in der config.json müssen folgend Zeilen gelöscht werden.
Dann sind folgende Log Einträge auch nicht mehr da.
Ich hab jetzt nur noch eins im Log beobachten können das ich immer wieder folgende Einträge habe die ich nicht deuten kann.
Das ist der gesamte log.
[07/04/2021, 21:04:42] [Homebridge UI] Homebridge log truncated by admin.
[07/04/2021, 21:04:51] [Homebridge UI] Rebooting linux server with command: "sudo -n shutdown -r now"
[07/04/2021, 21:04:52] [HB Supervisor] Stopping services...
[07/04/2021, 21:04:52] Got SIGTERM, shutting down Homebridge...
[07/04/2021, 21:04:52] [Hue] Smart Home F&P: websocket connection to ws://127.0.0.1:4531 closed - retrying in 15s
[07/04/2021, 21:04:57] [Hue] goodbye
[07/04/2021, 21:04:57] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[07/04/2021, 21:05:18] [HB Supervisor] OS: Linux 5.10.17-v7+ arm
[07/04/2021, 21:05:18] [HB Supervisor] Node.js v14.16.0 /usr/local/bin/node
[07/04/2021, 21:05:18] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[07/04/2021, 21:05:18] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[07/04/2021, 21:05:28] [Homebridge UI] Homebridge Config UI X v4.41.0 is listening on :: port 8581
[07/04/2021, 21:05:29] [HB Supervisor] Starting Homebridge with extra flags: -I
[07/04/2021, 21:05:29] [HB Supervisor] Started Homebridge v1.3.4 with PID: 1344
Initializing HAP-NodeJS v0.9.4...
[07/04/2021, 21:05:31] Loaded config.json with 0 accessories and 3 platforms.
[07/04/2021, 21:05:31] Loaded 4 cached accessories from cachedAccessories.
[07/04/2021, 21:05:31] ---
[07/04/2021, 21:05:33] Loaded plugin: [email protected]
[07/04/2021, 21:05:33] Registering platform 'homebridge-config-ui-x.config'
[07/04/2021, 21:05:33] ---
[07/04/2021, 21:05:48] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[07/04/2021, 21:05:48] ---
[07/04/2021, 21:05:53] Loaded plugin: [email protected]
[07/04/2021, 21:05:53] Registering platform 'homebridge-hue.Hue'
[07/04/2021, 21:05:53] ---
[07/04/2021, 21:05:53] Loading 3 platforms...
[07/04/2021, 21:05:53] [Config] Initializing config platform...
[07/04/2021, 21:05:53] [Config] Running in Service Mode
[07/04/2021, 21:05:53] [Hue] Initializing Hue platform...
[07/04/2021, 21:05:53] [Hue] homebridge-hue v0.13.5, node v14.16.0, homebridge v1.3.4
[07/04/2021, 21:05:53] [FritzPlatform] Initializing FritzPlatform platform...
[07/04/2021, 21:05:57] [FritzPlatform] Fritz!Box F&P Wifi guest: Configuring accessory...
[07/04/2021, 21:05:57] [FritzPlatform] Fritz!Box F&P Deflection: Configuring accessory...
[07/04/2021, 21:05:57] [FritzPlatform] Terrassenlicht: Configuring accessory...
[07/04/2021, 21:05:57] [FritzPlatform] Terrassenlicht Temperature: Configuring accessory...
[07/04/2021, 21:05:57] [Hue] Smart Home F&P: dresden elektronik deCONZ gateway v2.10.4, api v1.16.0
[07/04/2021, 21:05:58] [Hue] Smart Home F&P: /lights/6: warning: using default colour gamut for unknown light model {"colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"0cd71a24be348961a75bfbd2af75fefb","hascolor":true,"lastannounced":"2021-03-23T02:19:00Z","lastseen":"2021-04-07T19:05Z","manufacturername":"Paulmann Licht GmbH","modelid":"RGBW light","name":"Kugellicht","state":{"alert":"none","bri":254,"colormode":"xy","ct":0,"effect":"none","hue":21672,"on":false,"reachable":true,"sat":233,"xy":[0.178,0.6783]},"swversion":"1218-0909","type":"Extended color light","uniqueid":"00:15:8d:00:03:12:b5:e6-01"}
[07/04/2021, 21:05:58] [Hue] Smart Home F&P: 6 accessories
[07/04/2021, 21:05:58] [Hue] masked debug info dumped to /var/lib/homebridge/homebridge-hue.json.gz
[07/04/2021, 21:05:58] Initializing platform accessory 'Smart Home F&P'...
[07/04/2021, 21:05:58] [Hue] Smart Home F&P: 2 services
[07/04/2021, 21:05:58] Initializing platform accessory 'Duschen Licht'...
[07/04/2021, 21:05:58] Initializing platform accessory 'Nischen Licht'...
[07/04/2021, 21:05:58] Initializing platform accessory 'Waschtisch Licht'...
[07/04/2021, 21:05:58] Initializing platform accessory 'Wand Licht'...
[07/04/2021, 21:05:58] Initializing platform accessory 'Kugellicht'...
Preparing Advertiser for 'Homebridge EF93' using bonjour-hap backend!
Setup Payload:
X-HM://0024CVTMBDKDO
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 000-00-000 │
Starting to advertise 'Homebridge EF93' using bonjour-hap backend!
[07/04/2021, 21:05:58] Homebridge v1.3.4 (Homebridge) is running on port 51857.
[07/04/2021, 21:05:59] [Hue] Kugellicht: set homekit supported transition configuration to {"configuration":[{"iid":11,"characteristic":1},{"iid":13,"characteristic":2}]}
[07/04/2021, 21:05:59] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 21:06:00] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 21:06:28] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 21:06:57] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 21:13:12] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 21:16:05] [Hue] Duschen Licht: set homekit on from true to false
[07/04/2021, 21:16:05] [Hue] Duschen Licht: set homekit on from false to true
[07/04/2021, 21:17:53] [Hue] Wand Licht: set homekit on from true to false
[07/04/2021, 22:19:36] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 22:59:18] [Hue] Wand Licht: set homekit on from false to true
[07/04/2021, 23:00:00] [Hue] Wand Licht: set homekit on from true to false
[07/04/2021, 23:04:08] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 23:34:56] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 23:35:14] [Hue] Wand Licht: set homekit on from false to true
[07/04/2021, 23:35:55] [Hue] Wand Licht: set homekit on from true to false
[07/04/2021, 23:39:38] [Hue] Kugellicht: set homekit transition control to ""
[07/04/2021, 23:50:21] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 00:29:25] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 00:34:25] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 01:10:39] [Homebridge UI] Running job to cleanup config.json backup files older than 60 days...
[08/04/2021, 01:15:36] [Homebridge UI] Running scheduled instance backup...
[08/04/2021, 01:15:36] [Homebridge UI] Creating temporary backup archive at /tmp/homebridge-backup-8caA7a/homebridge-backup-0EA17A781D68.tar.gz
[08/04/2021, 01:23:30] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 01:32:27] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 03:00:39] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 03:06:03] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 03:24:04] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 03:38:23] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 04:12:15] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 06:04:12] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 06:07:05] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:07:17] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:07:28] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:07:39] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:07:50] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:01] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:12] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:24] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:35] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:46] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 06:08:57] [homebridge-fritz-platform] This plugin generated a warning from the characteristic 'Amperes': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[08/04/2021, 07:20:33] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 07:41:42] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 08:05:55] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 08:50:17] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 09:49:22] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 09:53:04] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 11:52:39] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 12:23:27] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 12:40:18] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 13:11:25] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 13:27:45] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 13:28:16] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 13:30:27] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 15:01:17] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 15:07:29] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 15:51:07] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 16:08:01] [Hue] Kugellicht: set homekit transition control to ""
[08/04/2021, 16:13:00] [Hue] Kugellicht: set homekit transition control to ""
Das ist die Aktuelle config.json dazu.
"name": "FritzPlatform",
"devices": [
"name": "Fritz!Box F&P",
"host": "192.168.178.1",
"username": "User",
"password": "Passwort",
"ssl": true,
"tr064": true,
"igd": false,
"manufacturer": "AVM",
"model": "FRITZ!Box 7490",
"serialNumber": "H000.000.00.000.000",
"master": true,
"hide": true,
"connection": "dsl",
"options": {
"wifi_guest": "switch",
"deflection": "switch"
"smarthome": [
"name": "Terrassenlicht",
"ain": "00000 0000000",
"energy": true,
"temperature": true,
"accType": "switch"
"callmonitor": {
"active": false,
"port": 1012
"extras": {
"alarm": {
"active": false
"wakeup": {
"active": false
"ringlock": {
"active": false
"phoneBook": {
"active": false
"options": {
"polling": {
"timer": 10
"telegram": {
"active": false
"platform": "FritzPlatform"
