahi-client-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-client-dev:armhf (0.6.32-2) ...
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
Preparing to unpack .../4-libavahi-compat-libdnssd1_0.6.32-2_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.6.32-2) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev:armhf.
Preparing to unpack .../5-libavahi-compat-libdnssd-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev:armhf (0.6.32-2) ...
Setting up libdbus-1-dev:armhf (1.10.26-0+deb9u1) ...
Setting up libavahi-common-dev:armhf (0.6.32-2) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Setting up libavahi-client3:armhf (0.6.32-2) ...
Setting up libavahi-client-dev:armhf (0.6.32-2) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.32-2) ...
Setting up libavahi-compat-libdnssd-dev:armhf (0.6.32-2) ...
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo apt-get install git
git-man liberror-perl
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
gitweb git-arch git-cvs git-mediawiki git-svn
git git-man liberror-perl
0 upgraded, 3 newly installed, 0 to remove and 61 not upgraded.
Need to get 4,849 kB of archives.
After this operation, 26.4 MB of additional disk space will be used.
Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf liberror-perl all 0.17024-1 [26.9 kB]
Get:2 http://debian.bio.lmu.de/raspbian/raspbian stretch/main armhf git-man all 1:2.11.0-3+deb9u4 [1,433 kB]
Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf git armhf 1:2.11.0-3+deb9u4 [3,390 kB]
Fetched 4,849 kB in 3s (1,437 kB/s)
Selecting previously unselected package liberror-perl.
(Reading database ... 34704 files and directories currently installed.)
Preparing to unpack .../liberror-perl_0.17024-1_all.deb ...
Unpacking liberror-perl (0.17024-1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../git-man_1%3a2.11.0-3+deb9u4_all.deb ...
Unpacking git-man (1:2.11.0-3+deb9u4) ...
Selecting previously unselected package git.
Preparing to unpack .../git_1%3a2.11.0-3+deb9u4_armhf.deb ...
Unpacking git (1:2.11.0-3+deb9u4) ...
Setting up git-man (1:2.11.0-3+deb9u4) ...
Setting up liberror-perl (0.17024-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up git (1:2.11.0-3+deb9u4) ...
pi@raspberrypi:~ $ uname -m
armv7l
pi@raspberrypi:~ $ wget https://nodejs.org/dist/latest/node-v10.4.1-linux-armv7l.tar.gz
--2019-03-31 20:03:04-- https://nodejs.org/dist/latest/node-v10.4.1-linux-armv7l.tar.gz
Resolving nodejs.org (nodejs.org)... 2606:4700:10::6814:162e, 2606:4700:10::6814:172e, 104.20.22.46, ...
Connecting to nodejs.org (nodejs.org)|2606:4700:10::6814:162e|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2019-03-31 20:03:05 ERROR 404: Not Found.
pi@raspberrypi:~ $ wget https://nodejs.org/dist/latest/node-v11.13.0-linux-armv7l.tar.gz
--2019-03-31 20:04:05-- https://nodejs.org/dist/latest/node-v11.13.0-linux-armv7l.tar.gz
HTTP request sent, awaiting response... 200 OK
Length: 19117628 (18M) [application/gzip]
Saving to: ‘node-v11.13.0-linux-armv7l.tar.gz’
node-v11.13.0-linux 100%[===================>] 18.23M 2.36MB/s in 8.3s
2019-03-31 20:04:15 (2.19 MB/s) - ‘node-v11.13.0-linux-armv7l.tar.gz’ saved [19117628/19117628]
pi@raspberrypi:~ $ 1
-bash: 1: command not found
pi@raspberrypi:~ $ tar xf node-v10.4.1-linux-armv7l.tar.gz
tar: node-v10.4.1-linux-armv7l.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
pi@raspberrypi:~ $ tar xf node-v11.103.0-linux-armv7l.tar.gz
tar: node-v11.103.0-linux-armv7l.tar.gz: Cannot open: No such file or directory
pi@raspberrypi:~ $ tar xf node-v11.13.0-linux-armv7l.tar.gz
pi@raspberrypi:~ $ sudo cp -R node-v11.13.0-linux-armv7l/* /usr/local/
pi@raspberrypi:~ $ sudo npm install -g n
/usr/local/bin/n -> /usr/local/lib/node_modules/n/bin/n
+ [email protected]
added 1 package from 4 contributors in 2.065s
pi@raspberrypi:~ $ sudo useradd -m -c "Homebridge Service" -s /bin/bash -G audio,bluetooth,dialout,gpio,video homebridge
pi@raspberrypi:~ $ sudo visudo -f /etc/sudoers.d/homebridge
pi@raspberrypi:~ $ sudo chmod 640 /etc/sudoers.d/homebridge
pi@raspberrypi:~ $ homebridge ALL=(ALL) SETENV:NOPASSWD: ALL
-bash: syntax error near unexpected token `('
pi@raspberrypi:~ $ sudo npm install -g --unsafe-perm homebridge
/usr/local/bin/homebridge -> /usr/local/lib/node_modules/homebridge/bin/homebridge
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/curve25519-n
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/homebridge/node_modules/curve25519-n/build'
CXX(target) Release/obj.target/curve/node_curve.o
../node_curve.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE DoCurve(Nan::NAN_METHOD_ARGS_TYPE)’:
../node_curve.cc:18:79: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
unsigned char* arg0 = (unsigned char*) node::Buffer::Data(info[0]->ToObject());
In file included from /root/.node-gyp/11.13.0/include/node/node.h:63:0,
from ../../nan/nan.h:53,
from ../node_curve.cc:10:
/root/.node-gyp/11.13.0/include/node/v8.h:10257:15: note: declared here
Local<Object> Value::ToObject() const {
../node_curve.cc:19:79: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
unsigned char* arg1 = (unsigned char*) node::Buffer::Data(info[1]->ToObject());
../node_curve.cc:20:79: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
unsigned char* arg2 = (unsigned char*) node::Buffer::Data(info[2]->ToObject());
SOLINK_MODULE(target) Release/obj.target/curve.node
COPY Release/curve.node
make: Leaving directory '/usr/local/lib/node_modules/homebridge/node_modules/curve25519-n/build'
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/ed25519-hap
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/homebridge/node_modules/ed25519-hap/build'
CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
CC(target) Release/obj.target/ed25519/src/ed25519/open.o
CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
CXX(target) Release/obj.target/ed25519/src/ed25519.o
../src/ed25519.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE MakeKeypair(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/ed25519.cc:19:98: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
!Buffer::HasInstance(info[0])) || (Buffer::Length(info[0]->ToObject()) != 32)) {
from ../src/ed25519.cc:1:
../src/ed25519.cc:22:77: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
const unsigned char* seed = (unsigned char*)Buffer::Data(info[0]->ToObject());
../src/ed25519.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Sign(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/ed25519.cc:53:69: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
if ((info.Length() < 2) || (!Buffer::HasInstance(info[0]->ToObject()))) {
../src/ed25519.cc:56:74: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
(Buffer::HasInstance(info[1])) && (Buffer::Length(info[1]->ToObject()) == 32)) {
../src/ed25519.cc:57:72: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
unsigned char* seed = (unsigned char*)Buffer::Data(info[1]->ToObject());
../src/ed25519.cc:65:81: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
(Buffer::HasInstance(info[1])) && (Buffer::Length(info[1]->ToObject()) == 64)) {
../src/ed25519.cc:66:63: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
privateKey = (unsigned char*)Buffer::Data(info[1]->ToObject());
../src/ed25519.cc:68:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
Local<Value> privateKeyBuffer = info[1]->ToObject()->Get(Nan::New<String>("privateKey").ToLocalChecked())->ToObject();
../src/ed25519.cc:68:119: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/ed25519.cc:76:45: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
Handle<Object> message = info[0]->ToObject();
../src/ed25519.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Verify(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/ed25519.cc:101:69: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
if ((info.Length() < 3) || (!Buffer::HasInstance(info[0]->ToObject())) ||
../src/ed25519.cc:102:43: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
(!Buffer::HasInstance(info[1]->ToObject())) || (!Buffer::HasInstance(info[2]->ToObject()))) {
../src/ed25519.cc:102:90: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/ed25519.cc:105:45: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/ed25519.cc:106:47: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
Handle<Object> signature = info[1]->ToObject();
../src/ed25519.cc:107:47: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
Handle<Object> publicKey = info[2]->ToObject();
SOLINK_MODULE(target) Release/obj.target/ed25519.node
COPY Release/ed25519.node
make: Leaving directory '/usr/local/lib/node_modules/homebridge/node_modules/ed25519-hap/build'
+ [email protected]
added 40 packages from 35 contributors in 78.135s
pi@raspberrypi:~ $
Denke mal das wird daran liegen oder?
Ich bin in der Hinsicht Neuling.
bitte um Hilfe
restore
