ich habe es jetzt auch einmal gewagt und, fast hätte ich gesagt, wie erwartet, läuft es nach der Neuinstallation des Images über den Raspberry Pi Imager nicht ganz rund. Nach dem Wiedereinspielen meines Backups schafft es homebridge nicht, das homebrige-hue und das homebridge-zway-plaugin zu laden.
[18/11/2023, 17:33:15] [Hue] goodbye
[18/11/2023, 17:33:15] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[18/11/2023, 17:33:47] [HB Supervisor] OS: Linux 6.1.21-v8+ arm
[18/11/2023, 17:33:47] [HB Supervisor] Node.js v20.9.0 /opt/homebridge/bin/node
[18/11/2023, 17:33:47] [HB Supervisor] Homebridge Path: /var/lib/homebridge/node_modules/homebridge/bin/homebridge
[18/11/2023, 17:33:47] [HB Supervisor] UI Path: /opt/homebridge/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
prebuild-file-path: /opt/homebridge/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/prebuilds/linux-arm/node.abi115.node
[18/11/2023, 17:34:20] [Homebridge UI] Homebridge UI v4.52.3 is listening on :: port 8581
[18/11/2023, 17:34:20] [HB Supervisor] Starting Homebridge with extra flags: -I -P /var/lib/homebridge/node_modules --strict-plugin-resolution
[18/11/2023, 17:34:20] [HB Supervisor] Started Homebridge v1.7.0 with PID: 843
[18/11/2023, 17:34:22] Loaded config.json with 0 accessories and 6 platforms.
[18/11/2023, 17:34:22] Loaded 15 cached accessories from cachedAccessories.
[18/11/2023, 17:34:22] ---
[18/11/2023, 17:34:28] Loaded plugin: [email protected]
[18/11/2023, 17:34:28] Registering platform 'homebridge-hue.Hue'
[18/11/2023, 17:34:28] ---
[18/11/2023, 17:34:29] Loaded plugin: [email protected]
[18/11/2023, 17:34:29] Registering platform 'homebridge-meross.Meross'
[18/11/2023, 17:34:29] ---
[18/11/2023, 17:34:33] Loaded plugin: [email protected]
[18/11/2023, 17:34:33] Registering platform 'homebridge-ring.Ring'
[18/11/2023, 17:34:33] ---
[18/11/2023, 17:34:35] Registering platform 'homebridge-shelly.Shelly'
[18/11/2023, 17:34:35] ---
[18/11/2023, 17:34:35] Loaded plugin: [email protected]
[18/11/2023, 17:34:35] Registering accessory 'homebridge-zway.ZWayServer'
[18/11/2023, 17:34:35] Registering platform 'homebridge-zway.ZWayServer'
[18/11/2023, 17:34:35] Loading 6 platforms...
[18/11/2023, 17:34:35] [ZWayServer] Initializing ZWayServer platform...
[18/11/2023, 17:34:35] [Hue] Initializing Hue platform...
[18/11/2023, 17:34:35] [Hue] homebridge-hue v0.13.69, node v20.9.0, homebridge v1.7.0
[18/11/2023, 17:34:35] [Hue] warning: planned changes, see https://github.com/ebaauw/homebridge-hue/issues/1070
[18/11/2023, 17:34:35] [Hue] config.json: nupnp: invalid key
[18/11/2023, 17:34:35] [Shelly] Initializing Shelly platform...
[18/11/2023, 17:34:35] [Meross] Initializing Meross platform...
[18/11/2023, 17:34:35] [Meross] Initialising plugin v10.0.0 | System linux | Node v20.9.0 | HB v1.7.0 | HAPNodeJS v0.11.1...
[18/11/2023, 17:34:35] [Ring] Initializing Ring platform...
[18/11/2023, 17:34:35] [Ring] Configuring cached accessory d96a6548-0c26-4e7d-9974-efc84e90f684 Haustür
[18/11/2023, 17:34:35] [Ring] Configuring cached accessory dd66b1b2-09d3-4d9c-b7b7-79304d2b60de Flur Anbau
[18/11/2023, 17:34:35] [Ring] Configuring cached accessory 26ba3295-4828-45bb-ab91-49007b0c0c1f Sinntal Mode
[18/11/2023, 17:34:35] [Shelly] 11 accessories loaded from cache
[18/11/2023, 17:34:35] [Meross] Plugin initialised. Setting up accessories....
[18/11/2023, 17:34:36] [Shelly] Admin server is running on port 8181
[18/11/2023, 17:34:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:34:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:34:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:34:36] [ZWayServer] ERROR: Request failed! Error code ECONNREFUSED. Check the URL in config.json and ensure that the URL can be reached from this system!
[18/11/2023, 17:34:36] [Meross] [Garagentor] initialising with options {"connection":"hybrid","garageDoorOpeningTime":20}.
[18/11/2023, 17:34:36] [Meross] [Garagentor] initialised with id [2006040578021736100248e1e91e4f88}].
[18/11/2023, 17:34:36] [Meross] ✓ Setup complete. This plugin has been made with ♥ by bwp91, please consider a ☆ on GitHub if you are finding it useful!
[18/11/2023, 17:34:37] [Ring] Found the following locations:
[18/11/2023, 17:34:37] [Ring] locationId: 710b6ca7-cb5f-4496-9a9e-90f5402fb725 - Sinntal
[18/11/2023, 17:34:37] [Ring] Configuring 1 cameras and 3 devices for location "Sinntal" - locationId: 710b6ca7-cb5f-4496-9a9e-90f5402fb725
[18/11/2023, 17:34:39] [Meross] [Garagentor] has been reported [online].
[18/11/2023, 17:34:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:34:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:35:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:35:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:35:15] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:15] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:35] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:35] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:35:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:35:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:35:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:35:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:36:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:36:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:36:15] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:15] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:35] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:35] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:36:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:36:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:36:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:36:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:37:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:37:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:37:15] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:15] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:35] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:35] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:37:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:37:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:37:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:37:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:38:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:38:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:38:15] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:15] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:35] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:35] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:38:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:38:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:38:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:38:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:39:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:39:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:39:15] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:15] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:35] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:35] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:36] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:39:36] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:39:36] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:39:55] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:39:55] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
[18/11/2023, 17:40:06] [Hue] 192.***.***.102: request 1: GET /config
[18/11/2023, 17:40:06] [Hue] 192.168.0.102: request 1: connect ECONNREFUSED 192.168.0.102:8090
[18/11/2023, 17:40:06] [Hue] 192.168.0.102:8090: not found - retrying in 30s
[18/11/2023, 17:40:15] [homebridge-zway] This plugin is taking long time to load a
Auf die Phoscon-Oberfläche kann ich auch nicht mehr zugreifen. Der Link landet im Nirvana. Letztlich steuere ich über das hue-plugin den Cobee II-Stick und die Hue-Bridge an, was in der "alten" Homebridge verlässlich funktionierte.
In Homekit funktionieren weder die Meross- noch die Conbee-Geräte (Keine Antwort). Die an der Hue-Bridge angeschlossenen Geräte (auch über das homebridge-plugin) funktionieren dagegen.
