Hab vorhin das Eufy Security Plugin zum Testen installiert, nach dem es nicht richtig lief habe ich es deinstalliert.
Seit dem startet die Homebridge nicht mehr.
Anbei mein Log, wäre um jede Hilfe dankbar.
Feb 18 20:18:43 raspberrypi homebridge[6111]: [18/02/2021, 20:18:43] Homebridge is running on port 51826.
Feb 18 20:18:44 raspberrypi homebridge[6111]: [18/02/2021, 20:18:44] [EufySecurityHomebridgePlugin] failed to register push token Error: Request failed: https://security-app-eu.eufylife.com/v1/passport/login -> 100028 - Failed to request.
Feb 18 20:18:44 raspberrypi homebridge[6111]: at /usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/http/http.utils.js:24:15
Feb 18 20:18:44 raspberrypi homebridge[6111]: at Generator.next (<anonymous>)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at fulfilled (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/http/http.utils.js:5:58)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at processTicksAndRejections (internal/process/task_queues.js:93:5)
Feb 18 20:18:44 raspberrypi homebridge[6111]: (node:6111) UnhandledPromiseRejectionWarning: Error: Request failed: https://security-app-eu.eufylife.com/v1/passport/login -> 100028 - Failed to request.
Feb 18 20:18:44 raspberrypi homebridge[6111]: (Use `node --trace-warnings ...` to show where the warning was created)
Feb 18 20:18:44 raspberrypi homebridge[6111]: (node:6111) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.htm…unhandled_rejections_mode). (rejection id: 1)
Feb 18 20:18:44 raspberrypi homebridge[6111]: (node:6111) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Feb 18 20:18:44 raspberrypi homebridge[6111]: [18/02/2021, 20:18:44] TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received undefined
Feb 18 20:18:44 raspberrypi homebridge[6111]: at Hash.update (internal/crypto/hash.js:84:11)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at Object.generate (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/util/uuid.ts:9:11)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClient.callback (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/src/platform.ts:134:46)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClient.handleParsedMessage (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client.service.js:206:26)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.<anonymous> (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client.service.js:103:63)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.emit (events.js:315:20)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.onGotMessageBytes (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client-parser.service.js:150:14)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.handleFullMessage (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client-parser.service.js:79:22)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.waitForData (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client-parser.service.js:64:18)
Feb 18 20:18:44 raspberrypi homebridge[6111]: at PushClientParser.onGotMessageSize (/usr/local/lib/node_modules/homebridge-plugin-eufy-security/node_modules/eufy-node-client/build/push/push-client-parser.service.js:124:18)
Feb 18 20:18:44 raspberrypi homebridge[6111]: [18/02/2021, 20:18:44] Got SIGTERM, shutting down Homebridge...
Feb 18 20:18:45 raspberrypi homebridge[6111]: [18/02/2021, 20:18:45] [MagicHome-Platform] [ 'Polling Light', 'ACCF239F2950' ]
Feb 18 20:18:45 raspberrypi homebridge[6111]: [18/02/2021, 20:18:45] [MagicHome-Platform] /usr/local/lib/node_modules/homebridge-magichome-platform/src/flux_led.py 192.168.178.48 -i
Feb 18 20:18:45 raspberrypi homebridge[6111]: [18/02/2021, 20:18:45] [MagicHome-Platform] Unknown ID [192.168.178.48] OFF [Color: (26, 5, 0)]
Feb 18 20:18:45 raspberrypi homebridge[6111]: [18/02/2021, 20:18:45] [MagicHome-Platform] [ 'Updating Device', 'ACCF239F2950', { H: 12, S: 100, L: 10 }, false ]
Feb 18 20:18:45 raspberrypi homebridge[6111]: [18/02/2021, 20:18:45] [Homebridge UI] Homebridge Config UI X v4.39.0 is listening on :: port 8080
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] 1 bulbs found
Feb 18 20:18:46 raspberrypi homebridge[6111]: ACCF239F2950=192.168.178.48
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] Saving Lights
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] {"ACCF239F2950":"192.168.178.48","192.168.178.48":"192.168.178.48"}
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] Lights Saved.
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] Discovery Finished
Feb 18 20:18:46 raspberrypi homebridge[6111]: [18/02/2021, 20:18:46] [MagicHome-Platform] { ACCF239F2950: '192.168.178.48', '192.168.178.48': '192.168.178.48' }
Feb 18 20:18:49 raspberrypi homebridge[6111]: [18/02/2021, 20:18:49] [Hue] goodbye
Feb 18 20:18:49 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Feb 18 20:18:49 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Feb 18 20:18:59 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Feb 18 20:18:59 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 4.
Feb 18 20:18:59 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Feb 18 20:18:59 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
