So, zum laufen habe ich sie jetzt bekommen. Mit 2 Fehlern.
1. Fehler:
Nov 11 18:59:35 homebridge homebridge[14381]: [11.11.2020, 18:59:35] [FritzPlatform] Callmonitor connection established with 192.168.5.1:1012
Nov 11 18:59:40 homebridge homebridge[14381]: Failed to process updates. TelegramError: 409: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
Nov 11 18:59:40 homebridge homebridge[14381]: at /usr/local/lib/node_modules/homebridge-fritz-platform/node_modules/telegraf/core/network/client.js:281:17
Nov 11 18:59:40 homebridge homebridge[14381]: at processTicksAndRejections (node:internal/process/task_queues:93:5) {
Nov 11 18:59:40 homebridge homebridge[14381]: code: 409,
Nov 11 18:59:40 homebridge homebridge[14381]: response: {
Nov 11 18:59:40 homebridge homebridge[14381]: ok: false,
Nov 11 18:59:40 homebridge homebridge[14381]: error_code: 409,
Nov 11 18:59:40 homebridge homebridge[14381]: description: 'Conflict: terminated by other getUpdates request; make sure that only one bot instance is running'
Nov 11 18:59:40 homebridge homebridge[14381]: },
Nov 11 18:59:40 homebridge homebridge[14381]: description: 'Conflict: terminated by other getUpdates request; make sure that only one bot instance is running',
Nov 11 18:59:40 homebridge homebridge[14381]: parameters: {},
Nov 11 18:59:40 homebridge homebridge[14381]: on: { method: 'getUpdates?offset=0&limit=100&timeout=30', payload: {} }
2. Fehler:
Die Devices gehen immer offline - online - offline - online.
Nov 11 18:59:58 homebridge homebridge[14381]: [11.11.2020, 18:59:58] [FritzPlatform] Repeater-Emil: Device seems to be offline (router)
Nov 11 18:59:58 homebridge homebridge[14381]: [11.11.2020, 18:59:58] [FritzPlatform] Repeater-Emil Led: Device seems to be offline (led)
Nov 11 18:59:58 homebridge homebridge[14381]: [11.11.2020, 18:59:58] [FritzPlatform] Repeater-Emil Lock: Device seems to be offline (lock)
Nov 11 18:59:58 homebridge homebridge[14381]: [11.11.2020, 18:59:58] [FritzPlatform] Repeater-Emil Dect: Device seems to be offline (dect)
Nov 11 19:00:00 homebridge homebridge[14381]: [11.11.2020, 19:00:00] [FritzPlatform] Fritzbox 7360: Device seems to be offline (router)
Nov 11 19:00:01 homebridge homebridge[14381]: [11.11.2020, 19:00:01] [FritzPlatform] Repeater-Kueche: Device seems to be offline (router)
Nov 11 19:00:01 homebridge homebridge[14381]: [11.11.2020, 19:00:01] [FritzPlatform] Repeater-Kueche Led: Device seems to be offline (led)
Nov 11 19:00:01 homebridge homebridge[14381]: [11.11.2020, 19:00:01] [FritzPlatform] Repeater-Kueche Lock: Device seems to be offline (lock)
Nov 11 19:00:01 homebridge homebridge[14381]: [11.11.2020, 19:00:01] [FritzPlatform] Repeater-Kueche Dect: Device seems to be offline (dect)
Nov 11 19:00:02 homebridge homebridge[14381]: [11.11.2020, 19:00:02] [FritzPlatform] Repeater-Emil: Device seems to be offline (router)
Nov 11 19:00:02 homebridge homebridge[14381]: [11.11.2020, 19:00:02] [FritzPlatform] Repeater-Emil Led: Device seems to be offline (led)
Nov 11 19:00:02 homebridge homebridge[14381]: [11.11.2020, 19:00:02] [FritzPlatform] Repeater-Emil Lock: Device seems to be offline (lock)
Nov 11 19:00:02 homebridge homebridge[14381]: [11.11.2020, 19:00:02] [FritzPlatform] Repeater-Emil Dect: Device seems to be offline (dect)
Nov 11 19:00:03 homebridge homebridge[14381]: [11.11.2020, 19:00:03] [FritzPlatform] Fritzbox 7360: Device seems to be offline (router)
Nov 11 19:00:04 homebridge homebridge[14381]: [11.11.2020, 19:00:04] [FritzPlatform] Repeater-Kueche: Device seems to be offline (router)
Nov 11 19:00:04 homebridge homebridge[14381]: [11.11.2020, 19:00:04] [FritzPlatform] Repeater-Kueche Led: Device seems to be offline (led)
Nov 11 19:00:04 homebridge homebridge[14381]: [11.11.2020, 19:00:04] [FritzPlatform] Repeater-Kueche Lock: Device seems to be offline (lock)
Nov 11 19:00:04 homebridge homebridge[14381]: [11.11.2020, 19:00:04] [FritzPlatform] Repeater-Kueche Dect: Device seems to be offline (dect)
Nov 11 19:00:13 homebridge homebridge[14381]: [11.11.2020, 19:00:13] [FritzPlatform] Repeater-Kueche Lock: Device seems to be offline (lock)
Nov 11 19:00:13 homebridge homebridge[14381]: [11.11.2020, 19:00:13] [FritzPlatform] Repeater-Kueche: Device seems to be offline (router)
Nov 11 19:00:13 homebridge homebridge[14381]: [11.11.2020, 19:00:13] [FritzPlatform] Repeater-Kueche Dect: Device seems to be offline (dect)
Nov 11 19:00:13 homebridge homebridge[14381]: [11.11.2020, 19:00:13] [FritzPlatform] Repeater-Kueche Led: Device seems to be offline (led)
Nov 11 19:00:39 homebridge homebridge[14381]: [11.11.2020, 19:00:39] [FritzPlatform] FritzBox 7590 Led: OFF (led)
Nov 11 19:00:40 homebridge homebridge[14381]: [11.11.2020, 19:00:40] [FritzPlatform] Repeater-Emil: Device seems to be offline (router)
Nov 11 19:00:40 homebridge homebridge[14381]: [11.11.2020, 19:00:40] [FritzPlatform] Repeater-Emil Led: Device seems to be offline (led)
Nov 11 19:00:40 homebridge homebridge[14381]: [11.11.2020, 19:00:40] [FritzPlatform] Repeater-Emil Lock: Device seems to be offline (lock)
Nov 11 19:00:40 homebridge homebridge[14381]: [11.11.2020, 19:00:40] [FritzPlatform] Repeater-Emil Dect: Device seems to be offline (dect)
Nov 11 19:00:41 homebridge homebridge[14381]: [11.11.2020, 19:00:41] [FritzPlatform] Repeater-Kueche Lock: Device seems to be offline (lock)
Nov 11 19:00:41 homebridge homebridge[14381]: [11.11.2020, 19:00:41] [FritzPlatform] Repeater-Kueche Led: Device seems to be offline (led)
Nov 11 19:00:41 homebridge homebridge[14381]: [11.11.2020, 19:00:41] [FritzPlatform] Repeater-Kueche Dect: Device seems to be offline (dect)
Nov 11 19:00:41 homebridge homebridge[14381]: [11.11.2020, 19:00:41] [FritzPlatform] Repeater-Kueche: Device seems to be offline (router)
Nov 11 19:00:42 homebridge homebridge[14381]: [11.11.2020, 19:00:42] [FritzPlatform] Fritzbox 7360: Device seems to be offline (router)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Emil: Device seems to be offline (router)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Emil Led: Device seems to be offline (led)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Emil Lock: Device seems to be offline (lock)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Emil Dect: Device seems to be offline (dect)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Kueche: Device seems to be offline (router)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Kueche Lock: Device seems to be offline (lock)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Kueche Led: Device seems to be offline (led)
Nov 11 19:00:43 homebridge homebridge[14381]: [11.11.2020, 19:00:43] [FritzPlatform] Repeater-Kueche Dect: Device seems to be offline (dect)
Nov 11 19:00:44 homebridge homebridge[14381]: [11.11.2020, 19:00:44] [FritzPlatform] FritzBox 7590 Led: ON (led)
Nov 11 19:00:45 homebridge homebridge[14381]: [11.11.2020, 19:00:45] [FritzPlatform] Fritzbox 7360: Device seems to be offline (router)
Nov 11 19:00:56 homebridge homebridge[14381]: [11.11.2020, 19:00:56] [FritzPlatform] Emil: Occupancy state changed to NOT DETECTED
Nov 11 19:00:56 homebridge homebridge[14381]: [11.11.2020, 19:00:56] [FritzPlatform] Emil: Wait 90s before switching state!
Nov 11 19:01:07 homebridge homebridge[14381]: [11.11.2020, 19:01:07] [FritzPlatform] Emil: Occupancy state switched back to DETECTED
