Seit ich meine Homebridge (Node, Plugins, Homebridge, Firmware,...) aktualisiert habe stürzt meine Homebridge immer wieder ab.
Mein Mailservice schickt mir folgendes Log - das sind alle Logeinträge seit dem letzten Absturz und automatischen restart. Jemand ne Idee, was das Problem sein könnte?
Im Screenshot alle aktuellen Versionen
Feb 17 21:01:34 homebridge homebridge[7189]: at Module._compile (module.js:660:30)
Feb 17 21:01:34 homebridge homebridge[7189]: at Object.Module._extensions..js (module.js:671:10)
Feb 17 21:01:34 homebridge homebridge[7189]: at Module.load (module.js:573:32)
Feb 17 21:01:34 homebridge systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Feb 17 21:01:34 homebridge systemd[1]: homebridge.service: Unit entered failed state.
Feb 17 21:01:34 homebridge systemd[1]: homebridge.service: Failed with result 'exit-code'.
Feb 17 21:01:44 homebridge systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Feb 17 21:01:44 homebridge systemd[1]: Stopped Node.js HomeKit Server.
Feb 17 21:01:44 homebridge systemd[1]: Started Node.js HomeKit Server.
Feb 17 21:01:45 homebridge homebridge[7212]: /usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
Feb 17 21:01:45 homebridge homebridge[7212]: throw ex;
Feb 17 21:01:45 homebridge homebridge[7212]: ^
Feb 17 21:01:45 homebridge homebridge[7212]: Error: The module '/usr/local/lib/node_modules/homebridge/node_modules/mdns/build/Release/dns_sd_bindings.node'
Feb 17 21:01:45 homebridge homebridge[7212]: was compiled against a different Node.js version using
Feb 17 21:01:45 homebridge homebridge[7212]: NODE_MODULE_VERSION 57. This version of Node.js requires
Feb 17 21:01:45 homebridge homebridge[7212]: NODE_MODULE_VERSION 59. Please try re-compiling or re-installing
Feb 17 21:01:45 homebridge homebridge[7212]: the module (for instance, using `npm rebuild` or `npm install`).
Feb 17 21:01:45 homebridge homebridge[7212]: at Object.Module._extensions..node (module.js:689:18)
Feb 17 21:01:45 homebridge homebridge[7212]: at Module.load (module.js:573:32)
Feb 17 21:01:45 homebridge homebridge[7212]: at tryModuleLoad (module.js:513:12)
Feb 17 21:01:45 homebridge homebridge[7212]: at Function.Module._load (module.js:505:3)
Feb 17 21:01:45 homebridge homebridge[7212]: at Module.require (module.js:604:17)
Feb 17 21:01:45 homebridge homebridge[7212]: at require (internal/module.js:11:18)
Feb 17 21:01:45 homebridge homebridge[7212]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
Feb 17 21:01:45 homebridge homebridge[7212]: at Module._compile (module.js:660:30)
Feb 17 21:01:45 homebridge homebridge[7212]: at Object.Module._extensions..js (module.js:671:10)
Feb 17 21:01:45 homebridge systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Feb 17 21:01:45 homebridge systemd[1]: homebridge.service: Unit entered failed state.
Feb 17 21:01:45 homebridge systemd[1]: homebridge.service: Failed with result 'exit-code'.
