Whuao ![]()
Hab mal nach meiner wilden Theorieerei eine Anfrage gestellt und PROMPT sogar folgende Antwort erhalten:
Zitat von AnfrageAlles anzeigenDear support team,
i guess since cupertino made some updates on their Bluetooth Chip drivers (i even don't know if they did... but it seems so ) the AUTO UNLOCK function is working as shit.
Sometimes it goes like the time before IOS12 - lets say PERFECT < 3 - sometimes it needs seconds or minutes and you have to enable disable the BT Button to activate AUTO UNLOCK.
This doesn't makes fun at all, do you have some workaround to deal with it?!
Best regards
Andreas
Zitat von DanalockAlles anzeigenDear Andreas,
We can only confirm that iOS 12 affected the auto unlock feature in a bad way.
The latest app 3.6.103 ensure an improvement, but still succesrate may vary.
We recommend that you try changing the auto-unlock zone, so e.g.:
If you arrive home by car, zone should be wide (e.g. 1000 m)
If you arrive home by bike or if you walk , zone should be smaller (300 m)
If you live in an apartment, zone should be smaller (300 m)
When you are 40 to 50 meters from your Danalock, your smart phone will send periodic commands to unlock the door. If the app is unable to reach your Danalock within four minutes, the Auto Unlock command will time-out.
//Danalock
hmmmmmm... denke aber das ihre Vorschläge bei mir nicht viel bringen werden, bin ja bereits am experimentieren gewesen und hab z.B. nur eine Range von 200m im Moment
