homebridge 1.0.0
Breaking Changes
The minimum Node.js version required is now v10.17.0.
Important notice: The update to the underlying HAP-NodeJS library brings many fixes to the HomeKit Accessory Protocol. One of those is the permission management of people you may have added to your Home. It is strongly recommended that you remove every person added to your Home and then invite them back into your home. This will ensure that permissions for all people in your home are downgraded correctly.
#2481 - Platforms will no longer load unless they have been explicitly configured in the config.json
#2482 - Dropped support for the BridgeSetupManager
If you encounter any issues in v1.0.0 you can rollback to v0.4.53 using this command:
sudo npm install -g --unsafe-perm [email protected]
Notable Changes
#2476 - Project converted to Typescript by @Supereg
Homebridge API version was bumped to 2.5 with the following additions:The signatures of registerAccessory and registerPlatformhave been adjusted. The plugin name, which was passed as the first argument, can now be left out and will be determined automatically by homebridge.
The PlatformAccessory class received a new method configureController which can be used to access the new Controller API (used for Apple TV Remotes and Cameras) introduced with HAP-NodeJS 0.6.0
Cameras can now be added to the bridge using a DynamicPlatformPlugin and the methods configureCameraSource or configureController of the PlatformAccessory (removing the need to create an external accessory)
The hidden service and primary service properties are now properly restored for cached accessories
#2391 - HAP-NodeJS
updated to 0.6.0 with some changes highlighted here:HAP-NodeJS was converted to Typescript as well (thanks to @hassankhan)
Support for exposing Cameras through a Bridge was added
Support for Apple TV Remotes (with and without Siri Voice transmission) using the new RemoteController API
Introduction of the new CameraController API which improves on the existing API and opens the way for a possible future introduction of an API for HomeKit Secure Video
Introduced new APIs to mark a service as primary service
Added new characteristic property adminOnlyAccess to limit certain access rights to the home-owner
Added new services and characteristics for:HomeKit Routers (WiFiRouter and WiFiSatelliteservices)
HomeKit Secure Video (CameraOperatingMode and CameraEventRecordingManagement services)
AccessControl service
SmartSpeaker service
PowerManagement service
TransferTransportManagement service
Updated to HAP Protocol Version 1.1.0:Support of the HomeKit Data Stream (HDS) protocol (used by Remotes and Secure Video)
Support for Timed Writes and Write Responses
Fixed a bug in the encryption layer, which would sometimes encrypt events in the wrong order causing corrupted responses.
This issue typically affected service which expose their state using 'target' characteristics
and 'current' characteristics like Doors, Locks and Windows.
Improved HAP specification compatibility, while noting the following changes affecting compatibility:For /characteristics PUT request the HAP server will return 204 No Content if all characteristic writes succeeded and 207 Multi-Status if at least one write failed or when a write-response is delivered.
For /characteristics GET request the HAP server will return 200 Success if all characteristic reads succeeded and 207 Multi-Status if at least one write failed.
The HAP server will now return short UUIDs for Apple predefined services and characteristics for the /accessories route.
Many, many more bug fixes and improvements.
Other Changes
Homebridge now exports TypeScript types that can be used in the development of plugins.See the homebridge-examples repo for examples of how to do this.
We also have create a plugin template you can use as a base for your own plugins.
