SeydX
erstmal Danke, super Arbeit.
Beim telegram senden mit Video kommt folgender Fehler:
(die Message selber kommt an)
Danach startet die Instanz neu.
hier die aktuelle config:
"bridge": {
"name": "Homebridge-camera-ui",
"username": "CC:22:3D:E3:CE:42",
"port": 51842,
"pin": "031-45-142"
"description": "This is an sample-config for selective load from det",
"plugins": [
"homebridge-config-ui-x",
"homebridge-camera-ui"
"accessories": [],
"platforms": [
"platform": "CameraUI",
"debug": true,
"videoProcessor": "ffmpeg",
"cameras": [
"name": "Cam-Flur",
"yihackv4": true,
"active": true,
"videoConfig": {
"source": "-rtsp_transport tcp -re -i rtsp://192.168.23.15/ch0_0.h264",
"stillImageSource": "-i rtsp://192.168.23.15/ch0_0.h264",
"maxStreams": 3,
"maxWidth": 1920,
"maxHeight": 1080,
"maxFPS": 30,
"vcodec": "copy"
"mqtt": {
"active": true,
"host": "192.168.23.232",
"port": 1883,
"username": "",
"password": "",
"topicPrefix": "yicam",
"topicSuffix": "motion",
"startMessage": "motion_start",
"stopMessage": "motion_stop",
"recordOnMovement": true,
"recordVideoSize": 30,
"interval": 120
"ftp": {
"active": false,
"username": "pi",
"password": "raspberry",
"secure": false,
"absolutePath": "/var/CAMS/Recordings",
"movementDuration": 20,
"interval": 0
"gui": {
"active": true,
"username": "xxxx",
"password": "xxx",
"port": 3000,
"wsport": 8100,
"removeAfter": 1440
"notifier": {
"active": true,
"token": "xxxxx",
"chatID": "xxxxxx",
"motion_start": "Bewegung *erkannt*",
"motion_stop": "*Keine* Bewegung"
"name": "Config-UI42",
"port": 8042,
"auth": "form",
"theme": "blue-grey",
"restart": "sudo -n systemctl restart homebridge-camera-ui",
"tempUnits": "c",
"sudo": true,
"log": {
"method": "systemd",
"service": "homebridge-camera-ui",
"command": "sudo journalctl -fau homebridge-camera-ui"
"platform": "config"
hier der Inhalt von var/homebridge-camera-ui:
eine /var/homebridge-camera-ui/out_ftp.mp4 existiert nicht, ich möchte auch kein FTP machen.
Mache ich was falsch oder liegt es an der config?
Der selbe Fehler kommt auch wenn eine jpg gesendet werden soll. ("MQTT - recordOnMovement": false,)
Das umbenennen von out.mp4 in /var/homebridge-camera-ui/out_ftp.mp4 nützt auch nichts.
Ach ja, der Schalter Strom (EVE-APP) hat keinerlei Wirkung, auch keine Meldung im Log.
ist nach einem Neustart der Instanz immer auf AUS.
Benutze eine: yi_dome_1080p
